Integrate the engine generated above into deepstream5.0, most of the results can be consistent, but some more target boxes will be detected on some images.
That is, some false positives will be generated when passing deepstream detection.
This issue is observed on your side, what do you ask us to test?
In my above reply, I mean you reproduce the issue with aove YoloV4 DS and share the screenshot of the issue - some false positives will be generated when passing deepstream detection?
Or whether other customers also encountered the problem, we always inconsistent with our model test results in the actual product deployment environment, which caused us a lot of trouble.
I mean I have a workable YoloV4 version (here ), you can use your custom data to test. We have verified the mAP of this model.
If you can’t reproduce the issue with this DS app & model, it indicates the issue comes from your model, you need to retrain your model.
I know, maybe I am not clear about it. I have downloaded it many times, but it will be aborted every time. Are there other ways to download the above files?
