Originally published at: https://developer.nvidia.com/blog/speeding-up-deep-learning-inference-using-tensorrt/
Looking for more? Check out the hands-on DLI training course: Optimization and Deployment of TensorFlow Models with TensorRT This is an updated version of How to Speed Up Deep Learning Inference Using TensorRT. This version starts from a PyTorch model instead of the ONNX model, upgrades the sample application to use TensorRT 7, and replaces…
This line:
>> tar xvf speeding-up-unet.7z # Unpack the model data into the unet folder
is out of date. It’ll throw an error “this does not look like a tar archive”.
This fix is:
apt update
apt install p7zip-full
7z x speeding-up-unet.7z
The article or the file should be updated, if possible
I think this blog page needs to be updated. For example, you make mention of pulling down a Docker container for pytorch, but then make no mention of it.
When I try to build code_samples/posts/TensorRT-introduction with the default Ubuntu 20.04 protobuf I get an error about post.inc. I then grabbed the latest protobuf repo and tried that. That version gave me different errors. Now I’m on protobuf v3.17.3 and I receive the following errors:
In file included from /usr/local/include/onnx/onnx_pb.h:52,
from ioHelper.cpp:32:
/usr/local/include/onnx/onnx-ml.pb.h:616:3: error: ‘PROTOBUF_FUTURE_MUST_USE_RESULT’ does not name a type
616 | PROTOBUF_FUTURE_MUST_USE_RESULT std::string* release_name();
/usr/local/include/onnx/onnx-ml.pb.h:634:3: error: ‘PROTOBUF_FUTURE_MUST_USE_RESULT’ does not name a type
634 | PROTOBUF_FUTURE_MUST_USE_RESULT std::string* release_s();
/usr/local/include/onnx/onnx-ml.pb.h:652:3: error: ‘PROTOBUF_FUTURE_MUST_USE_RESULT’ does not name a type
652 | PROTOBUF_FUTURE_MUST_USE_RESULT std::string* release_doc_string();
/usr/local/include/onnx/onnx-ml.pb.h:670:3: error: ‘PROTOBUF_FUTURE_MUST_USE_RESULT’ does not name a type
670 | PROTOBUF_FUTURE_MUST_USE_RESULT std::string* release_ref_attr_name();
/usr/local/include/onnx/onnx-ml.pb.h:685:3: error: ‘PROTOBUF_FUTURE_MUST_USE_RESULT’ does not name a type
685 | PROTOBUF_FUTURE_MUST_USE_RESULT ::onnx::TensorProto* release_t();
The errors go on and on and on. Very difficult to follow an “introductory example.”
Hi @Shadowmind, sorry about the inconvenience.
This tutorial has been tested on Ubuntu 18.04, so can you please try using the following container?
# Pull docker container
docker pull nvcr.io/nvidia/pytorch:20.07-py3
# Run container
docker run --rm --gpus all -ti nvcr.io/nvidia/pytorch:20.07-py3
error occurs as below
File "/home/screw/Desktop/LearningTensorRT/code-samples/posts/unet/prepareData.py", line 7, in <module>
from utils import normalize_volume
ImportError: cannot import name 'normalize_volume' from 'utils' (/home/screw/.local/lib/python3.8/site-packages/utils/__init__.py)
l don’t know where to import the normalize_volume fucntion, so i guess it just normalize the input image, using code below replace the original function
input_image = np.asarray(input_image, dtype='float32')
mean_input_image = input_image.mean()
input_image /= mean_input_image
the model does works, but it does’t work as amazing as the examples from the tourial.
So my question is how to fix the bug and using the normalize_volume function, thanks!
When I try to build code_samples/posts/TensorRT-introduction, there is an error:
simpleOnnx.cpp: In function ‘nvinfer1::ICudaEngine* createCudaEngine(const string&, int)’:
simpleOnnx.cpp:72:14: error: ‘class nvinfer1::IBuilder’ has no member named ‘setFp16Mode’
builder->setFp16Mode(builder->platformHasFastFp16());
How to fix it?
