Shared memory inconsistent results
I am trying to implement a shared memory optimization on a piece of code but I see inconsistent results.
In this code below I am looping on the z dimension for every XY plane in a block, iteratively loading values in the shared memory as i go up in Z.
Over the ex, ey and ez arrays updates, you can see commented out a global memory access to those same values previously loaded into shared memory. Well, that works perfectly.
The problem arises when I use shared memory. I get completely different results at every run.
All the compute sanitizer checks return 0 error/warning/info.
The shared arrays should hold the same exact values as those in gblbal memory, but they do not.
Also, I noted that using less than 4 of these shared arrays does not produce erroneous results (in release mode). Any combination.
At this point I am not even sure how to debug this.
Any help is super appreciated.
#include<stdio.h>
#include "constantsGPU.h"
#define assert( X , i, j, k, str) if ( !(X)) { printf("%s failed at %d, %d, %d \n", str, i, j, k ); return; }
#define BLOCKSIZE 16
__global__ void EStepPMLNew( float* ex, float* ey, float* ez,
	float* hx,float* hy, float* hz,
	bool dbg)
	int bx = blockIdx.x;
	int by = blockIdx.y;
	int tx = threadIdx.x;
	int ty = threadIdx.y;
	int i = bx*blockDim.x + tx;
	int j = by*blockDim.y + ty;
	int index = i + j*wE;
	__shared__ float  currHx[BLOCKSIZE+1][BLOCKSIZE+1];
	__shared__ float  currHy[BLOCKSIZE+1][BLOCKSIZE+1];
	__shared__ float  currHz[BLOCKSIZE+1][BLOCKSIZE+1];
	__shared__ float aboveHx[BLOCKSIZE][BLOCKSIZE];
	__shared__ float aboveHy[BLOCKSIZE][BLOCKSIZE];
	if(i < Nx && j < Ny){
	// load the first plane of H
		currHx[tx][ty] = hx[i+j*wHx];
		currHy[tx][ty] = hy[i+j*wHy];
		currHz[tx][ty] = hz[i+j*wHz];
		if(tx == BLOCKSIZE-1){
			currHy[tx+1][ty] = hy[i+1+j*wHy];
			currHz[tx+1][ty] = hz[i+1+j*wHz];
		if(ty == BLOCKSIZE-1){
			currHx[tx][ty+1] = hx[i+(j+1)*wHx];
			currHz[tx][ty+1] = hz[i+(j+1)*wHz];
	__syncthreads();
	for(int z = 0; z < Nz; z++){
		if (i < Nx && j < Ny) {
			aboveHx[tx][ty] = hx[i+j*wHx+(z+1)*whHx];
			aboveHy[tx][ty] = hy[i+j*wHy+(z+1)*whHy];
		__syncthreads();
			// assert shared memory is correct
			int k = z;
			// ex[index + z*whE] -= d_dtmu*(d_invdZ*(hy[i+j*wHy+(k+1)*whHy]-hy[i+j*wHy+k*whHy])
			// 	-d_invdY*(hz[i+(j+1)*wHz+k*whHz]-hz[i+j*wHz+k*whHz]));
			ex[index + z*whE] -= d_dtmu*(d_invdZ*(aboveHy[tx][ty]-currHy[tx][ty])
				-d_invdY*(currHz[tx][ty+1]-currHz[tx][ty]));
			// ey[index + z*whE] -= d_dtmu*(d_invdX*(hz[i+1+j*wHz+k*whHz]-hz[i+j*wHz+k*whHz])
			// 	-d_invdZ*(hx[i+j*wHx+(k+1)*whHx]-hx[i+j*wHx+k*whHx]));
			ey[index + z*whE] -= d_dtmu*(d_invdX*(currHz[tx+1][ty]-currHz[tx][ty])
				-d_invdZ*(aboveHx[tx][ty]-currHx[tx][ty]));
			// ez[index + z*whE] -= d_dtmu*(d_invdY*(hx[i+(j+1)*wHx+k*whHx]-hx[i+j*wHx+k*whHx])
			// 	-d_invdX*(hy[i+1+j*wHy+k*whHy]-hy[i+j*wHy+k*whHy]));
			ez[index + z*whE] -= d_dtmu*(d_invdY*(currHx[tx][ty+1]-currHx[tx][ty])
				-d_invdX*(currHy[tx+1][ty]-currHy[tx][ty]));
		__syncthreads();
			if (z < Nz-1) {
					currHy[tx+1][ty] = hy[i+1+j*wHy+(z+1)*whHy];
					currHz[tx+1][ty] = hz[i+1+j*wHz+(z+1)*whHz];
					currHx[tx][ty+1] = hx[i+(j+1)*wHx+(z+1)*whHx];
					currHz[tx][ty+1] = hz[i+(j+1)*wHz+(z+1)*whHz];
				currHx[tx][ty] = aboveHx[tx][ty];
				currHy[tx][ty] = aboveHy[tx][ty];
				currHz[tx][ty] = hz[i+j*wHz+(z+1)*whHz];
		__syncthreads();
Pick a value that ends up wrong. Put in-kernel printf at various points in your code that display the various values used in calculating that value. To avoid getting overwhelmed with print-out data, only print the components for a single value, e.g. for/from a single thread, using conditional checks before printing, based on block indices and thread indices. If it helps, reduce the problem size to the smallest that still shows calculation errors.
You can also do something similar with cuda-gdb. Session 12 of this online tutorial gives enough information to train you to be able to do that. It basically requires knowledge of how to set breakpoints, how to step through code, and how to inspect data, all of which is covered there.
Thank you. I was already doing it but reducing it to one single thread helped me find the issue. Thanks again
