• Hardware Platform (Jetson / GPU) Tesla T4 • DeepStream Version 5.0 • TensorRT Version 8.0.0-1 • NVIDIA GPU Driver Version (valid for GPU only) 11.3
I am following the steps given in GitHub - NVIDIA-AI-IOT/yolov4_deepstream to create a tensorrt engine file, and then I use it to run deepstream-app. However, I get the following error:
Based on this topic and a few other topics, this is due to a mismatch between tensorrt version used for creating the engine and the one for deserializing it. However, I am creating the engine on the same machine and I assume that the same version of tensorrt should be used for both task.
Do you know what can possibly cause this problem?
From the description, you used TRT 8.0.0, for deepstream 5.0, you should use TensorRT 7.0.X
