Sionna Visualizer β€” Open Source Web Dashboard for Sionna 6G Simulation Results (Live Demo)
Hi everyone πŸ‘‹
I’m Vinayak, a Java backend developer from Pune, India
and a member of the NVIDIA AI Aerial / 6G Developer Program.
Over the past few weeks I’ve been building something I
couldn’t find anywhere β€” a visual, interactive, shareable
web dashboard on top of NVIDIA Sionna simulation results.
I’m calling it Sionna Visualizer.
πŸ”— Live Demo: https://sionna-visualizer.vercel.app
πŸ™ GitHub: GitHub - Vinu2111/sionna-visualizer: A full-stack web dashboard for NVIDIA Sionna 6G simulation results. Angular + Java + Python + PostgreSQL. Β· GitHub
THE PROBLEM I KEPT RUNNING INTO
Sionna outputs raw Python data β€” tensors, numbers,
Jupyter notebook graphs. Every researcher I’ve spoken
to has the same workflow: run simulation, copy data
to Excel or matplotlib, generate chart manually,
share a screenshot.
There was no web-based visual layer. No shareable links.
No history. No comparison tool. I built one.
WHAT IT DOES RIGHT NOW
Three simulation types β€” all running real mathematics:
  1. BER vs SNR Simulation
    β†’ Real AWGN channel model
    β†’ Two curves: theoretical (closed-form erfc equations)
    • simulated (Monte Carlo, 100,000 bits)
      β†’ BPSK / QPSK / 16QAM / 64QAM
      β†’ Logarithmic chart, 25 SNR points
      β†’ 94ms on CPU β€” no GPU required
  2. Beam Pattern Visualization
    β†’ Uniform Linear Array (ULA) model
    β†’ 8 / 16 / 32 / 64 antenna elements
    β†’ 28 GHz / 39 GHz / 60 GHz / 77 GHz
    β†’ Polar chart showing main lobe + side lobes
    β†’ 16-element ULA gives -13.15 dB SLL β€” textbook correct
    β†’ Steering angle control: -90Β° to +90Β°
  3. Modulation Comparison
    β†’ BPSK vs QPSK vs 16QAM vs 64QAM simultaneously
    β†’ Crossover points computed automatically
    β†’ Spectral efficiency tradeoff visible instantly
Plus:
β†’ Every simulation saved to PostgreSQL with full history
β†’ Shareable public link for every result
β†’ Simulation comparison tool β€” select any two from
history, overlay on one chart, winner computed automatically
β†’ JWT authentication
β†’ Full mobile responsive layout
TECH STACK
Frontend: Angular 17 + Chart.js (Vercel)
Backend: Java 17 + Spring Boot 3 (Railway)
Bridge: Python 3.10 + FastAPI + Sionna (Railway)
Database: PostgreSQL (Railway)
Auth: Spring Security + JWT
Fully open source under MIT License.
docker-compose up runs the entire stack locally.
WHAT IS NOT BUILT YET
Being transparent about current limitations:
β†’ GPU Sionna simulation β€” currently using CPU-compatible
AWGN model. Full GPU Sionna integration is next.
β†’ AODT (city-scale digital twin) integration β€” planned
β†’ MIMO channel visualization β€” planned
β†’ Ray tracing simulation support β€” planned
WHY I’M POSTING HERE
This community is exactly who I built this for.
I have three genuine questions for anyone who uses
Sionna in their research:
  1. What Sionna simulation outputs do you wish you
    could visualize that aren’t in the tool yet?
  2. What would make this actually useful in your
    daily research workflow?
  3. Would a REST API that lets you POST your own
    Sionna output JSON and get back a chart URL
    be useful?
Any feedback β€” even harsh β€” is genuinely appreciated.
This is being built in public and your input directly
shapes what gets built next.
Full build-in-public journey documented at:
vinayak6g.hashnode.dev
Thank you for your time.
β€” Vinayak
Thanks Vinayak for your contribution. Do keep the innovations coming.
