Hardware Platform (Jetson / GPU) T4
• DeepStream Version 6.1
• TensorRT Version 11.4
Could you provide examples for PostProcessor of Triton Apps
What do you mean by PostProcessor? Does it mean nvdspostprocess plugin? Gst-nvdspostprocess (Alpha) — DeepStream 6.1 Release documentation
What does you mean by “Triton Apps”?
need parser for bbox
There are several ways. With gst-nvinfer, there are some default postprocessing algorithm inside, you can choose by settings Gst-nvinfer — DeepStream 6.1 Release documentation. If the default postprocessing can not meet your model’s requirement, you can customize your own postprocessing algorithm by parse customization.
The postprocess depends on the model. So what is your model? What is the output layers of your model and what is the postprocessing algorithm?
as of now i need parsers for tao -applications (tlt models converted to tenssorrt engine files ) .could you help us ?? and i use nvinferserver
Which TAO model? nvinferserver is just the same case as nvinfer. All nvinfer postprocess can be used with nvinferserver too if the model is the same.
yolov3 tao model
If you use TAO yolov3 model, the postprocess functions in /opt/nvidia/deepstream/deepstream/sources/objectDetector_Yolo can be used with nvinferserver too
can you help me with parser for yolov4 etlt model
There is already TAO yolov4 deepstream sample here: deepstream_reference_apps/deepstream_app_tao_configs at master · NVIDIA-AI-IOT/deepstream_reference_apps (github.com)
