i modified the sampleonnxMINST for my own onnx model, and i have a confusion about how the inputdata in the buffer is reshaped for the model input size? i just follow the sample and changed the input data to A one-dimensional vector for input. However, i found that the TensorRT can not accelarate the onnx model for inferencing, i can obtain 20ms for pytorch inference but 30ms for tensorrt. I don’t know why, maybe there is some bugs in my code. Can anybody give me some advice to slove my problem? Thanks!
A clear and concise description of the bug or issue.
Environment
TensorRT Version : 7.0.0.11
GPU Type : 2080i
Nvidia Driver Version :
CUDA Version : 10.0
CUDNN Version : 7.6.0
Operating System + Version : Vs2017 Community
Python Version (if applicable) : 3.6.7
TensorFlow Version (if applicable) : /
PyTorch Version (if applicable) : 1.3.0
Baremetal or Container (if container which image + tag) :
Relevant Files
Here is my code:
//! sampleOnnxMNIST.cpp
//! This file contains the implementation of the ONNX MNIST sample. It creates the network using
//! the MNIST onnx model.
//! It can be run with the following command line:
//! Command: ./sample_onnx_mnist [-h or --help] [-d=/path/to/data/dir or --datadir=/path/to/data/dir]
//! [–useDLACore=]
include <opencv2/core/core.hpp>
include <opencv2/highgui/highgui.hpp>
include <opencv2/highgui/highgui_c.h>
include <opencv2/opencv.hpp>
include “argsParser.h”
include “buffers.h”
include “common.h”
include “logger.h”
include “parserOnnxConfig.h”
include “NvInfer.h”
include <cuda_runtime_api.h>
include
include
include
include
include
include
include <numpy/arrayobject.h>
const std::string gSampleName = “TensorRT.sample_onnx_mnist”;
//! \brief The SampleOnnxMNIST class implements the ONNX MNIST sample
//! \details It creates the network using an ONNX model
class SampleOnnxMNIST
template
using SampleUniquePtr = std::unique_ptr<T, samplesCommon::InferDeleter>;
public:
SampleOnnxMNIST(const samplesCommon::OnnxSampleParams& params)
: mParams(params)
, mEngine(nullptr)
//! \brief Function builds the network engine
bool build();
//! \brief Runs the TensorRT inference engine for this sample
bool infer();
private:
samplesCommon::OnnxSampleParams mParams; //!< The parameters for the sample.
nvinfer1::Dims mInputDims; //!< The dimensions of the input to the network.
nvinfer1::Dims mOutputDims; //!< The dimensions of the output to the network.
int mNumber{ 0 }; //!< The number to classify
std::shared_ptr<nvinfer1::ICudaEngine> mEngine; //!< The TensorRT engine used to run the network
//! \brief Parses an ONNX model for MNIST and creates a TensorRT network
bool constructNetwork(SampleUniquePtr<nvinfer1::IBuilder>& builder,
SampleUniquePtr<nvinfer1::INetworkDefinition>& network, SampleUniquePtr<nvinfer1::IBuilderConfig>& config,
SampleUniquePtr<nvonnxparser::IParser>& parser);
//! \brief Reads the input and stores the result in a managed buffer
bool processInput(const samplesCommon::BufferManager& buffers);
//! \brief Classifies digits and verify result
bool verifyOutput(const samplesCommon::BufferManager& buffers);
//! \brief Creates the network, configures the builder and creates the network engine
//! \details This function creates the Onnx MNIST network by parsing the Onnx model and builds
//! the engine that will be used to run MNIST (mEngine)
//! \return Returns true if the engine was created successfully and false otherwise
bool SampleOnnxMNIST::build()
cout << “Wawting for the next step…” << endl;
auto builder = SampleUniquePtrnvinfer1::IBuilder(nvinfer1::createInferBuilder(gLogger.getTRTLogger()));
if (!builder)
return false;
const auto explicitBatch = 1U << static_cast<uint32_t>(NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
auto network = SampleUniquePtr<nvinfer1::INetworkDefinition>(builder->createNetworkV2(explicitBatch));
if (!network)
return false;
cout << "Parsing the onnx model !" << endl;
auto config = SampleUniquePtr<nvinfer1::IBuilderConfig>(builder->createBuilderConfig());
if (!config)
return false;
auto parser = SampleUniquePtr<nvonnxparser::IParser>(nvonnxparser::createParser(*network, gLogger.getTRTLogger()));
if (!parser)
return false;
cout << "Start to build the network...." << endl;
auto constructed = constructNetwork(builder, network, config, parser);
if (!constructed)
return false;
cout << "Start to build the mEngine......." << endl;
mEngine = std::shared_ptr<nvinfer1::ICudaEngine>(
builder->buildEngineWithConfig(*network, *config), samplesCommon::InferDeleter());
if (!mEngine)
return false;
cout << "mEngine is OK!!!!" << endl;
assert(network->getNbInputs() == 1);
mInputDims = network->getInput(0)->getDimensions();
assert(mInputDims.nbDims == 5);
assert(network->getNbOutputs() == 1);
mOutputDims = network->getOutput(0)->getDimensions();
assert(mOutputDims.nbDims == 4);
cout << "Finish build network!" << endl;
return true;
//! \brief Uses a ONNX parser to create the Onnx MNIST Network and marks the
//! output layers
//! \param network Pointer to the network that will be populated with the Onnx MNIST network
//! \param builder Pointer to the engine builder
bool SampleOnnxMNIST::constructNetwork(SampleUniquePtrnvinfer1::IBuilder& builder,
SampleUniquePtrnvinfer1::INetworkDefinition& network, SampleUniquePtrnvinfer1::IBuilderConfig& config,
SampleUniquePtrnvonnxparser::IParser& parser)
auto parsed = parser->parseFromFile(
locateFile(mParams.onnxFileName, mParams.dataDirs).c_str(), static_cast(gLogger.getReportableSeverity()));
if (!parsed)
return false;
builder->setMaxBatchSize(mParams.batchSize);
config->setMaxWorkspaceSize(16_MiB);
if (mParams.fp16)
config->setFlag(BuilderFlag::kFP16);
if (mParams.int8)
config->setFlag(BuilderFlag::kINT8);
samplesCommon::setAllTensorScales(network.get(), 127.0f, 127.0f);
samplesCommon::enableDLA(builder.get(), config.get(), mParams.dlaCore);
return true;
//! \details This function is the main execution function of the sample. It allocates the buffer,
//! sets inputs and executes the engine.
bool SampleOnnxMNIST::infer()
// Create RAII buffer manager object
samplesCommon::BufferManager buffers(mEngine, mParams.batchSize);
auto context = SampleUniquePtr<nvinfer1::IExecutionContext>(mEngine->createExecutionContext());
if (!context)
return false;
// Read the input data into the managed buffers
assert(mParams.inputTensorNames.size() == 1);
if (!processInput(buffers))
return false;
// Memcpy from host input buffers to device input buffers
buffers.copyInputToDevice();
auto startTime = std::chrono::high_resolution_clock::now();
bool status = context->executeV2(buffers.getDeviceBindings().data());
auto endTime = std::chrono::high_resolution_clock::now();
float totalTime = std::chrono::duration<float, std::milli>(endTime - startTime).count();
std::cout << "Time used one image (measured by chrono):" << totalTime << " ms" << std::endl;
if (!status)
return false;
// Memcpy from device output buffers to host output buffers
buffers.copyOutputToHost();
// Verify results
if (!verifyOutput(buffers))
return false;
return true;
bool SampleOnnxMNIST::processInput(const samplesCommon::BufferManager& buffers)
using namespace cv;
string imgpath = “D:/02_DataFile/data_20191122_2D/01_PNG_data/03/lower/frame2d_1064.png”;
string ascpath = “D:/02_DataFile/data_20191122_2D/01_PNG_data/03/lower_asc/frame3d_1064.png”;
string zpath = “D:/02_DataFile/data_20191122_2D/01_PNG_data/03/lower_z/frame3d_1064.png”;
Mat img = imread(imgpath, 1);
Mat asc = imread(imgpath, 1);
Mat z = imread(imgpath, 0);
if (img.empty())
cout << "Image loading failed!"
<< endl;
return -1;
vector<float> input;
for (int i = 0; i < 3; i++)
for (size_t nrow = 0; nrow < img.rows; nrow++)
for (size_t ncol = 0; ncol < img.cols; ncol++)
Vec3i bgr = img.at<Vec3b>(nrow, ncol);
input.push_back(bgr.val[i]);
cout << "Pictureinput.size():" << input.size() << endl;
for (int i = 0; i < z.rows; i++)
for (int j = 0; j < z.cols; j++)
input.push_back(z.at<uchar>(i, j));
for (size_t nrow = 0; nrow < asc.rows; nrow++)
for (size_t ncol = 0; ncol < asc.cols; ncol++)
Vec3i bgr = asc.at<Vec3b>(nrow, ncol);
int vsize = input.size();
for (int i = 0; i < vsize; i++)
input.push_back(input[i]);
float* hostDataBuffer = static_cast<float*>(buffers.getHostBuffer(mParams.inputTensorNames[0]));
//hostDataBuffer[i] = 1.0 - float(toothresult[i] / 255.0);
hostDataBuffer[i] = input[i];
return true;
//! \return whether the classification output matches expectations
bool SampleOnnxMNIST::verifyOutput(const samplesCommon::BufferManager& buffers)
const int Size0 = mOutputDims.d[0];
const int Size1 = mOutputDims.d[1];
const int Size2 = mOutputDims.d[2];
const int Size3 = mOutputDims.d[3];
cout << typeid(mOutputDims).name() << endl;
cout << "outresult.size():" << mOutputDims.d[0] << endl;
cout << "outresult.size():" << mOutputDims.d[1] << endl;
cout << "outresult.size():" << mOutputDims.d[2] << endl;
cout << "outresult.size():" << mOutputDims.d[3] << endl;
float* output = static_cast<float*>(buffers.getHostBuffer(mParams.outputTensorNames[0]));
vector<float> result;
int size = Size0 * Size1 * Size2 * Size3;
float *arr = new float[size];
for (int i = 0; i < mOutputDims.d[0] * mOutputDims.d[1] * mOutputDims.d[2] * mOutputDims.d[3]; i++)
result.push_back(output[i]);
arr[i] = output[i];
//std::cout << result[i] << " " << std::endl;
float ***DD;
DD = new float **[Size1];
for (int x = 0; x < Size1; x++)
DD[x] = new float *[Size2];
for (int y = 0; y < Size2; y++)
DD[x][y] = new float[Size3];
for (int i = 0; i < Size1; i++)
for (int j = 0; j < Size2; j++)
for (int k = 0; k < Size3; k++)
DD[i][j][k] = arr[(i*Size2 + j)*Size3 + k];
cout << "Picture_result.size():" << result.size() << endl;
using namespace cv;
string imgpath = "D:/02_DataFile/data_20191122_2D/01_PNG_data/03/lower_label/frame2d_1064.png";
Mat img = imread(imgpath, 0);
int row = img.rows;
int col = img.cols;
if (img.empty())
<< endl;
return -1;
int **label = new int *[row];
for (int i = 0; i < row; i++)
label[i] = new int[col];
for (int j = 0; j < col; j++)
label[i][j] = img.at<uchar>(i, j);
int **out_result = new int *[row];
out_result[i] = new int[col];
int index_max = 0; //Initializes the maximum subscript
for (int k = 0; k < 3; k++)
if (DD[k][i][j] < DD[index_max][i][j])
index_max = k;
out_result[i][j] = index_max;
//calculate the accuracy
int sum = 0;
if (label[i][j] == out_result[i][j])
sum = sum + 1;
//cout << sum << endl;
cout << "The number of sum is : " << sum << endl;
float accuracy = (1.00000f*sum / row / col);
cout << "The accuracy of image is: " << accuracy << endl;
//! \brief Initializes members of the params struct using the command line args
samplesCommon::OnnxSampleParams initializeSampleParams(const samplesCommon::Args& args)
samplesCommon::OnnxSampleParams params;
if (args.dataDirs.empty()) //!< Use default directories if user hasn’t provided directory paths
params.dataDirs.push_back(“data/mnist/”);
params.dataDirs.push_back(“data/samples/mnist/”);
else //!< Use the data directory provided by the user
params.dataDirs = args.dataDirs;
params.onnxFileName = “test_simple.onnx”;
params.inputTensorNames.push_back(“0”);
params.batchSize = 1;
params.outputTensorNames.push_back(“1033”);
params.dlaCore = args.useDLACore;
params.int8 = args.runInInt8;
params.fp16 = args.runInFp16;
return params;
//! \brief Prints the help information for running this sample
void printHelpInfo()
std::cout
<< “Usage: ./sample_onnx_mnist [-h or --help] [-d or --datadir=] [–useDLACore=]”
<< std::endl;
std::cout << “–help Display help information” << std::endl;
std::cout << "–datadir Specify path to a data directory, overriding the default. This option can be used "
"multiple times to add multiple directories. If no data directories are given, the default is to use "
“(data/samples/mnist/, data/mnist/)”
<< std::endl;
std::cout << "–useDLACore=N Specify a DLA engine for layers that support DLA. Value can range from 0 to n-1, "
“where n is the number of DLA engines on the platform.”
<< std::endl;
std::cout << “–int8 Run in Int8 mode.” << std::endl;
std::cout << “–fp16 Run in FP16 mode.” << std::endl;
int main(int argc, char** argv)
samplesCommon::Args args;
bool argsOK = samplesCommon::parseArgs(args, argc, argv);
if (!argsOK)
gLogError << “Invalid arguments” << std::endl;
printHelpInfo();
return EXIT_FAILURE;
if (args.help)
printHelpInfo();
return EXIT_SUCCESS;
auto sampleTest = gLogger.defineTest(gSampleName, argc, argv);
gLogger.reportTestStart(sampleTest);
SampleOnnxMNIST sample(initializeSampleParams(args));
gLogInfo << "Building and running a GPU inference engine for Onnx FCHardNet" << std::endl;
if (!sample.build())
return gLogger.reportFail(sampleTest);
if (!sample.infer())
return gLogger.reportPass(sampleTest);
And there is my onnx model:https://drive.google.com/open?id=11rmigXkzDIbhxzlwKQBjeDHicX9h9ZyL
