in my algorithm the threds of a block all operate on one specific element in shared memory. when they are all done the next element is loaded.
i have reduced my problem to the following code which stops with the message “incorrect use of __syncthreads()” in device emulation (after the first time __sync is reached in the loop). if i launch this code in normal mode my system crashes.
__global__ void f()
__shared__ int keep_going;
const int thread_id = threadIdx.y * blockDim.x + threadIdx.y;
if (thread_id == 0)
keep_going = 1;
__syncthreads();
while (keep_going != 0)
if (thread_id == 0)
keep_going = 0;
__syncthreads();
i know that you have to be careful using __sync inside of loops/branches but i don’t understand the problem here, since there is no way a thread does not reach the __sync.
I have tried the ways mentioned above but I always got keep_going=1.And also I didn’t met the complier error. It shows when all the threads reached the __syncthreads(), only the first thread is Valid .Why ? Confused!!
I haven’t tried this, but your problem is likely because you’re using a const for the thread_id variable. The compiler may be only setting it once from the first thread, hence why thread_id always looks like it’s zero.
I know this is an old thread but I had a similar problem so thought I’d reply.
