Hello, I would like to use nvinfer
to run a TensorRT model and get its raw output that I will process in a Python probe function. I don’t need to run any postprocessing function nor I know C++. Is there a way I can skip the postprocessing? It seems that nvinfer
wants an input function. I’d like to explicitly tell nvinfer
not to do any postprocessing, otherwise the plugin tries to run some default processing an raise the following error:
0:00:06.330034453 82 0x409ad20 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 1]: Could not find output coverage layer for parsing objects
0:00:06.330071451 82 0x409ad20 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 1]: Failed to parse bboxes
0:00:06.330086189 82 0x409ad20 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 1]: Could not find output coverage layer for parsing objects
0:00:06.330096395 82 0x409ad20 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 1]: Failed to parse bboxes
0:00:06.330109152 82 0x409ad20 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::parseBoundingBox() <nvdsinfer_context_impl_output_parsing.cpp:59> [UID = 1]: Could not find output coverage layer for parsing objects
0:00:06.330118605 82 0x409ad20 ERROR nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::fillDetectionOutput() <nvdsinfer_context_impl_output_parsing.cpp:735> [UID = 1]: Failed to parse bboxes
I know that this can be done with nvinferserver
but I’d like to know if this can be done too using nvinfer
I am currently using DS 6.0 and Tesla T4.
Thank you!
