Description
I use a docker container build from tensorflow/tensorflow:2.5.0-gpu, and download tensorrt by myself in this container. It failed when I try to build an engine from my onnx model, and I can’t find any helpful information from the error message. I upload my onnx file here, and anyone may help me build the engine(any environment is OK…)? Or just tell me why I can’t build engine. Thanks!
Environment
TensorRT Version: 8.2.1.8
GPU Type: rtx2080
Nvidia Driver Version: 465.19.01
CUDA Version: 11.2.152
CUDNN Version: 8.1.0
Operating System + Version: ubuntu18.04
Python Version (if applicable): 3.6.9
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag): tensorflow/tensorflow:2.5.0-gpu
Relevant Files
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
def build_engine(onnx_path, using_half=True, dynamic_input=False):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(1) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
# builder.max_batch_size = 1
config = builder.create_builder_config()
config.max_workspace_size = 2 * 1 << 30
if using_half:
config.set_flag(trt.BuilderFlag.FP16)
with open(onnx_path, 'rb') as model:
if not parser.parse(model.read()):
print('error: failed to parse onnx model')
for error in range(parser.num_errors):
print(parser.get_error(error))
return None
engine = builder.build_engine(network, config)
return engine
engine = build_engine(r'./model.onnx', False, True)
update
solve the problem using the tensorrt ngc(21.11-py3) temporarily, and I have removed the onnx model.
