Hi.
I tryed to compile this simple program but it does not work.
It seems there are missing files.
How can i fix it ?
I use Ubuntu 11.10
alechand@pcsantos2:~/test_acc$ more te.f90
program te
double precision x
integer i
do i=1,5
write(,) i
enddo
end program te
alechand@pcsantos2:~/test_acc$ pgfortran -o gg te.f90
NOTE: your trial license will expire in 14 days, 7.49 hours.
/usr/bin/ld: cannot find /usr/lib/crt1.o: No such file or directory
/usr/bin/ld: cannot find /usr/lib/crti.o: No such file or directory
It appears that the compilers did not get installed correctly most likely due to missing system development packages. Ubuntu doesn’t always install development tools by default, so you may need install the “build essentials” packages (https://help.ubuntu.com/community/CompilingEasyHowTo)
sudo apt-get install build-essential checkinstall
You may need to also install the 32-bit compatibility packages:
Hi, i am here again…
Now this is the message.
I think i cannot use it in ubuntu 12.05, right ?
Can i install an older version of gcc ?
alechand@pcsantos2:~/test_acc$ pgfortran -acc -o gg dn.f90
NOTE: your trial license will expire in 13 days, 21.5 hours.
In file included from /opt/pgi/linux86/2012/cuda/4.0/include/cuda_runtime.h:59:0,
from /tmp/pgaccaKIaFik4Fzo.gpu:1:
/opt/pgi/linux86/2012/cuda/4.0/include/host_config.h:82:2: error: #error – unsupported GNU version! gcc 4.5 and up are not supported!
PGF90-W-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (dn.f90: 14)
0 inform, 1 warnings, 0 severes, 0 fatal for dn
