Description
When trying to execute an ONNX model converted from
torch.hub.load('pytorch/vision:v0.10.0', 'fcn_resnet50', pretrained=True)
I get the following error
[TensorRT] ERROR: 3: [executionContext.cpp::enqueueInternal::322] Error Code 3: Internal Error (Parameter check failed at: runtime/api/executionContext.cpp::enqueueInternal::322, condition: bindings != nullptr
I used the code in TensorRT/samples directory and my very basic engine is below.
Building stream
import numpy as np
import pycuda.driver as cuda
import pycuda.autoinit
input_batch = np.empty([1,3,720,1280], dtype=np.float16)
output = np.empty([1, 21, 720, 1280], dtype = np.float16)
d_input = cuda.mem_alloc(1 * input_batch.nbytes)
d_output = cuda.mem_alloc(1 * output.nbytes)
bindings = [int(d_input), int(d_output)]
stream = cuda.Stream()
Building context
import tensorrt as trt
f = open("fcn-resnet50-11.trt", "rb")
runtime = trt.Runtime(trt.Logger(trt.Logger.WARNING))
engine = runtime.deserialize_cuda_engine(f.read())
context = engine.create_execution_context()
Prediction Part
def predict(batch):
cuda.memcpy_htod_async(d_input, batch, stream)
context.execute_async_v2(bindings, stream.handle, None)
cuda.memcpy_dtoh_async(output, d_output, stream)
stream.synchronize()
return output
I can execute resnet18_fcn.onnx taken from the jetson-inference module with the same code.
I also tried models from models/vision/object_detection_segmentation/fcn at main · onnx/models · GitHub but I can not achieve the execute properly.
Environment
TensorRT Version: 8.0.3.4
GPU Type: GTX 1660 Ti
Nvidia Driver Version: 465
CUDA Version: 11.3.1
CUDNN Version: 8.2.1
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8
PyTorch Version (if applicable): 1.10.1
Steps To Reproduce
Convert FCN-ResNet50 from torchhub and convert TRT.
Run it with engine above.
