I am trying to convert an ONNX version of a ReIdentification vehicle network to TensorRT. I am running this script for the conversion from ONNX to TensorRT. However, the engine is never created. I have found this error in other posts, but the solution suggested is to use trtexec…however, I was wondering how to solve it with Python.
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command. https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
@NVES Thanks for the quick reply. As you can see in my original post, I shared my ONNX file since the beginning.
Today I was able to successfully convert the model using trtexec. However, If I try to load it into pytorch (torch.load) it gives me the following error:
“UnpicklingError: unpickling stack underflow”
Could you please tell me the easiest way to load my trained trt model into pytorch?
