Shared memory & sync, changes not visible
Two things…
First, why was this thread locked: http://forums.nvidia.com/index.php?showtopic=156615 ?
(and worse, without any reason/notification - very unprofessional and suspicious)
Second, I’m experiencing similar issues to the thread I linked above.
I have a kernel with a single block, 256 threads (8 warps). In this kernel I have a small segment of code similar to the following:
[codebox]…
shared float3 var;
if(threadIdx.x == blah)
var = some_value;
__syncthreads();
// At this point in the code, no other threads except the writing thread (threadIdx.x == blah) can see that var = some_value, not even threads in the same warp as the writing thread.[/codebox]
This appears to be a compiler bug of sorts, as I’ve failed to reproduce this test case multiple times on CUDA 2.3 or the Nexus alpha SDKs in a smaller kernel.
My main question really, is asking for advice on how to best diagnose/nail down the cause of the bug (I’m not overly familiar with ptx, and disassembling this kernel results in hundreds of thousands of lines of ptx, a few mb of text)…
Any advice would be greatly appreciated.
good question as to why that thread was locked, I have no idea. it was probably an accident. anyway, it’s unlocked now.
anyway yeah this looks like a compiler bug–can you post a repro case that fails on the 3.0 beta toolkit?
What type is “some_value”?
some_value’s type is a data structure (EuclideanTransform3f - see below)
[codebox]struct float3x3
float3 rows[3];
__device__ void operator=(const float3x3 &b)
	rows[0] = b.rows[0];
	rows[1] = b.rows[1];
	rows[2] = b.rows[2];
struct align(16) EuclideanTransform3f
float3x3 R;
float3 T;
__device__ void operator=(const EuclideanTransform3f &b)
	R = b.R;
	T = b.T;
};[/codebox]
Update: I just tested with various other types (float2/3/4) - they all exhibit the same problem.
Looking into a repro case (I’ve tried this before though, with little/no success - I suspect the size of my kernel is somehow making the compiler a bit crazy, that said it’s a fairly straight forward kernel)
