what 'incorrect use of __syncthreads()' means ?
Hi
What the error message ‘incorrect use of __syncthreads()’ means in reality ?
I have kernel that runs fine in hardware, but when run in device emulation mode
some blocks terminate early with ‘incorrect use of __syncthreads()’ message,
In what situations this message is triggered ?
I’m suspicious about this construct:
int device foobar()
shared someval;
if (threadIdx.x == 0)
// calculate someval
__syncthreads();
// early out from function
if (someval == 0)
return 0;
int reg_someval = someval;
for (i = 0; i < reg_someval; i++)
for (j = 0; …)
   __syncthreads();
      // merge values on thread 0 and write result to shared memory
  __syncthreads();
return result_from_shared_memory;
void global fooKernel()
int val = foobar();
if (val > 0)
// do something on all threads
// merge values from shared memory and write result to global memory
__syncthreads();
// do some other calculations
return;
how the ‘__syncthreads’ are realised in emulation mode ?
is the code above abuses ‘__syncthreads’ ? - all should be fine since all threads in
the block always follow that same execution path (they all take or not the branch).
__syncthreads() works only if ALL threads of the same block reach it,
ex:
if (val > 0)
__syncthreads();
it’s good only if val > 0 for the whole block.
and since val is from shared memory it is that same for whole block :), not a case here
interestingly if i’v put OutputDebugString around every __syncthreads in my kernel to see witch one triggers the message … suprise … the message is gone and all blocks finish now corectly in device emulation mode … what is going on ?
uuuh… well, I don’t know,
try to stop this annoying alert putting __syncthreads() out of the if(),
and if it’s needed you can replicate the if() statement:
if (val > 0)
__syncthreads();
if (val > 0)
that’s will only mask the problem, not kill its root ;)
so again question to nvidia ppl ‘when’ this message about __syncthreads is triggered ?
