Question on Shared Memory access by multiple threads
I am using shared memory (a_smem and b_smem) in my CUDA kernel to perform a simple difference operation over 19 elements.
My kernel is launched with 608 threads per block to copy data i.e 24 bytes per thread, but only 192 threads participate in the differnece computation.
Given fixed input vectors (aIn and bIn), I expect the output to be consistent. However, I observe random variations in the results across different runs.
each thread accesses a different 32-bit memory location at a time. I would appreciate if anyone could throw insights about his random behaviour.
Thank you
global void Kernel()
__shared__ int16_t a_smem[384 * 19];
__shared__ int16_t b_smem[384 * 19];
uint32_t chunk_len = 384;
uint64_t a_reg[3];
uint64_t b_reg[3];
int32_t *a_reg_ptr = (int32_t *)a_reg;
int32_t *b_reg_ptr = (int32_t *)b_reg;
uint32_t tidx = threadIdx.x; // 0 to 607
uint32_t col = tidx / 32;    // 0 to 18 max
uint32_t idx = (tidx % 32) * 12; // 0 to 372
int16_t * aptr = &aIn[col * chunk_len];
// one warp copies 32*24 bytes
uint64_t *p1 = reinterpret_cast<uint64_t *>(&aptr[idx]);
a_reg[0] = *p1++;
a_reg[1] = *p1++;
a_reg[2] = *p1;
int16_t * bptr = &bIn[col * chunk_len];
uint64_t *p2 = reinterpret_cast<uint64_t *>(&bptr[idx]);
b_reg[0] = *p1++;
b_reg[1] = *p1++;
b_reg[2] = *p1;
int32_t *a_smem_ptr = (int32_t *)&a_smem[(col * chunk_len) + idx];
for (int x = 0; x < 6; x++)
  a_smem_ptr[x] = a_reg_ptr[x];
int32_t *b_smem_ptr = (int32_t *)&b_smem[(col * chunk_len) + idx];
  b_smem_ptr[x] = b_reg_ptr[x];
__syncthreads();
if(tidx < chunk_len/2) //192 threads
  for (uint32_t ind = 0; ind < 19; col_ind++)
	int32_t *ptr_a = (int32_t *)&a_smem[ind * chunk_len];
	int32_t *ptr_b = (int32_t *)&b_smem[ind * chunk_len];
	// Saturating Subtraction
	int32_t a = ptr_a[tidx];
	int16_t a0 = a & 0xFFFF;
	int16_t a1 = (a >> 16) & 0xFFFF;
	int32_t b = ptr_b[tidx];
	int16_t b0 = b & 0xFFFF;
	int16_t b1 = (b >> 16) & 0xFFFF;
	int16_t sub_val0 = b0 - a0;
	int16_t sub_val1 = b1 - a1;
	// store updates
	int32_t tmp = (sub_val1 << 16);
	tmp = tmp & 0xFFFF0000;
	tmp = tmp | (sub_val0  & 0xFFFF);
	ptr_b[tidx] = tmp;
  b_reg_ptr[x] = b_smem_ptr[x];
uint64_t *p3 = reinterpret_cast<uint64_t *>(&bptr[z_idx]);
*p3++ = b_reg[0];
*p3++ = b_reg[1];
*p3 = b_reg[2];
Please provide a minimal complete reproducer code.
Have you tried printing the values at different stages in the code over different runs to find out where there are differences?
Does compute-sanitizer report any warnings regarding data races?
You probably need __syncthreads again after the difference operation.
Loads and stores on the GPU data must be naturally aligned. Converting an int16_t* into an uint64_t*can easily lead to a violation of that restriction. The data delivered by an unaligned load is indeterminate.
Dereferencing a pointer after a reinterpret_cast from one pointer type to a different pointer type may result in undefined behavior; consult the C++ standard to check the validity of this construct.
What are you trying to accomplish here? I would suggest first trying to make the code functional without trickery.
I had bug in the code while handling number of chunks. Thank you again for all your support.
