The release of NVIDIA CUDA 13.1 introduces tile-based programming for GPUs, making it one of the most fundamental additions to GPU programming since CUDA was invented. Writing GPU tile kernels enables you to write your algorithm at a higher level than a single-instruction multiple-thread (SIMT) model, while the compiler and runtime handle the partitioning of work onto threads under the covers. Tile kernels also help abstract away special-purpose hardware like tensor cores, and write code that’ll be compatible with future GPU architectures. With the launch of NVIDIA cuTile Python, you can write tile kernels in Python.
What is cuTile Python?
cuTile Python is an expression of the CUDA Tile programming model in Python, built on top of the CUDA Tile IR specification. It enables you to write tile kernels in Python and express GPU kernels using a tile-based model, rather than or in addition to a single instruction, multiple threads (SIMT) model.
SIMT programming requires specifying each GPU thread of execution. In principle, each thread can operate independently and execute a unique code path from any other thread. In practice, to use GPU hardware effectively, it’s typical to program algorithms where each thread performs the same work on separate pieces of data.
SIMT enables maximum flexibility and specificity, but can also require more manual tuning to achieve top performance. The tile model abstracts away some of the HW intricacies. You can focus on your algorithm at a higher level, while the NVIDIA CUDA compiler and runtime handle partitioning your tile algorithm into threads and launching them onto the GPU.
cuTile is a programming model for writing parallel kernels for NVIDIA GPUs. In this model:
- Arrays are the primary data structure.
- Tiles are subsets of arrays that kernels operate on.
- Kernels are functions that are executed in parallel by blocks.
- Blocks are subsets of the GPU; operations on tiles are parallelized across each block.
cuTile automates block-level parallelism and asynchrony, memory movement, and other low-level details of GPU programming. It will leverage the advanced capabilities of NVIDIA hardware (such as tensor cores, shared memory, and tensor memory accelerators) without requiring explicit programming. cuTile is portable across different NVIDIA GPU architectures, enabling you to use the latest hardware features without rewriting your code.
Who is cuTile for?
cuTile is for general-purpose data-parallel GPU kernel authoring. Our efforts have been focused on optimizing cuTile for the types of computations typically encountered in AI/ML applications. We’ll continue to evolve cuTile, adding functionality and performance features to expand the range of workloads it can optimize.
You might be asking why you’d use cuTile to write kernels when CUDA C++ or CUDA Python has worked well so far. We talk more about this in another post describing the CUDA tile model. The short answer is that as GPU hardware becomes more complex, we’re providing an abstraction layer at a reasonable level so developers can focus more on algorithms and less on mapping an algorithm to specific hardware.
Writing tile programs enables you to target tensor cores with code compatible with future GPU architectures. Just as Parallel Thread Execution (PTX) provides the virtual Instruction Set Architecture (ISA) that underlies the SIMT model for GPU programming, Tile IR provides the virtual ISA for tile-based programming. It enables higher-level algorithm expression, while the software and hardware transparently map that representation to tensor cores to deliver peak performance.
cuTile Python example
What does cuTile Python code look like? If you’ve learned CUDA C++, you probably encountered the canonical vector addition kernel. Assuming the data has been copied from the host to the device, a vector add kernel in CUDA SIMT looks something like the following, which takes two vectors and adds them together elementwise to produce a third vector. This is one of the simplest CUDA kernels you can write.
