I am trying to optimize my 1D convolution kernel, code below.
template <int InputChannels, int InputLength, int Padding, int KernelSize, int ChannelsPerThread>
__global__ void conv1d(float *d_input, float *d_weight, float *d_bias, float *d_output)
//define constants
constexpr int SharedMemLength = constexpr_max(InputLength, KernelSize);
const int blockId = blockIdx.x;
const int tdIdx = threadIdx.x;
const int laneIdx = threadIdx.x % warpSize;
const int warpIdx = threadIdx.x / warpSize;
const int input_accesses_per_thread = (InputChannels * InputLength)/(4 * blockDim.x);
const int weight_accesses_per_thread = (InputChannels * KernelSize)/(blockDim.x);
const int weight_offset = blockId * InputChannels * KernelSize;
const int padded_input_length = InputLength + Padding * 2;
//static mem allocations
float regInput[padded_input_length*ChannelsPerThread] = {0};
float regFilter[KernelSize*ChannelsPerThread];
__shared__ float shared_mem[InputChannels * SharedMemLength];
//load input from global memory into shared memory
for (int channelIndex = 0; channelIndex < input_accesses_per_thread; ++channelIndex){
int td_offset = 4 * (channelIndex * blockDim.x + tdIdx);
int smem_offset = td_offset/32;
float4 data = *reinterpret_cast<float4*>(&d_input[td_offset]);
shared_mem[td_offset + smem_offset + 0] = data.x;
shared_mem[td_offset + smem_offset + 1] = data.y;
shared_mem[td_offset + smem_offset + 2] = data.z;
shared_mem[td_offset + smem_offset + 3] = data.w;
__syncthreads();
//load input from shared memory into thread registers
for (int channelIndex = 0; channelIndex < ChannelsPerThread; ++channelIndex){
for (int colIndex = 0; colIndex < InputLength; ++colIndex){
int regIndex = Padding + channelIndex * padded_input_length + colIndex;
int sharedMemIndex = InputLength * (ChannelsPerThread * tdIdx + channelIndex) + colIndex;
int smem_offset = sharedMemIndex/32;
regInput[regIndex] = shared_mem[sharedMemIndex + smem_offset];
__syncthreads();
//load weights from global memory into shared memory
for (int channelIndex = 0; channelIndex < weight_accesses_per_thread; ++channelIndex){
int td_offset = (channelIndex * blockDim.x) + tdIdx;
shared_mem[td_offset] = d_weight[td_offset + weight_offset];
__syncthreads();
//load weights from shared memory to thread registers
for (int colIdx = 0; colIdx < KernelSize; ++colIdx){
int regIndex = channelIndex * KernelSize + colIdx;
int sharedMemIndex = KernelSize * (ChannelsPerThread * tdIdx + channelIndex) + colIdx;
regFilter[regIndex] = shared_mem[sharedMemIndex];
//outer loop iterates over each element in output vector
#pragma unroll
for (int tileIdx = 0; tileIdx < InputLength; ++tileIdx){
float res = 0.0;
//inner loop performs dot product over all kernel positions and accumulates results
for(int dotIdx = 0; dotIdx < KernelSize; ++dotIdx){
for(int channelIndex = 0; channelIndex < ChannelsPerThread; ++channelIndex){
res += regInput[tileIdx + dotIdx + (channelIndex * padded_input_length)] * regFilter[dotIdx + (channelIndex * KernelSize)];
shared_mem[tdIdx] = res;
__syncthreads();
if (threadIdx.x < 128){
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 128];
__syncthreads();
if (threadIdx.x < 64){
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 64];
__syncthreads();
if (threadIdx.x < 32){
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 32];
__syncwarp();
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 16];
__syncwarp();
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 8];
__syncwarp();
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 4];
__syncwarp();
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 2];
__syncwarp();
shared_mem[threadIdx.x] += shared_mem[threadIdx.x + 1];
__syncwarp();
if (threadIdx.x == 0){
d_output[blockId * InputLength + tileIdx] = shared_mem[0] + d_bias[blockId];
__syncthreads();
When I run this with ChannelPerThread = 8, 1024 blocks, and 256 threads per block, I end up with near peak global memory bandwidth during the loading step (~700 GB/s on my RTX 3090).
When I run the same code with ChannelsPerThread=2, 1024 blocks, and 1024 threads per block, I get significantly lower bandwidth (~330 GB/s)! The kernel with 256 threads actually has lower theoretical occupancy (~33%) than the one with higher thread count due to register pressure. I was under the impression that what impacts GMEM bandwidth is coalescing accesses/vectorized loads. Why does having more threads loading fewer elements (with accesses still coalesced) result in so much lower bandwidth than fewer threads performing more loads? I’ve included ncurep files here in case anyone sees anything interesting there - Conv1D Profiles - Google Drive
