__shfl_down_sync weird behavior
I am trying to accelerate my reduce kernel using warp shuffle.
When the array size is a multiple of 32,the code works well. When it comes to general cases, I need to check the boundary condition. I made my test case as below:
the input_data length is 10, using a block length = 1024, so only partial threads (10) of the first warp will participate in the shuffle.
        for (size_t i = 16; i > 0; i = i >> 1) {
            if ((i + laneIdx) < count1) {
                printf("delta= %d, threadx = %d, thread_sum = %f\n", i, threadIdx.x, thread_sum);
                thread_sum = CudaReduceOperate<T, reduce_type>(thread_sum, __shfl_down_sync(mask, thread_sum, i));
count1 is calculated as the number of active thread in the wap and in the case, count1 == 10. In my view, when the delta = 16, no threads would do the reduction op. delta = 8, the thread 0 and 1 would do the reduction op…etc.
However, I find them all equals to 0 in the outputs. Here are the complete code and outputs:
const int kBlockDimReduce = 1024;
template <typename T, ReduceType reduce_type>
static inline __device__ auto CudaReduceOperate(T in1, T in2) -> enable_if_t<reduce_type == ReduceType::kSum, T> {
    return in1 + in2;
static inline __device__ auto CudaReduceOperate(T in1, T in2) -> enable_if_t<reduce_type == ReduceType::kMax, T> {
    return in1 > in2 ? in1 : in2;
static inline __device__ auto CudaReduceOperate(T in1, T in2) -> enable_if_t<reduce_type == ReduceType::kMin, T> {
    return in1 > in2 ? in2 : in1;
static inline __device__ auto CudaReduceAtomicOperate(T *addr, T value)
    -> enable_if_t<reduce_type == ReduceType::kSum, void> {
    atomicAdd(addr, value);
    -> enable_if_t<reduce_type == ReduceType::kMax, void> {
    atomicMax(addr, value);
    -> enable_if_t<reduce_type == ReduceType::kMin, void> {
    atomicMin(addr, value);
__forceinline__ __device__ T warpReduce(unsigned int mask, T localSum) {
#pragma unroll
        localSum = CudaReduceOperate<T, reduce_type>(__shfl_down_sync(mask, localSum, i), localSum);
        printf("fullwarp round = %d threadx = %d, local = %f\n", i, threadIdx.x, localSum);
    return localSum;
__global__ void CudaReduceKernel(void *input_data, int length, void *output_data) {
    __shared__ T sdata[kBlockDimReduce];
    int idx = 8 * blockIdx.x * blockDim.x + threadIdx.x;
    // shuffle init (must be done first, otherwise the maskWindUp won't take effect)
    const int laneIdx = threadIdx.x % 32;
    const int warpIdx = threadIdx.x / 32;
    unsigned int maskLength;
    __shared__ unsigned int maskWindUp;
    bool is_full_warp = false;
    int remain_data = length - (8 * blockIdx.x * blockDim.x + 32 * (warpIdx + 1));
    if (remain_data >= 0) {
        maskLength = 31;  // 31 = warpSize-1
        is_full_warp = true;
        maskWindUp |= (1 << warpIdx);
    } else {
        if (remain_data > -32) {
            maskLength = 32 + remain_data;
        } else {
            maskLength = 0;
            // this warp is invalid
            maskWindUp &= ~(1 << warpIdx);
    printf("threadx = %d, remain_data = %d, maskWindUp = %d\n", threadIdx.x, remain_data, maskWindUp);
    if (idx >= length) {
        return;
    sdata[threadIdx.x] = static_cast<T *>(input_data)[idx];
    // unrolling 8
    if (idx + 7 * blockDim.x < length) {
#pragma unroll
        for (int i = 1; i < 8; i++) {
            sdata[threadIdx.x] = CudaReduceOperate<T, reduce_type>(sdata[threadIdx.x],
        static_cast<T *>(input_data)[idx + i * blockDim.x]);
    } else {
        // the last block (boundary condition)
        const int remain_data = length - 8 * blockIdx.x * blockDim.x;
        const int n_unrolling_need = (remain_data + blockDim.x - 1) / blockDim.x;
#pragma unroll
        for (size_t i = 1; i < n_unrolling_need; i++) {
            if (idx + i * blockDim.x < length) {
                    sdata[threadIdx.x], static_cast<T *>(input_data)[idx + i * blockDim.x]);
    __syncthreads();
    // shuffle inside warp
    maskLength = maskLength & length;
    maskLength = (maskLength > 0) ? (32 - maskLength) : maskLength;
    const unsigned int mask = (0xffffffff) >> maskLength;
    maskWindUp = 1;
    printf("mask --> %d maskWindUp -->%d\n", mask, maskWindUp);
    __shared__ T warps_sum[32];
    T thread_sum = sdata[threadIdx.x];
    __syncthreads();
    printf("reduce result before %f, laneID = %d\n", thread_sum, laneIdx);
    // 1. warp shuffle
    if (is_full_warp) {
        thread_sum = warpReduce<T, reduce_type>(mask, thread_sum);
    } else {
        int count1 = 0;
        unsigned int value = mask;
        while (value) {
            value &= value - 1;
            count1++;
        printf("threadx = %d, count1 = %d, laneID = %d\n", threadIdx.x, count1, laneIdx);
    printf("threadx = %d, reduce result %f\n", threadIdx.x, thread_sum);
    if (threadIdx.x == 0) {
        CudaReduceAtomicOperate<T, reduce_type>(static_cast<T *>(output_data), thread_sum);
    return;
template <DataType data_type, ReduceType reduce_type>
void CudaReduce(void *input_data, int length, void *output_data, cudaStream_t stream) {
#if __CUDA_ARCH__ < 700
    static_assert(data_type != DataType::kHalf, "CudaReduce does not support kHalf with __CUDA_ARCH__ < 700");
#endif
    // forbid call for kInt8 kSum
    static_assert(data_type != DataType::kInt8 || reduce_type != ReduceType::kSum,
                  "CudaReduce does not support sum of int8");
    dim3 block(cudaop_constant::kBlockDimReduce);
    const int gridsize = (length + 8 * block.x - 1) / (8 * block.x);
    dim3 grid(gridsize);
    // std::cout << "gridsize " << gridsize << "length " << length << std::endl;
    CudaReduceKernel<typename DataTypeTraits<data_type>::Type, reduce_type>
        <<<grid, block, 0, stream>>>(input_data, length, output_data);
the output is:
reduce result before 0.333333, laneID = 0
reduce result before 0.247059, laneID = 1
reduce result before 0.600000, laneID = 2
reduce result before 0.658824, laneID = 3
reduce result before 0.992157, laneID = 4
reduce result before 0.760784, laneID = 5
reduce result before 0.368627, laneID = 6
reduce result before 0.156863, laneID = 7
reduce result before 0.509804, laneID = 8
reduce result before 0.635294, laneID = 9
threadx = 0, count1 = 10, laneID = 0
threadx = 1, count1 = 10, laneID = 1
threadx = 2, count1 = 10, laneID = 2
threadx = 3, count1 = 10, laneID = 3
threadx = 4, count1 = 10, laneID = 4
threadx = 5, count1 = 10, laneID = 5
threadx = 6, count1 = 10, laneID = 6
threadx = 7, count1 = 10, laneID = 7
threadx = 8, count1 = 10, laneID = 8
threadx = 9, count1 = 10, laneID = 9
income round = 8 threadx = 0, thread_sum = 0.000000
income round = 4 threadx = 0, thread_sum = 0.000000
income round = 2 threadx = 0, thread_sum = 0.000000
income round = 1 threadx = 0, thread_sum = 0.000000
threadx = 9, reduce result 0.635294
threadx = 8, reduce result 0.000000
threadx = 6, reduce result 0.000000
threadx = 7, reduce result 0.000000
threadx = 2, reduce result 0.000000
threadx = 3, reduce result 0.000000
threadx = 4, reduce result 0.000000
threadx = 5, reduce result 0.000000
threadx = 0, reduce result 0.000000
threadx = 1, reduce result 0.000000
all the thread_sum == 0 after the reduce, which is weird. Moreover, the printf seems to work abnormal near the shuffle.
Thanks in advance for the reply!
Shared variables are uninitialized. You have to initialize maskWindUp before using it.
The shuffle mask is probably incorrect. Did you verify that only the threads for which the surrounding if is true are present in the mask of the shuffle call ?
Thanks for the reminder. However in this case, maskWindUp has nothing to do with the shuffle. It was designed to mark which warps are valid after the shuffle. The first warp would do a “wind up” afterwards. Since in this case, only the first warp takes effect, this mask will not be used.
The second question: yes, I identified them throught the printf, there are exactly 10 threads in the shuffle call, which is marked as true in the mask.
My problem is, the thread sum become 0 after shuffle, which should be at least one of the input data, but actually not.
I think there are less than 10 threads executing the shuffle call, and a different number of threads in each iteration.
count1 is 10. For i = 16, no threads will shuffle. For i = 8, only laneIdx 0 and 1 will shuffle. This will require the mask 0x11 instead of 0x1111111111.
I see, I will give it a try. Thanks a lot!
For sake of completeness, there are also simpler ways to achieve your goal.
  1. Always use a full warp, pad out-of-bounds elements with the neutral element, i.e. 0 for sum reduction. (thread 0-9 contribute values of the array, thread 10-31 contribute 0)
  2. Use cooperative groups API for reduction
if(is_full_warp){
  auto group = cg::tiled_partition<32>(cg::this_thread_block());
  thread_sum = cg::reduce(group, thread_sum, cg::plus<int>());
}else{
  if(lane < count1){
    auto group = cg::coalesced_group();
  1. Use a library like Thrust or CUB.
