sort each row in a matrix?
Are there CUDA library to sort each row in a matrix simultaneously?
if I use thrust sort library, I have to sequentially call thrust sort function to sort each row, if there are 10000 rows, I need to make 10000 sequential calls. This is not efficient.
Any help on this?
Thanks a lot!
Hi Zhao,
You can try sort in ArrayFire.
Here is a snippet of code that can help understand it:
array a = randu(4, 3); // random matrix of 4 rows and 3 columns
array b = sort(a, 0); // Sort along the columns
array c = sort(a, 1); // Sort along the rows
print(a);
print(b);
print(c);
outputs
a =
           0.7402        0.9251        0.4702
           0.9210        0.4464        0.5132
           0.0390        0.6673        0.7762
           0.9690        0.1099        0.2948
b =
           0.0390        0.1099        0.2948
           0.7402        0.4464        0.4702
           0.9210        0.6673        0.5132
           0.9690        0.9251        0.7762
c =
           0.4702        0.7402        0.9251
           0.4464        0.5132        0.9210
           0.1099        0.2948        0.9690
thanks for your reply!
Actually, I’ve tried ArrayFire and installed successfully.
However, when I tried example codes, it always gave “segmentation fault” info. No clue about it.
I run ArrayFire on a GPU cluster through Putty~
