set input to tensorflow frozen model before converting to TRT fails
The goal:
  1. convert a retrained ssd-inception-v2 tensorflow model to a TensorRT model.
  2. conversion and inference done on TX2
  3. training - laptop
I used the “ssd-inception-v2” model from tensorflow zoo, retrained it and now I wanted to convert to TRT.
The problem was that the converted model was not faster than the origin since the input dim is undefined (?, ?, ?, 3).
I tried to set the input size to a fixed size using the code below, but I get an error, as shown below.
Help is appreciated in what and how to change.
The error:
ValueError: node 'image_tensor' in input_map does not exist in graph (input_map entry: image_tensor:0->image_tensor:0)
The code:
with tf.gfile.GFile(frozen_graph_filename, "rb") as file_handle:
    graph_def = tf.GraphDef()
    graph_def.ParseFromString(file_handle.read())
new_input = tf.placeholder(dtype=tf.uint8, shape=[1, 320, 320, 3], name='image_tensor')
with tf.Graph().as_default() as frozen_graph:
    # tf.import_graph_def(graph_def, name='')  # <-- this works as expected
    tf.import_graph_def(graph_def, input_map={'image_tensor:0': new_input})
# convert to TRT:
model_out = ['detection_classes', 'num_detections', 'detection_boxes', 'detection_scores']
trt_graph = trt.create_inference_graph(
    input_graph_def=graph_def,
    outputs=model_out,
    max_batch_size=1,
    max_workspace_size_bytes=max_work_space,
    precision_mode=tensorRT_precision,
    is_dynamic_op=False)
Could you please share your script and model file so we can better help?
Also, provide details on the platforms you are using:
o Linux distro and version
o GPU type
o Nvidia driver version
o CUDA version
o CUDNN version
o Python version [if using python]
o Tensorflow and PyTorch version
o TensorRT version
SuniJB,
Details:
– Laptop:
– TX2:
  • jetpack 4.2.2
Both use:
  • python 3.6.8
  • tensorflow-gpu 1.14.0
  • tensorRT 5.1.5.0
The model is, as mentioned, ssd-mobilenetv2 (for object detection), as taken from the tensorflow zoo.
Retraining follows the tensorflow examples, and the conversion to tensorRT is as above.
if I run this:
new_input = tf.placeholder(dtype=tf.uint8, shape=[None, 320, 320, 3], name='image_tensor')
I get:
ValueError: NodeDef mentions attr 'shape' not in Op<name=Cast; signature=x:SrcT -> y:DstT; attr=SrcT:type; attr=DstT:type; attr=Truncate:bool,default=false>; NodeDef: {{node import/Cast}}. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.).
This is running on the laptop, same tf version (1.14.0)
Could you please try below code, it seems to be working:
frozen_graph_filename = "frozen_inference_graph.pb"
#with tf.Graph().as_default() as frozen_graph: <--- commented this code
Updated Input Layer:
op: "Placeholder"
attr {
  key: "dtype"
  value {
    type: DT_UINT8
attr {
  key: "shape"
  value {
    shape {
      dim {
      dim {
      dim {
      dim {
Was able to successfully generate TRT engine with default max_workspace_size_bytes and precision_mode:
TensorRT model is successfully stored!
numb. of trt_engine_nodes in TensorRT graph: 4
numb. of all_nodes in TensorRT graph: 6023
SunilJB,
Thanks for the support and for the effort but that didn’t work either (comment #4), but I was able to export the model to a frozen graph with the input dim set in another way. Inference seems to be as expected.
When I convert to TRT I get a new error:
convert to trt:
# convert to TRT:
    outputs=model_out,
    max_batch_size=1,
New error:
tensorflow.python.framework.errors_impl.InvalidArgumentError: NodeDef mentions attr 'shape' not in Op<name=Cast; signature=x:SrcT -> y:DstT; attr=SrcT:type; attr=DstT:type; attr=Truncate:bool,default=false>; NodeDef: {{node Cast}}. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.)
Does this indicate a mismatch between tensorflow versions on the laptop vs. TX2 or could it be something else too?
On the laptop I get:
Version: 1.14.0
On the TX2 I get:
Version: 1.14.0+nv19.10
After looking at the options through:
https://developer.download.nvidia.com/compute/redist/jp/v42/tensorflow-gpu/
I tried 1.14.0+nv19.7, 1.14.0+nv19.9 but I still get the same error.
To install on the TX2 I run:
sudo pip3 install --no-cache-dir --pre --extra-index-url https://developer.download.nvidia.com/compute/redist/jp/v42 tensorflow-gpu==1.14.0+nv19.10
Issue has been resolved!
I installed v1.14.0+nv19.10 on the TX2 and model was converted successfully and I could apply it too.
Not sure why this time the installation worked but the code above hasn’t changed.
Thanks for the effort SunilJB.
