I was planning to buy several tesla cards as NVIDIA’s mad science offer seemed to be promising Fermi cards for the price difference but this is not the case.
So I’m left with the option of Tesla C1060 cards for £620 each
OR GTX295 cards for £330 each
I’m using them for CUDA programming of large neural networks and real time visual feature extraction so I don’t care about gaming performance or graphics output.
I can see that the Tesla has double the memory and the GTX has double the cores (split into 2 devices).
I’m looking for the fastest option which would seem to be the GTX, I hope there is enough memory there?
I could even mix and match, 2 tesla and 2 gtx in one machine?
To some extent it depends on your application (i.e. how much RAM you need) and who’s paying for your hardware. If it’s someone else get the Tesla’s and take advantage of the Fermi offer.
I’ll just repeat what everyone else said. Some applications are able to crunch large data sets on GPUs with a small amount of memory because they can break the data up and process it in chunks; some can’t, and so they need the larger memory available from a Quadro or Tesla card because all of the data has to fit into the GPU’s memory at once.
So if you can break up the data, go with the GTX295. If not, go with the Tesla (or a Quadro, if you want the video output).
This is correct only if your 4GB of Tesla RAM is enough :) if its not enough, you’ll have to chunk things even on a Tesla…
Unfortunatly for me I have to do it all the time (and 6GB RAM will not be enough either, as a matter of fact a 72GB of CPU RAM isn’t enough either ) :)
Go 4 Tesla ONLY IF you need that extra memory. TESLA is enterprise grade - more thoroughly tested and has ECC for memories, I believe.
Also I hope GTX 295 has the enhanced memory coalescing capability that TESLA series have. And, I hope they support “doubles” as well.
You may need to check the compute capability of both these cards. TESLA is 1.3 and supports “doubles” as well. What is the compute capability of GTX 295? If it is 1.3, it should be good enough.
If you dont need any of these features (now and in future), GTX 295 is the best option. They run faster than TESLA (more clock speed for shaders and memory) and they are priced less.
Thanks everyone, I’ve gone for tesla’s for now as I do need quite a bit of memory for some applications. I’ll be buying more later I think but I’m going to wait for fermi and see what the options are then…
