I have the simple code:
call initialize_flow
!$acc enter data copyin(v_flow_r,v_flow_t,v_flow_p)
where the three arrays are contained in an included module, and the called routine allocates them and initializes their values on the CPU. These arrays are not created/copied anywhere else of the GPU.
The code compiles fine, but when I run it I get:
FATAL ERROR: variable in data clause is partially present on the device: name=v_flow_t
If I run the code using PGI 17.10 (and I think 18.1,18.3) it also works fine.
I also tried creating the arrays in the routine itself but it still fails.
I put the debug flags on and got:
pgi_uacc_dataenterstart( file=/home/sumseq/Dropbox/PSI/MAS/MAS_SVN/branches/mas_openacc/mas_sed_expmac.f, function=start, line=4771:4771, line=5255, devid=0 )
pgi_uacc_dataon(hostptr=0x4fcb190,stride=1,267,size=267x246,eltsize=8,lineno=5255,name=v_flow_r,flags=0x20700=present+create+copyin+dynamic,async=-1,threadid=1)
pgi_uacc_alloc(size=525456,devid=1,threadid=1)
allocate device memory 0x7f1c1af3da00(525824B)
pgi_uacc_alloc(size=525456,devid=1,threadid=1) returns 0x7f1c1af3da00
map dev:0x7f1c1af3da00 host:0x4fcb190 dindex:1 size:525456 offset:0 (line:5255 name:v_flow_r) thread:1
alloc done with devptr at 0x7f1c1af3da00
pgi_uacc_alloc(size=96,devid=1,threadid=1)
recycle device memory 0x7f1ea5c07200(512B)
pgi_uacc_alloc(size=96,devid=1,threadid=1) returns 0x7f1ea5c07200
map dev:0x7f1ea5c07200 host:0x10f67b0 dindex:1 size:96 offset:0 (line:5255 name:descriptor) thread:1
alloc done with devptr at 0x7f1ea5c07200
pgi_uacc_dataupx(devptr=0x7f1ea5c07200,hostptr=0x10f67b0,eltsize=96,lineno=5255,name=descriptor,async=-1,threadid=1)
pgi_uacc_cuda_dataup1(devdst=0x7f1ea5c07200,hostsrc=0x10f67b0,offset=0,stride=1,size=1,eltsize=96,lineno=5255,name=descriptor,thread=1)
pgi_uacc_dataupx(devptr=0x7f1c1af3da00,hostptr=0x4fcb190,stride=1,size=65682,eltsize=8,lineno=5255,name=v_flow_r,async=-1,threadid=1)
pgi_uacc_cuda_dataup1(devdst=0x7f1c1af3da00,hostsrc=0x4fcb190,offset=0,stride=1,size=65682,eltsize=8,lineno=5255,name=v_flow_r,thread=1)
pgi_uacc_dataon(hostptr=0x53df480,stride=1,266,size=266x246,eltsize=8,lineno=5255,name=v_flow_t,flags=0x20700=present+create+copyin+dynamic,async=-1,threadid=1)
v_flow_t lives at 0x53df480 size 523488 partially present
It seems to have copied the v_flow_r fine but fails on the v_flow_t which is bizarre.
I tried putting these copies on separate lines and it still does the same thing.
This is a pretty big snag since 18.4 is the community edition…
Any Ideas?
- Ron
