Slow inference with yolov8 pytorch on agx orin
Hello everyone,
my inference time is to slow and i wonder if i make an obvious mistake? This is my setup:
Python version: 3.8.10 (default, May 26 2023, 14:05:08)
[GCC 9.4.0]
Python Path: /usr/bin/python3
OpenCV version: 4.5.4
OpenCV Path: /usr/local/lib/python3.8/site-packages/cv2/python-3.8
CUDA Version: 11.4
cuDNN Version: 8401
Ultralytics YOLOv8.0.140 πŸš€ Python-3.8.10 torch-1.13.0a0+d0d6b1f2.nv22.09 CUDA:0 (Orin, 30536MiB)
Setup complete βœ… (12 CPUs, 29.8 GB RAM, 35.0/56.7 GB disk)
YOLOv8 v0.1-121-g2fdc7f1 torch 1.13.0a0+d0d6b1f2.nv22.09 CUDA:0 (Orin, 30535.83203125MB)
Model summary: 225 layers, 3011043 parameters, 0 gradients
i am running a yolov8n model on a live feed from a realsense camera 640x480. the inference time is around 18 ms and the total detection process takes around 35 ms. When i have a look at benchmarks, these times should be 3-5 times lower. where do i have to look for to speed up the process. Is there a way to test my system?
This is a normal output:
Marker 1 Time for capturing frame: 4.37 ms
0: 480x640 1 door, 23.5ms
Speed: 2.0ms preprocess, 23.5ms inference, 2.8ms postprocess per image at shape (1, 3, 480, 640)
Marker 3 Time for object detection: 30.36 ms
This is my test code:
import pyrealsense2 as rs
import numpy as np
import cv2
from ultralytics import YOLO
import time
prev_time = 0
# Configure depth and color streams
pipeline = rs.pipeline()
config = rs.config()
config.enable_stream(rs.stream.depth, 640, 480, rs.format.z16, 60)
config.enable_stream(rs.stream.color, 640, 480, rs.format.bgr8, 60)
# Start streaming
pipeline.start(config)
# Align the depth frame to color frame
align_to = rs.stream.color
align = rs.align(align_to)
model = YOLO("/home/tec/yolov8/models/v8nbest.pt")
try:
while True:
start_time = cv2.getTickCount()
        marker_1_start = time.time()
        # Wait for a coherent pair of frames: depth and color
        frames = pipeline.wait_for_frames()
        aligned_frames = align.process(frames) # Align the frames
        depth_frame = aligned_frames.get_depth_frame()
        color_frame = aligned_frames.get_color_frame()
        if not depth_frame or not color_frame:
            continue
        # Convert images to numpy arrays
        color_image = np.asanyarray(color_frame.get_data())
        marker_1_end = time.time()
        print(f"    Marker 1 Time for capturing frame: {(marker_1_end - marker_1_start) * 1000:.2f} ms")
        # marker_3: Time taken for object detection in the frame
        marker_3_start = time.time()
        # Run YOLO inference
        result = model(color_image, verbose = True, show = False)
        marker_3_end = time.time()
        print(f"    Marker 3 Time for object detection: {(marker_3_end - marker_3_start) * 1000:.2f} ms")
        # Calculate FPS
        end_time = cv2.getTickCount()
        frame_time = (end_time - start_time) / cv2.getTickFrequency()
        fps = 1 / frame_time
        # Render FPS on the video frames
        cv2.putText(color_image, f"FPS: {fps:.2f}", (10, 30), cv2.FONT_HERSHEY_SIMPLEX, 1, (0, 255, 0), 2)
        # Show images in separate windows
        cv2.namedWindow('RGB Image', cv2.WINDOW_AUTOSIZE)
        cv2.imshow('RGB Image', color_image)
        # Break the loop if 'q' key is pressed
        if cv2.waitKey(1) == ord('q'):
            break
finally:
    # Stop streaming
    pipeline.stop()
    # Close all OpenCV windows
    cv2.destroyAllWindows()
Have you maximized the device?
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
I also have the same problem.
i have maximized the device as suggested with no difference in inference time.
would appreciate insights.
Could you try it with TensorRT or Deepstream?
There are some samples written by the community to show how to do this.
For example GitHub - marcoslucianops/DeepStream-Yolo: NVIDIA DeepStream SDK 6.3 / 6.2 / 6.1.1 / 6.1 / 6.0.1 / 6.0 / 5.1 implementation for YOLO models
Hi, thanks for the reply. My device is maximized. No change …
i am aware that i have to use TensorRT to use the full potential of the GPU but i wonder why i am so far off from these results:
Thanks for the interesting repo, i will look into that .
Our results are based on TensorRT.
It’s recommended to give it a try.
