Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command. https://github.com/NVIDIA/TensorRT/tree/master/samples/opensource/trtexec
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
Sorry, I made a typing mistake and the display went wrong.
Re-write the script.
import sys, os, glob
import numpy as np
import tensorrt as trt
import common
from tensorflow.keras.preprocessing.image import img_to_array, load_img
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
def build_engine_onnx(model_file, batch_size):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(common.EXPLICIT_BATCH) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
builder.max_workspace_size = common.GiB(1)
builder.fp16_mode = True
with open(model_file, 'rb') as model:
if not parser.parse(model.read()):
print('ERROR: Failed to parse the ONNX file.')
for error in range(parser.num_errors):
print(parser.get_error(error))
return None
return builder.build_cuda_engine(network)
def main():
model_file = ‘/home/--/sample.onnx’
hold_vector = np.load(’/home/--/sample-hv.npy’)
batch_size = 32
with build_engine_onnx(model_file, batch_size) as engine, create_execution_context() as context:
serialized_engine = engine.serialize()
with open('samplename.engine', 'wb') as f:
f.write(engine.serialize())
if __name__ == "__main__":
main()
and Then,
[TensorRT] ERROR: Network has dynamic or shape inputs, but no optimization profile has been defined.
[TensorRT] ERROR: Network validation failed.
with build_engine_onnex(model_file, batch_size) as engine, engine.create_executioncontext() as contexit:
AttributeError: __enter__
When I use the same script with Jetson NANO, I don’t get an error, so I think there is a problem with the Docker environment.
I want to use Docker to start the script, so it would be helpful if you could give me some advice on building the environment.
