• Hardware Platform (Jetson / GPU) Jetson Nano 2GB • DeepStream Version 5.1 • JetPack Version (valid for Jetson only) 4.5.1 [L4T 32.5.1] • TensorRT Version 7.1.3.0 • Issue Type( questions, new requirements, bugs) question
I am trying to create a deepstream application for realtime inference over people and face.Since I have used two different models for person detection(Resnet10.caffemodel) and then face detection(fd_lpd.caffemodel taken from here), so with this approach i am getting pretty low FPS.
So, I am looking for single model which can detect both classes.
Hi @kayccc ,
I am still looking for such model which can behave as primary detector and can detect person and their face as well.
Looking forward for your suggestions.
Hi @Morganh
Thanks for your response, can you please suggest me a TRT based model.
Currently i have some limitations for using only TRT models.
If you need a tensorrt engine, there is a tool named tlt-converter. It can convert the etlt model to trt engine. You can copy the etlt model to the machine where you want to run inference. Refer to DetectNet_v2 — Transfer Learning Toolkit 3.0 documentation
Hi @Morganh,
Thanks for your help given links were helpful and they solved my issue, just one last question before closing the topic.
Accuracy for face detection in peoplenet is quit low can you please suggest me to what should I do to get Peoplenet more accurate on face.
Although bag and face class are included in the model, the accuracy of these classes will be much lower than people class. Some re-training will be required on these classes to improve accuracy.
BTW, moving this topic from DS forum into TLT forum.
