Some problems about enable SPI by modifying DTB
I meet some problems when I enabling the SPI by modifying DTB files.
I use the methods refer to this link.https://forums.developer.nvidia.com/t/about-using-spi-on-jetson-nano/210372/21
And change all of the nodes mentioned. Like below:
spi1_mosi_pc0 {
nvidia,pins = “spi1_mosi_pc0”;
nvidia,function = “spi1”;
nvidia,pull = <0x1>;
nvidia,tristate = <0x0>;
nvidia,enable-input = <0x1>;
Then after rebooting, and see the tegra_pinctrl_reg file, the register information has not been changed. It looks like below:
Bank: 1 Reg: 0x70003050 Val: 0x0000e045 → spi1_mosi_pc0
Bank: 1 Reg: 0x70003054 Val: 0x0000e045 → spi1_miso_pc1
Bank: 1 Reg: 0x70003058 Val: 0x0000e045 → spi1_sck_pc2
Bank: 1 Reg: 0x7000305c Val: 0x0000e049 → spi1_cs0_pc3
Bank: 1 Reg: 0x70003060 Val: 0x0000e049 → spi1_cs1_pc4
Bank: 1 Reg: 0x70003064 Val: 0x00006046 → spi2_mosi_pb4
Bank: 1 Reg: 0x70003068 Val: 0x00006046 → spi2_miso_pb5
Bank: 1 Reg: 0x7000306c Val: 0x00006046 → spi2_sck_pb6
Bank: 1 Reg: 0x70003070 Val: 0x00006046 → spi2_cs0_pb7
Bank: 1 Reg: 0x70003074 Val: 0x00006045 → spi2_cs1_pdd0
Bank: 1 Reg: 0x70003078 Val: 0x0000e015 → spi4_mosi_pc7
Bank: 1 Reg: 0x7000307c Val: 0x0000e015 → spi4_miso_pd0
Bank: 1 Reg: 0x70003080 Val: 0x0000e015 → spi4_sck_pc5
Bank: 1 Reg: 0x70003084 Val: 0x0000e015 → spi4_cs0_pc6
Bank: 1 Reg: 0x70003088 Val: 0x00002015 → qspi_sck_pee0
Bank: 1 Reg: 0x7000308c Val: 0x00002015 → qspi_cs_n_pee1
Bank: 1 Reg: 0x70003090 Val: 0x00002015 → qspi_io0_pee2
Bank: 1 Reg: 0x70003094 Val: 0x00002015 → qspi_io1_pee3
Bank: 1 Reg: 0x70003098 Val: 0x00002015 → qspi_io2_pee4
Bank: 1 Reg: 0x7000309c Val: 0x00002015 → qspi_io3_pee5
Bank: 0 Reg: 0x70000b70 Val: 0x00000001 → drive_qspi_comp_control
Bank: 0 Reg: 0x70000b78 Val: 0x00000001 → drive_qspi_lpbk_control
Bank: 0 Reg: 0x70000a78 Val: 0x00808000 → drive_qspi_comp
According the Moderator says, Looks like my device didn’t apply well.
I don’t know why, could any handsome/beautifuy experts surport for me?
Pretty thanks!
Hi 1169119875,
Are you using the devkit or custom board for Jetson Nano?
and what’s your current Jetpack version in use?
Glad to see your reply.
I am using Jetson Nano Developer Kit B01 with Jetpack4.6.1
Could you help to update to Jetpack 4.6.3(R32.7.3) and refer to the following instruction to verify SPI loopback test?
Jetson Nano SPI Bus Not Working - #10 by KevinFFF
OK,sir, I’ll try it.
But sir, could you please tell me how to update my nano to Jetpack4.6.3?
I didn’t find an SD card system image on the Nividia official wesite.
If you are using the devkit from NVIDA, you could just use SDKM to flash your board with SD card.
Install Jetson Software with SDK Manager :: NVIDIA SDK Manager Documentation
