Hi I have a piece of code where each thread writes to it’s own shared memory location. Afterwards I perform a __syncthreads(); and then read shared memory (also from the neighbours). Unfortunately one thread gets different values as another threads, even though the element read should be the same. The code follows:
__global__ void facet_kernel (unsigned int blocks_offset, int2 g_blocklist){
__shared__ int s_block_x, s_block_y;
__shared__ unsigned int s_facet_hit[16*16];
unsigned int tid = threadIdx.x + threadIdx.y * 16;
if (tid==0) {
int2 number = g_blocklist[blockIdx.x + blocks_offset];
s_block_x = number.x;
s_block_y = number.y;
// s_facet_hit[tid] = 0; // normally we do not hit a facet
s_facet_hit[tid] = tid; // For debugging purposes
__syncthreads();
unsigned int reflection_plane;
bool found_reflection = false;
// CODE TO FIND REFLECTIONS
// SKIPPED IT HERE
if (found_reflection) {
s_facet_hit[tid] = reflection_plane + 1;
__syncthreads();
// Write thread indices of a 3x3 block around the current thread (on the right some extra debugging output)
if ((s_block_x==-2) && (s_block_y==-44) && (tid==136)) {
unsigned int index = atomicInc(d_debug_offset, gridDim.x*14*14);
d_debug[index] = make_float4((float) tid-17, \
(float) tid-16, \
(float) tid-15, \
(float) s_facet_hit[tid+16]);
unsigned int index_1 = atomicInc(d_debug_offset, gridDim.x*14*14);
d_debug[index_1] = make_float4((float) tid-1, \
(float) tid, \
(float) tid+1, \
unsigned int index_2 = atomicInc(d_debug_offset, gridDim.x*14*14);
d_debug[index_2] = make_float4((float) tid+15, \
(float) tid+16, \
(float) tid+17, \
// Write the values in shared memory of a 3x3 block around the current thread (on the right some extra debugging output)
d_debug[index] = make_float4((float) s_facet_hit[tid-17], \
(float) s_facet_hit[tid-16], \
(float) s_facet_hit[tid-15], \
d_debug[index_1] = make_float4((float) s_facet_hit[tid-1], \
(float) s_facet_hit[tid], \
(float) s_facet_hit[tid+1], \
(float) s_facet_hit[tid+32]);
d_debug[index_2] = make_float4((float) s_facet_hit[tid+15], \
(float) s_facet_hit[tid+16], \
(float) s_facet_hit[tid+17], \
(float) s_facet_hit[tid+33]);
Blocksize is 16x16, so tid has the value:
0 1 ... 14 15
16 .. 31
240 .... 255
Output is
tid==136
135.0000 136.0000 137.0000 4.0000
151.0000 152.0000 153.0000 4.0000
167.0000 168.0000 169.0000 4.0000
151.0000 4.0000 153.0000 4.0000
167.0000 4.0000 4.0000 4.0000
tid == 152
119.0000 120.0000 121.0000 152.0000
135.0000 136.0000 137.0000 152.0000
151.0000 152.0000 153.0000 152.0000
135.0000 136.0000 137.0000 168.0000
151.0000 152.0000 153.0000 169.0000
As you can see, in the case for tid==152, the value at index 152 remains unchanged (152), whereas for tid==136, the value is overwritten with 4 (reflection_plane==3)
Given the __syncthreads(); just before the code where debugging-output is extracted, this seems to me like a CUDA bug.
On XP64:
Driver 185.85
nvcc --version
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2009 NVIDIA Corporation
Built on Sat_May__2_05:54:12_PDT_2009
Cuda compilation tools, release 2.2, V0.2.1221
Has the bug. Upgrading XP64 to the latest toolkit & driver fixes the problem. Linux64 with the latest toolkit & driver is also correctly functioning. Was there a bug with __syncthreads() fixed between 2.2 and 2.3???
P.S. I cannot change the topic-name unfortunately
