gram that what happens:
Sep 06 13:34:29 node2 systemd[1]: Starting NVIDIA Persistence Daemon…
Sep 06 13:34:29 node2 nvidia-persistenced[21134]: Verbose syslog connection opened
Sep 06 13:34:29 node2 nvidia-persistenced[21134]: Now running with user ID 116 and group ID 124
Sep 06 13:34:29 node2 systemd[1]: Started NVIDIA Persistence Daemon.
Sep 06 13:34:29 node2 nvidia-persistenced[21134]: Started (21134)
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: device 0000:03:00.0 - registered
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: Local RPC service initialized
Sep 06 13:34:30 node2 systemd[1]: Stopping NVIDIA Persistence Daemon…
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: Received signal 15
Sep 06 13:34:30 node2 systemd[1]: Stopped NVIDIA Persistence Daemon.
and when I run a pro- Unit nvidia-persistenced.service has begun shutting down.
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: Socket closed.
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: PID file unlocked.
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: PID file closed.
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: The daemon no longer has permission to remove its runtime data directory /var/run/nvidia-persistenced
Sep 06 13:34:30 node2 nvidia-persistenced[21134]: Shutdown (21134)
Sep 06 13:34:30 node2 sudo[21069]: pam_unix(sudo:session): session closed for user root
– Subject: Unit nvidia-persistenced.service has finished shutting down
It appears that you are running driver 384.130, is that correct?
what does nvidia-smi show?
My guess would be some sort of corrupted CUDA software install (e.g. mismatched driver components, from different driver installs), or else running on a platform that is not supported for CUDA.
Detected 1 CUDA Capable device(s)
Device 0: "Tesla C2050"
CUDA Driver Version / Runtime Version 9.0 / 9.0
CUDA Capability Major/Minor version number: 2.0
Total amount of global memory: 2621 MBytes (2748448768 bytes)
MapSMtoCores for SM 2.0 is undefined. Default to use 64 Cores/SM
(14) Multiprocessors, ( 64) CUDA Cores/MP: 896 CUDA Cores
GPU Max Clock rate: 1147 MHz (1.15 GHz)
Memory Clock rate: 1500 Mhz
Memory Bus Width: 384-bit
L2 Cache Size: 786432 bytes
Maximum Texture Dimension Size (x,y,z) 1D=(65536), 2D=(65536, 65535), 3D=(2048, 2048, 2048)
Maximum Layered 1D Texture Size, (num) layers 1D=(16384), 2048 layers
Maximum Layered 2D Texture Size, (num) layers 2D=(16384, 16384), 2048 layers
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 49152 bytes
Total number of registers available per block: 32768
Warp size: 32
Maximum number of threads per multiprocessor: 1536
Maximum number of threads per block: 1024
Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
Max dimension size of a grid size (x,y,z): (65535, 65535, 65535)
Maximum memory pitch: 2147483647 bytes
Texture alignment: 512 bytes
Concurrent copy and kernel execution: Yes with 2 copy engine(s)
Run time limit on kernels: No
Integrated GPU sharing Host Memory: No
Support host page-locked memory mapping: Yes
Alignment requirement for Surfaces: Yes
Device has ECC support: Enabled
Device supports Unified Addressing (UVA): Yes
Supports Cooperative Kernel Launch: No
Supports MultiDevice Co-op Kernel Launch: No
Device PCI Domain ID / Bus ID / location ID: 0 / 3 / 0
Compute Mode:
< Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 1
Result = PASS
I’ve encountered an issue with my machine that 1 of my 4 1080Ti’s disappears from nvidia-smi (under no load what so ever). I’m trying to get to the root of the problem and I found the following behavior for the NVIDIA Persistence Daemon. Seems to be in a constant loop: activating → active → inactive → activating → active → activating …
no its not normal. But I doubt it has anything to do with the root cause of the problem. I think it could be what happens if the GPU disappears when the persistence daemon was previously configured on that GPU.
