Hello, i’ve got some questions about SLI and CUDA.
- If i use two GTX 480(connected by SLI) for example, does cuda see a big GPU with 960 cores or 2 GPU with 480 cores? Is it compatible?
- Both same cards without SLI, is it possible to run a kernel on the first one and at the same time run a second kernel on the second card ?
Thank you
