hi,
does a shared memory read access from different threads to the same bank cause a bank conflict?
regards,
moik
hi,
regards,
moik
Yes. Unless all 16 threads are reading the same word.
Paulius
ok do i understand correctly:
16 is a half warp size and there couldnt be bank conflicts within the 2 warp halfs.
so is it right to say:
"you have only to avoid bank conflicts (r&w) within the threads 0-15, 16-31, 32-47, 48-63, … " ?
but im still a little bit confused about “…unless all 16 are reading the same word”. does this mean, if 15 and 1 not, there would be a conflict, but if all 16 there would be none?
moik
When all the 16 threads in an half warp read the same word, there is a broadcast mechanism.
ah great, thank u!
Yes, that’s correct.
Paulius
