I am trying to convert a Tensorflow MobileNet graph (*.pb file) into TensorRT via the TF-TRT module. However I get an error
`NotFoundError: No attr named 'shape' in NodeDef:`
I am running the following:
Jetson TX2
Jetpack 3.3
TensorRT 4.0.2.0-1+cuda9.0
tensorflow-gpu==1.9.0+nv18.8
Here is my code:
import tensorflow as tf
import tensorflow.contrib.tensorrt as trt
import numpy as np
import PIL
from timeit import default_timer as timer
from tqdm import tqdm
This script performs inference on a pure Tensorflow (TF) model vs a converted TensorRT model
In order to run it, it assumes you have a frozen TF graph in the form of a *.pb file.
The specific model is MobileNetv2
(https://github.com/tensorflow/models/tree/master/research/slim/nets/mobilenet(
Frozen graph can be downloaded from: https://storage.googleapis.com/mobilenet_v2/checkpoints/mobilenet_v2_1.4_224.tgz
The image file 'panda.jpg' is downloaded from:
https://upload.wikimedia.org/wikipedia/commons/f/fe/Giant_Panda_in_Beijing_Zoo_1.JPG
## File paths (needs to be set)
pb_path = "mobilenet_v2_1.0_224_frozen.pb" # frozen TF graph
input_name = 'input' # input layer of the graph
output_names = ['MobilenetV2/Predictions/Reshape_1'] # output layer of the graph. (Can be multiple)
img_path = 'data/panda.jpg' # image to perform inference on (from https://upload.wikimedia.org/wikipedia/commons/f/fe/Giant_Panda_in_Beijing_Zoo_1.JPG)
## Load image
img_raw = np.array(PIL.Image.open(img_path).resize((224, 224))).astype(np.float) / 128 - 1
img = img_raw.reshape(1, 224,224, 3)
##### Run w/ TensorRT
trt_graph = trt.create_inference_graph(
input_graph_def=frozen_graph,
outputs=output_names,
max_batch_size=1,
precision_mode='FP16', # 'INT8'/'FP16'
tf_config = tf.ConfigProto()
tf_config.gpu_options.allow_growth = True
tf_sess = tf.Session(config=tf_config)
tf.import_graph_def(trt_graph, name='')
tf_input = tf_sess.graph.get_tensor_by_name(input_name + ':0')
tf_output = tf_sess.graph.get_tensor_by_name(output_names[0] + ':0')
output = tf_sess.run(tf_output, feed_dict={tf_input: img + np.random.random(img.shape)/10})
And here is the full error trace:
2018-11-09 16:43:48.943803: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:864] ARM64 does not support NUMA - returning NUMA node zero
2018-11-09 16:43:48.943953: I tensorflow/core/grappler/devices.cc:51] Number of eligible GPUs (core count >= 8): 0
NotFoundError Traceback (most recent call last)
/home/nvidia/Projects/SANATA/trt_test.py in <module>()
71 outputs=output_names,
72 max_batch_size=1,
---> 73 precision_mode='FP16', # 'INT8'/'FP16'
74 )
75
/home/nvidia/Projects/SANATA/.venv/lib/python3.5/site-packages/tensorflow/contrib/tensorrt/python/trt_convert.py in create_inference_graph(input_graph_def, outputs, max_batch_size, max_workspace_size_bytes, precision_mode, minimum_segment_size)
113 # pylint: disable=protected-access
114 raise _impl._make_specific_exception(None, None, ";".join(msg[1:]),
--> 115 int(msg[0]))
116 # pylint: enable=protected-access
117 output_graph_def = graph_pb2.GraphDef()
[[Node: input = Placeholder[dtype=DT_FLOAT]()]] for 'input' (op: 'Placeholder') with input shapes:
Note, I get essentially the same error even when using the SSDLite graph from: http://download.tensorflow.org/models/object_detection/ssdlite_mobilenet_v2_coco_2018_05_09.tar.gz.
How can I fix this?
Thanks,
Roman
