Serialized engine contains plugin, but no plugin factory was provided
• Hardware Platform (Jetson / GPU) -> dGPU aws T4
• DeepStream Version - 5.0
• TensorRT Version -> 7+
• NVIDIA GPU Driver Version (valid for GPU only) -> 440.82
I have created TensorRT engine using tensorRT API. And was trying to use the engine file to do inference on RetinaFace detection. Below is my config file:
[property]
gpu-id=0
net-scale-factor=0.0039215697906911373
model-engine-file=../../../samples/models/RetinaFace_Detector/retina_r50.engine
# create labels file
# labelfile-path=./labels.txt
batch-size=1
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=1
interval=0
gie-unique-id=1
is-classifier=0
custom-lib-path=./libdecodeplugin.so
[class-attrs-all]
threshold=0.2
group-threshold=1
## Set eps=0.7 and minBoxes for enable-dbscan=1
eps=0.2
#minBoxes=3
roi-top-offset=0
roi-bottom-offset=0
detected-min-w=0
detected-min-h=0
detected-max-w=1920
detected-max-h=1080
And this is the custom plugin that I defined while creating tensorRT engine file:
#ifndef _DECODE_CU_H
#define _DECODE_CU_H
#include "decode.h"
#include "stdio.h"
namespace nvinfer1
    DecodePlugin::DecodePlugin()
    DecodePlugin::~DecodePlugin()
    // create the plugin at runtime from a byte stream
    DecodePlugin::DecodePlugin(const void* data, size_t length)
    void DecodePlugin::serialize(void* buffer) const
    size_t DecodePlugin::getSerializationSize() const
        return 0;
    int DecodePlugin::initialize()
        return 0;
    Dims DecodePlugin::getOutputDimensions(int index, const Dims* inputs, int nbInputDims)
        //output the result to channel
        int totalCount = 0;
        totalCount += decodeplugin::INPUT_H / 8 * decodeplugin::INPUT_W / 8 * 2 * sizeof(decodeplugin::Detection) / sizeof(float);
        totalCount += decodeplugin::INPUT_H / 16 * decodeplugin::INPUT_W / 16 * 2 * sizeof(decodeplugin::Detection) / sizeof(float);
        totalCount += decodeplugin::INPUT_H / 32 * decodeplugin::INPUT_W / 32 * 2 * sizeof(decodeplugin::Detection) / sizeof(float);
        return Dims3(totalCount + 1, 1, 1);
    // Set plugin namespace
    void DecodePlugin::setPluginNamespace(const char* pluginNamespace)
        mPluginNamespace = pluginNamespace;
    const char* DecodePlugin::getPluginNamespace() const
        return mPluginNamespace;
    // Return the DataType of the plugin output at the requested index
    DataType DecodePlugin::getOutputDataType(int index, const nvinfer1::DataType* inputTypes, int nbInputs) const
        return DataType::kFLOAT;
    // Return true if output tensor is broadcast across a batch.
    bool DecodePlugin::isOutputBroadcastAcrossBatch(int outputIndex, const bool* inputIsBroadcasted, int nbInputs) const
        return false;
    // Return true if plugin can use input that is broadcast across batch without replication.
    bool DecodePlugin::canBroadcastInputAcrossBatch(int inputIndex) const
        return false;
    void DecodePlugin::configurePlugin(const PluginTensorDesc* in, int nbInput, const PluginTensorDesc* out, int nbOutput)
    // Attach the plugin object to an execution context and grant the plugin the access to some context resource.
    void DecodePlugin::attachToContext(cudnnContext* cudnnContext, cublasContext* cublasContext, IGpuAllocator* gpuAllocator)
    // Detach the plugin object from its execution context.
    void DecodePlugin::detachFromContext() {}
    const char* DecodePlugin::getPluginType() const
        return "Decode_TRT";
    const char* DecodePlugin::getPluginVersion() const
        return "1";
    void DecodePlugin::destroy()
        delete this;
    // Clone the plugin
    IPluginV2IOExt* DecodePlugin::clone() const
        DecodePlugin *p = new DecodePlugin();
        p->setPluginNamespace(mPluginNamespace);
        return p;
    __device__ float Logist(float data){ return 1./(1. + expf(-data)); };
    __global__ void CalDetection(const float *input, float *output, int num_elem, int step, int anchor) {
        int idx = threadIdx.x + blockDim.x * blockIdx.x;
        if (idx >= num_elem) return;
        int h = decodeplugin::INPUT_H / step;
        int w = decodeplugin::INPUT_W / step;
        int y = idx / w;
        int x = idx % w;
        const float *bbox_reg = &input[0];
        const float *cls_reg = &input[2 * 4 * num_elem];
        const float *lmk_reg = &input[2 * 4 * num_elem + 2 * 2 * num_elem];
        for (int k = 0; k < 2; ++k) {
            float conf1 = cls_reg[idx + k * num_elem * 2];
            float conf2 = cls_reg[idx + k * num_elem * 2 + num_elem];
            conf2 = expf(conf2) / (expf(conf1) + expf(conf2));
            if (conf2 <= 0.02) continue;
            float *res_count = output;
            int count = (int)atomicAdd(res_count, 1);
            char* data = (char *)res_count + sizeof(float) + count * sizeof(decodeplugin::Detection);
            decodeplugin::Detection* det = (decodeplugin::Detection*)(data);
            float prior[4];
            prior[0] = ((float)x + 0.5) / w;
            prior[1] = ((float)y + 0.5) / h;
            prior[2] = (float)anchor * (k + 1) / decodeplugin::INPUT_W;
            prior[3] = (float)anchor * (k + 1) / decodeplugin::INPUT_H;
            //Location
            det->bbox[0] = prior[0] + bbox_reg[idx + k * num_elem * 4] * 0.1 * prior[2];
            det->bbox[1] = prior[1] + bbox_reg[idx + k * num_elem * 4 + num_elem] * 0.1 * prior[3];
            det->bbox[2] = prior[2] * expf(bbox_reg[idx + k * num_elem * 4 + num_elem * 2] * 0.2);
            det->bbox[3] = prior[3] * expf(bbox_reg[idx + k * num_elem * 4 + num_elem * 3] * 0.2);
            det->bbox[0] -= det->bbox[2] / 2;
            det->bbox[1] -= det->bbox[3] / 2;
            det->bbox[2] += det->bbox[0];
            det->bbox[3] += det->bbox[1];
            det->bbox[0] *= decodeplugin::INPUT_W;
            det->bbox[1] *= decodeplugin::INPUT_H;
            det->bbox[2] *= decodeplugin::INPUT_W;
            det->bbox[3] *= decodeplugin::INPUT_H;
            det->class_confidence = conf2;
            for (int i = 0; i < 10; i += 2) {
                det->landmark[i] = prior[0] + lmk_reg[idx + k * num_elem * 10 + num_elem * i] * 0.1 * prior[2];
                det->landmark[i+1] = prior[1] + lmk_reg[idx + k * num_elem * 10 + num_elem * (i + 1)] * 0.1 * prior[3];
                det->landmark[i] *= decodeplugin::INPUT_W;
                det->landmark[i+1] *= decodeplugin::INPUT_H;
    void DecodePlugin::forwardGpu(const float *const * inputs, float * output, cudaStream_t stream, int batchSize)
        int num_elem = 0;
        int base_step = 8;
        int base_anchor = 16;
        int thread_count;
        cudaMemset(output, 0, sizeof(float));
        for (unsigned int i = 0; i < 3; ++i)
            num_elem = decodeplugin::INPUT_H / base_step * decodeplugin::INPUT_W / base_step;
            thread_count = (num_elem < thread_count_) ? num_elem : thread_count_;
            CalDetection<<< (num_elem + thread_count - 1) / thread_count, thread_count>>>
                (inputs[i], output, num_elem, base_step, base_anchor);
            base_step *= 2;
            base_anchor *= 4;
    int DecodePlugin::enqueue(int batchSize, const void*const * inputs, void** outputs, void* workspace, cudaStream_t stream)
        //assert(batchSize == 1);
        //GPU
        //CUDA_CHECK(cudaStreamSynchronize(stream));
        forwardGpu((const float *const *)inputs,(float *)outputs[0],stream,batchSize);
        return 0;
    PluginFieldCollection DecodePluginCreator::mFC{};
    std::vector<PluginField> DecodePluginCreator::mPluginAttributes;
    DecodePluginCreator::DecodePluginCreator()
        mPluginAttributes.clear();
        mFC.nbFields = mPluginAttributes.size();
        mFC.fields = mPluginAttributes.data();
    const char* DecodePluginCreator::getPluginName() const
    const char* DecodePluginCreator::getPluginVersion() const
        return "1";
    const PluginFieldCollection* DecodePluginCreator::getFieldNames()
        return &mFC;
    IPluginV2IOExt* DecodePluginCreator::createPlugin(const char* name, const PluginFieldCollection* fc)
        DecodePlugin* obj = new DecodePlugin();
        obj->setPluginNamespace(mNamespace.c_str());
        return obj;
    IPluginV2IOExt* DecodePluginCreator::deserializePlugin(const char* name, const void* serialData, size_t serialLength)
        // This object will be deleted when the network is destroyed, which will
        // call PReluPlugin::destroy()
        DecodePlugin* obj = new DecodePlugin(serialData, serialLength);
        return obj;
for which I have a libdecodeplugin.so that I have mentioned in the config file.
Deserializing engine file with this plugin works when I tested in tensorrt docker container but fails when deepstream deserializes using the lib.so liibrary for this plugin. I havent found any resources yet.
How do I include this so that I can deserialize tensorRT engine file successfully in deepstream?
and this is the terminal output:
root@73183ab47661:/opt/nvidia/deepstream/deepstream-5.0/sources/apps/deepstream-retinaface-multistream# ./deepstream-retinaface-multistream-app ../../../samples/streams/sample_720p.mp4
(gst-plugin-scanner:26): GStreamer-WARNING **: 07:09:47.376: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtrtserver.so: cannot open shared object file: No such file or directory
Warn: 'threshold' parameter has been deprecated. Use 'pre-cluster-threshold' instead.
Now playing: ../../../samples/streams/sample_720p.mp4
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: INVALID_ARGUMENT: getPluginCreator could not find plugin Decode_TRT version 1
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: safeDeserializationUtils.cpp (293) - Serialization Error in load: 0 (Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: INVALID_STATE: std::exception
ERROR: ../nvdsinfer/nvdsinfer_func_utils.cpp:31 [TRT]: INVALID_CONFIG: Deserialize the cuda engine failed.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:1452 Deserialize engine failed from file: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/deepstream-retinaface-multistream/tensorrt_engines_awsT4/retina_r50.engine
0:00:04.315405593    25 0x5618a017b8d0 WARN                 nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1566> [UID = 1]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/deepstream-retinaface-multistream/tensorrt_engines_awsT4/retina_r50.engine failed
0:00:04.315444719    25 0x5618a017b8d0 WARN                 nvinfer gstnvinfer.cpp:599:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1673> [UID = 1]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/deepstream-retinaface-multistream/tensorrt_engines_awsT4/retina_r50.engine failed, try rebuild
0:00:04.315464105    25 0x5618a017b8d0 INFO                 nvinfer gstnvinfer.cpp:602:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1591> [UID = 1]: Trying to create engine from model files
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:934 failed to build network since there is no model file matched.
ERROR: ../nvdsinfer/nvdsinfer_model_builder.cpp:872 failed to build network.
0:00:04.315759096    25 0x5618a017b8d0 ERROR                nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1611> [UID = 1]: build engine file failed
0:00:04.315783396    25 0x5618a017b8d0 ERROR                nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1697> [UID = 1]: build backend context failed
0:00:04.315800708    25 0x5618a017b8d0 ERROR                nvinfer gstnvinfer.cpp:596:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1024> [UID = 1]: generate backend failed, check config file settings
0:00:04.315966590    25 0x5618a017b8d0 WARN                 nvinfer gstnvinfer.cpp:781:gst_nvinfer_start:<primary-nvinference-engine> error: Failed to create NvDsInferContext instance
0:00:04.315979631    25 0x5618a017b8d0 WARN                 nvinfer gstnvinfer.cpp:781:gst_nvinfer_start:<primary-nvinference-engine> error: Config file path: retinaface_pgie_config.txt, NvDsInfer Error: NVDSINFER_CONFIG_FAILED
Running...
ERROR from element primary-nvinference-engine: Failed to create NvDsInferContext instance
Error details: gstnvinfer.cpp(781): gst_nvinfer_start (): /GstPipeline:dstest1-pipeline/GstNvInfer:primary-nvinference-engine:
Returned, stopping playback
Deleting pipeline
@y14uc339
There are some items to be clarified.
  1. How did you build your TensorRT engine with the APIs? Do you mind showing me the code? You can just give me the minimum implementation that can reproduce this error.
  2. Could you please show me all source code updates you have done to TensorRT/parsers/ and TensorRT/plugin/ as well as your commands & operations to reproduce this fault step by step?
  3. It would be wonderful that you sent me a packed file including your config files, updated source code files, together with the workspace like deepstream-retinaface-multistream. You can give me a link of one drive, google drive or baidu drive so that I can download.
Hi @ersheng , I dont really understand when you talk about TensorRT/parsers. Everything that I have done is in the below drive link. Yeah below is the drive link with both DeepStream app and RetinaFace Tensorrt that I used to create the serialized engine file. I have placed the engine file and libdecodeplugin.so that were generated during tensorrt serialization inside deepstream app but if you want to generate them again you can always do that using the readme that I have attached with the TensorRT folder. Please let me know if you need any help.
https://drive.google.com/open?id=1Yb_vDTWC2BoFb_TqDcc7XVrOfS6G-F52
To start and reroduce the error in deepstream docker container:
  1. Copy and paste the deepstream app in /opt/nvidia/deepstream/deepstream-5.0/sources/apps
  2. $ make
  3. $ ./deepstream-retinaface-multistream-app …/…/…/samples/streams/sample_720p.mp4
@y14uc339
Parser is needed if TensorRT has to convert onnx, uff or caffe models into engine files.
Since you manually use APIs to build engine by yourself, maybe you don’t need to use parsers or update any code inside TensorRT/parsers
Okay @ersheng ! Yeah I am manually using APIs. Also are you able to access the drive folder? Let me know if you need any help!
@y14uc339
I sent an access request needing your approval
@ersheng approved like 2 mins ago.
@ersheng I made a small update to decode.cu in tensorrt folder and added this line at the end in the parent namespace of that file:
REGISTER_TENSORRT_PLUGIN(DecodePluginCreator);
And generated the libdecodeplugin.so again placed it inside deepstream app, And the error after this is mentioned here :
If this is of any help.
@y14uc339
There is maybe another option that you could build your plugin alongside with other existing plugins under <TensorRT_OSS_root>/plugin/ so that your plugin will be added into libnvinfer_plugin.so so that you may prevent dependency missing problems.
