• Hardware Platform(GPU) RTX 3080 (also Jetson Orin Devkit and Xavier NX)
• DeepStream Version 6.1
• TensorRT Version 8.5
• Issue Type( questions) questions
So I have a complex pipeline in which I am using a series of CNNs. After the processing, I am using a combination of demuxer and a tee to store each of the raw video streams individually on the file system as well as display the tiled video using ‘nveglglessink’. Everything works perfectly, apart from the fact that the recorded raw video streams do not have an EOS which causes them to be unseekable.
I was able to use SIGINT by attaching a callback to GLib.unix_signal_add() to send EOS to properly close the files when the application is terminated using CTRL + C. But the problem persists when I terminate the application by closing the display window created by ‘nveglglessink’.
Edit: I have tried both signal.SIGINT and signal.SIGTERM.
