On a render node with 4 GTX Titan RTX GPUs running Debian 10 I want to have one X screen per GPU, so I can use it with MPI-based render software using OpenGL (ParaView server mode, with each process taking a different --display :O.<screen> argument). The problem I’m facing is that the X server gets configured to have 1 regular Device and 3 GPUDevice’s and the latter ones are apparently not capable of becoming X screens:
[346791.563]
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
[346791.563] Build Operating System: Linux 4.19.0-10-amd64 x86_64 Debian
[346791.563] Current Operating System: Linux r29n5.lisa.surfsara.nl 4.19.0-12-amd64 #1 SMP Debian 4.19.152-1 (2020-10-18) x86_64
[346791.563] Kernel command line: BOOT_IMAGE=/vmlinuz root=LABEL=root ro
[346791.563] Build Date: 27 August 2020 08:51:48AM
[346791.563] xorg-server 2:1.20.4-1+deb10u1 (https://www.debian.org/support)
[346791.563] Current version of pixman: 0.36.0
[346791.563] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[346791.563] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[346791.563] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Oct 27 14:21:08 2020
[346791.563] (==) Using config file: "/etc/X11/xorg.conf"
[346791.563] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[346791.564] (==) ServerLayout "Layout0"
[346791.564] (**) |-->Screen "Screen0" (0)
[346791.564] (**) | |-->Monitor "Monitor0"
[346791.565] (**) | |-->Device "Device0"
[346791.565] (**) | |-->GPUDevice "Device1"
[346791.565] (**) | |-->GPUDevice "Device2"
[346791.565] (**) | |-->GPUDevice "Device3"
[346791.627] (II) NVIDIA GLX Module 450.80.02 Wed Sep 23 00:51:32 UTC 2020
[346791.627] (II) NVIDIA: The X server does not support PRIME Render Offload.
[346791.630] (II) NVIDIA(0): NVIDIA GPU TITAN RTX (TU102-A) at PCI:59:0:0 (GPU-0)
[346791.630] (--) NVIDIA(0): Memory: 25165824 kBytes
[346791.630] (--) NVIDIA(0): VideoBIOS: 90.02.2e.00.0c
[346791.630] (EE) NVIDIA(G0): GPU screens are disabled
[346791.630] (EE) NVIDIA(G0): Failing initialization of X screen
[346791.630] (**) NVIDIA(G1): Depth 24, (--) framebuffer bpp 32
[346791.630] (==) NVIDIA(G1): RGB weight 888
[346791.630] (==) NVIDIA(G1): Default visual is TrueColor
[346791.630] (==) NVIDIA(G1): Using gamma correction (1.0, 1.0, 1.0)
[346791.630] (**) NVIDIA(G1): Enabling 2D acceleration
[346791.630] (EE) NVIDIA(G1): GPU screens are disabled
[346791.630] (EE) NVIDIA(G1): Failing initialization of X screen
[346791.630] (**) NVIDIA(G2): Depth 24, (--) framebuffer bpp 32
[346791.630] (==) NVIDIA(G2): RGB weight 888
[346791.630] (==) NVIDIA(G2): Default visual is TrueColor
[346791.630] (==) NVIDIA(G2): Using gamma correction (1.0, 1.0, 1.0)
[346791.630] (**) NVIDIA(G2): Enabling 2D acceleration
[346791.630] (EE) NVIDIA(G2): GPU screens are disabled
[346791.630] (EE) NVIDIA(G2): Failing initialization of X screen
I actually don’t want GPU Screens (nor PRIME rendering offloading), I want regular X screens. According to Appendix B. X Config Options the option AllowNVIDIAGPUScreens is a boolean, but I can’t seem to get the X server to listen to it when it is set to false or no. In fact, the option doesn’t seem to get picked up by the nvidia driver:
[346791.615] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[346791.615] (**) Option "AllowNVIDIAGpuScreens" "false"
[346791.615] (**) NVIDIA(0): Option "ConnectedMonitor" "DFP-0"
I checked the system-wide config files in /usr/share/X11/xorg.conf.d, but nothing relevant seems to be specified there.
Also strange is that the xconfig link above mentions that “The NVIDIA X driver will allow GPU screens on X.Org xserver version 1.20.7 and higher”, but we’re running 1.20.4. Plus, it’s reported in the X log output that PRIME Render Offload is not even supported by the X server.
Relevant excerpt from the xorg.conf:
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0"
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "AllowNVIDIAGPUScreens" "false"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BusID "PCI:59:0:0"
EndSection
Section "Device"
Identifier "Device1"
Driver "nvidia"
BusID "PCI:94:0:0"
EndSection
Section "Device"
Identifier "Device2"
Driver "nvidia"
BusID "PCI:177:0:0"
EndSection
Section "Device"
Identifier "Device3"
Driver "nvidia"
BusID "PCI:217:0:0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "UseDisplayDevice" "none"
Option "CustomEDID" "DFP-0: /etc/X11/dell-3008wfp.bin"
SubSection "Display"
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen1"
Device "Device1"
Monitor "Monitor1"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen2"
Device "Device2"
Monitor "Monitor2"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Section "Screen"
Identifier "Screen3"
Device "Device3"
Monitor "Monitor3"
DefaultDepth 24
Depth 24
EndSubSection
EndSection
Configuring the X server used to work with earlier driver versions, but it seems the recent PRIME support and relevant X options make this hard now. We also have another cluster with GPU nodes (2 Tesla K40m per node, NVIDIA driver 455.23.05) where the almost exact same X config (2 GPU devices instead of 4) does not lead to a GPUDevice being created, but simply 2 regular Device’s, which then are used as 2 X screens. I really don’t understand why that is. Are the K40m’s too old to support PRIME and are therefore not enabled as GPU Screens?
Edit: attach nvidia-bug-report.log.gz (2.8 MB)
