As the ptx reference says, data in the .param section would be available only after a load to register command( ld.param ). Considering I use a param in the main loop in my program, and I am seriously concerned about how many register is being used, in this case, does the ld.param operation consume a register physically?
PS: If a register must be used when ld.param is called, is there any other method to help me saving register use? Thanks!
You don’t need to estimate register usage at all. The -v flag to ptxas (or the --ptxas-options=-v flag to nvcc) will print out the final number of registers used per thread after register allocation has been performed.
