I’m working on a research which includes setting a power limit for Nvidia GPU cards.
I can do it using nvidia-smi -pl XX
command or using NVML API from my custom build application.
By default one must call the command with power limiting as a superuser.
I wonder if there is any way of changing a GPU power limit while not being a superuser?
Is there e.g. some place in the system (some register or file) which stores the current limit value and it might be enough to just chown this directory as a regular user?
Or any other way which would not require becoming a superuser for the whole server.
Thanks in advance for your answers!
Best regards,
Adam
