BufferManager issue | TensorRT C++ sample
Description
I am learning to use the TensorRT by C++ to speed on model inference time, I am not familiar with C++ tho. So I will be grateful if you ave any idea about it.
I was trying to do inference by deserializing the TensorRT engine.
I took the sampleOnnxMNIST to modify some parts. First of all, I could serialize the model from original sampleOnnxMNIST after it built the engine and network. Here is the model. MNIST TensorRT Engine model
Also, I added the deserializing engine part in build function and remove original parts such as parse onnx model and construct the network. The deserializing engine part was referred to sampleEngines.cpp in common folder.
However, after I make the file (generate the executive file in bin), it encountered segmentation fault during going to samplesCommon::BufferManager buffers(mEngine); this line.
Here is my code.
 * Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
//! SampleOnnxMNIST.cpp
//! This file contains the implementation of the ONNX MNIST sample. It creates the network using
//! the MNIST onnx model.
//! It can be run with the following command line:
//! Command: ./sample_onnx_mnist [-h or --help] [-d=/path/to/data/dir or --datadir=/path/to/data/dir]
//! [--useDLACore=<int>]
#include "argsParser.h"
#include "buffers.h"
#include "common.h"
#include "logger.h"
#include "parserOnnxConfig.h"
#include "NvInfer.h"
#include <cuda_runtime_api.h>
#include <cstdlib>
#include <fstream>
#include <iostream>
#include <sstream>
const std::string gSampleName = "TensorRT.sample_onnx_mnist";
//! \brief  The SampleOnnxMNIST class implements the ONNX MNIST sample
//! \details It creates the network using an ONNX model
class SampleOnnxMNIST
    template <typename T>
    using SampleUniquePtr = std::unique_ptr<T, samplesCommon::InferDeleter>;
public:
    SampleOnnxMNIST(const samplesCommon::OnnxSampleParams &params)
        : mParams(params), mEngine(nullptr)
    //! \brief Function builds the network engine
    bool build();
    //! \brief Runs the TensorRT inference engine for this sample
    bool infer();
private:
    samplesCommon::OnnxSampleParams mParams; //!< The parameters for the sample.
    nvinfer1::Dims mInputDims;  //!< The dimensions of the input to the network.
    nvinfer1::Dims mOutputDims; //!< The dimensions of the output to the network.
    int mNumber{0};             //!< The number to classify
    std::shared_ptr<nvinfer1::ICudaEngine> mEngine; //!< The TensorRT engine used to run the network
    //! \brief Reads the input  and stores the result in a managed buffer
    bool processInput(const samplesCommon::BufferManager &buffers);
    //! \brief Classifies digits and verify result
    bool verifyOutput(const samplesCommon::BufferManager &buffers);
//! \brief Creates the network, configures the builder and creates the network engine
//! \details This function creates the Onnx MNIST network by parsing the Onnx model and builds
//!          the engine that will be used to run MNIST (mEngine)
//! \return Returns true if the engine was created successfully and false otherwise
bool SampleOnnxMNIST::build()
    string enginePath = "/workspace/tensorrt/data/mnist/mnist_tensorrt.engine";
    std::ifstream engineFile(enginePath, std::ios::binary);
    if (!engineFile)
        std::cout << "Error opening engine file: " << enginePath << std::endl;
        return false;
    engineFile.seekg(0, engineFile.end);
    long int fsize = engineFile.tellg();
    engineFile.seekg(0, engineFile.beg);
    std::vector<char> engineData(fsize);
    engineFile.read(engineData.data(), fsize);
    if (!engineFile)
        std::cout << "Error loading engine file: " << enginePath << std::endl;
        return false;
    IRuntime *runtime = createInferRuntime(sample::gLogger.getTRTLogger());
    ICudaEngine *mEngine = runtime->deserializeCudaEngine(engineData.data(), fsize, nullptr);
    if (mEngine)
        std::cout << std::endl
                  << ">> ^_^ Succeeded to deserialize the model\n\n";
        return true;
    return false;
//! \brief Uses a ONNX parser to create the Onnx MNIST Network and marks the
//!        output layers
//! \param network Pointer to the network that will be populated with the Onnx MNIST network
//! \param builder Pointer to the engine builder
//! \details This function is the main execution function of the sample. It allocates the buffer,
//!          sets inputs and executes the engine.
bool SampleOnnxMNIST::infer()
              << ">> Start to inference\n\n";
    // Create RAII buffer manager object
              << ">>1 \n\n";
    auto context = SampleUniquePtr<nvinfer1::IExecutionContext>(mEngine->createExecutionContext());
    if (!context)
        return false;
              << ">>2 \n\n";
    // Read the input data into the managed buffers
    assert(mParams.inputTensorNames.size() == 1);
    if (!processInput(buffers))
        return false;
              << ">>3 \n\n";
    // Memcpy from host input buffers to device input buffers
    buffers.copyInputToDevice();
    bool status = context->executeV2(buffers.getDeviceBindings().data());
    if (!status)
        return false;
              << ">>4 \n\n";
    // Memcpy from device output buffers to host output buffers
    buffers.copyOutputToHost();
    // Verify results
    if (!verifyOutput(buffers))
        return false;
    return true;
bool SampleOnnxMNIST::processInput(const samplesCommon::BufferManager &buffers)
    const int inputH = mInputDims.d[2];
    const int inputW = mInputDims.d[3];
    // Read a random digit file
    srand(unsigned(time(nullptr)));
    std::vector<uint8_t> fileData(inputH * inputW);
    mNumber = rand() % 10;
    readPGMFile(locateFile(std::to_string(mNumber) + ".pgm", mParams.dataDirs), fileData.data(), inputH, inputW);
    // Print an ascii representation
    sample::gLogInfo << "Input:" << std::endl;
    for (int i = 0; i < inputH * inputW; i++)
        sample::gLogInfo << (" .:-=+*#%@"[fileData[i] / 26]) << (((i + 1) % inputW) ? "" : "\n");
    sample::gLogInfo << std::endl;
    float *hostDataBuffer = static_cast<float *>(buffers.getHostBuffer(mParams.inputTensorNames[0]));
        hostDataBuffer[i] = 1.0 - float(fileData[i] / 255.0);
    return true;
//! \return whether the classification output matches expectations
bool SampleOnnxMNIST::verifyOutput(const samplesCommon::BufferManager &buffers)
    const int outputSize = mOutputDims.d[1];
    float *output = static_cast<float *>(buffers.getHostBuffer(mParams.outputTensorNames[0]));
    float val{0.0f};
    int idx{0};
    // Calculate Softmax
    float sum{0.0f};
    for (int i = 0; i < outputSize; i++)
        output[i] = exp(output[i]);
        sum += output[i];
    sample::gLogInfo << "Output:" << std::endl;
        output[i] /= sum;
        val = std::max(val, output[i]);
        if (val == output[i])
            idx = i;
        sample::gLogInfo << " Prob " << i << "  " << std::fixed << std::setw(5) << std::setprecision(4) << output[i] << " "
                         << "Class " << i << ": " << std::string(int(std::floor(output[i] * 10 + 0.5f)), '*') << std::endl;
    return idx == mNumber && val > 0.9f;
//! \brief Initializes members of the params struct using the command line args
samplesCommon::OnnxSampleParams initializeSampleParams(const samplesCommon::Args &args)
    samplesCommon::OnnxSampleParams params;
    if (args.dataDirs.empty()) //!< Use default directories if user hasn't provided directory paths
        params.dataDirs.push_back("data/mnist/");
        params.dataDirs.push_back("data/samples/mnist/");
    else //!< Use the data directory provided by the user
        params.dataDirs = args.dataDirs;
    params.onnxFileName = "mnist.onnx";
    params.inputTensorNames.push_back("Input3");
    params.outputTensorNames.push_back("Plus214_Output_0");
    params.dlaCore = args.useDLACore;
    params.int8 = args.runInInt8;
    params.fp16 = args.runInFp16;
    return params;
//! \brief Prints the help information for running this sample
void printHelpInfo()
    std::cout
        << "Usage: ./sample_onnx_mnist [-h or --help] [-d or --datadir=<path to data directory>] [--useDLACore=<int>]"
        << std::endl;
    std::cout << "--help          Display help information" << std::endl;
    std::cout << "--datadir       Specify path to a data directory, overriding the default. This option can be used "
                 "multiple times to add multiple directories. If no data directories are given, the default is to use "
                 "(data/samples/mnist/, data/mnist/)"
              << std::endl;
    std::cout << "--useDLACore=N  Specify a DLA engine for layers that support DLA. Value can range from 0 to n-1, "
                 "where n is the number of DLA engines on the platform."
              << std::endl;
    std::cout << "--int8          Run in Int8 mode." << std::endl;
    std::cout << "--fp16          Run in FP16 mode." << std::endl;
    // FIXME:
    // std::cout << "--saveEngine[-s]        Path to save engine." << std::endl;
    // std::cout << "--loadEngine[-l]        Path to load engine." << std::endl;
int main(int argc, char **argv)
    samplesCommon::Args args;
    bool argsOK = samplesCommon::parseArgs(args, argc, argv);
    if (!argsOK)
        sample::gLogError << "Invalid arguments" << std::endl;
        printHelpInfo();
        return EXIT_FAILURE;
    if (args.help)
        printHelpInfo();
        return EXIT_SUCCESS;
    auto sampleTest = sample::gLogger.defineTest(gSampleName, argc, argv);
    sample::gLogger.reportTestStart(sampleTest);
    SampleOnnxMNIST sample(initializeSampleParams(args));
    sample::gLogInfo << "Building and running a GPU inference engine for Onnx MNIST" << std::endl;
    if (!sample.build())
        return sample::gLogger.reportFail(sampleTest);
    if (!sample.infer())
    return sample::gLogger.reportPass(sampleTest);
I expect that I can load the TensorRT engine to do correctly inference!
Thank you so much!
Environment
TensorRT Version: 7.1
GPU Type: Titan V
Nvidia Driver Version: 450
Baremetal or Container (if container which image + tag):
Using NGC image: nvcr.io/nvidia/tensorrt:20.09-py3
Relevant Files
Please refer to the installation steps from the below link if in case you are missing on anything
However suggested approach is to use TRT NGC containers to avoid any system dependency related issues.
In order to run python sample, make sure TRT python packages are installed while using NGC container.
/opt/tensorrt/python/python_setup.sh
Hi @NVES ,
Thanks for your reply.
  1. I used the NGC in my case. The docker image information was mentioned in my post. So there is no environment setting issue. In addition, my script was also used from /opt/tensorrt/sample.
  2. I have used the TensorRT Python API for a long time to develop a lot. Thanks for your suggestion.
My issue was encountered by using TensorRT C++.
Thank you.
Update:
I am wondering how to get the input and output dimension from the deserializing engine?
Here is a code for standard steps that it converted the onnx model to tensorrt model by builder and network.
So it can get the input dimension from network.
    mEngine = std::shared_ptr<nvinfer1::ICudaEngine>(
        builder->buildEngineWithConfig(*network, *config), samplesCommon::InferDeleter());
    assert(network->getNbInputs() == 1);
    mInputDims = network->getInput(0)->getDimensions();
    assert(mInputDims.nbDims == 4);
    assert(network->getNbOutputs() == 1);
    mOutputDims = network->getOutput(0)->getDimensions();
    assert(mOutputDims.nbDims == 2);
If I don’t go like this way that my script directly deserialize the TRT engine and directly do inference.
However, I don’t know how to get the input and output dimension how the TRT engine.
Is there any way?
Thank you in advance.
BR,
Chieh
Resolved:
Defined by myself.
