Nvidia 750
driver version Linux 460.39 (latest today updated) it does have bug
Windows driver version 461.40 (latest today updated) it does have bug
I did not test it on other Nvidia GPU, but base on the first bug - this bug should work on every Nvidia GPU that supports Vulkan except RTX 2xxx and 3xxx
the bug is - that “shader noise generated by bug from not initialized variable react to outside activity”
(on everything from simple mouse moving to panels/menu popup on other window/OS UI or other app activity)
so this “bug” in theory can be used to detect “user activity outside window”
this bug similar to other my bug that already fixed, but it act 1:1 the same
repeating bug in Vulkan-Samples where shader code does not have any dynamic uniforms but the image still change by outside activity (if it uniform-leak then it leaks from other applications that use GPU)
minimal shader code:
void mainImage( out vec4 fragColor, in vec2 fragCoord )
fragColor-= fragColor; //not initialized variable
fragColor-= max(0., length(fragCoord/iResolution.xy)-.8 );
fragColor = sqrt(1.-fragColor);
minimal exe and linux build to test (warning its my own application, you may not trust this)
Bug required atleast one application that use same gpu as bug-noise shader, launch browser ot anything else on same Nvidia GPU where noise-shader launched (if you have multiple GPU setup and OS launched on other GPU)
bug screenshot from khronos Vulkan-Samples
Steps to launch this shader in Khronos example:
- clone and build github.com/KhronosGroup/Vulkan-Samples
- edit shader code Vulkan-Samples/shaders/texture_loading/texture.frag to this:
#version 450
/* Copyright (c) 2019, Sascha Willems
* SPDX-License-Identifier: Apache-2.0
* Licensed under the Apache License, Version 2.0 the "License";
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
layout (binding = 1) uniform sampler2D samplerColor;
layout (location = 0) in vec2 inUV;
layout (location = 1) in float inLodBias;
layout (location = 2) in vec3 inNormal;
layout (location = 3) in vec3 inViewVec;
layout (location = 4) in vec3 inLightVec;
layout (location = 0) out vec4 outFragColor;
fragColor-= max(0., length(fragCoord/vec2(512.))-.8 );
void main()
mainImage(outFragColor,inUV*vec2(512.));
- launch ./build/app/bin/x86_64/vulkan_samples --sample texture_loading
P.S. if someone launch my exe or Vulkan-Sample with this shader, please tell your result does this bug works for you or it is not, thanks.
