[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 256, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_93 for ONNX node: Conv_93
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 215 for ONNX tensor: 215
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_93 [Conv] outputs: [215 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_94 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 215
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_94 [Sigmoid] inputs: [215 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_94 for ONNX node: Sigmoid_94
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 216 for ONNX tensor: 216
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_94 [Sigmoid] outputs: [216 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_95 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 216
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_95 [Mul] inputs: [215 -> (1, 256, 20, 20)], [216 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_95 for ONNX node: Mul_95
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 217 for ONNX tensor: 217
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_95 [Mul] outputs: [217 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Add_96 [Add]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 211
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 217
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Add_96 [Add] inputs: [211 -> (1, 256, 20, 20)], [217 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Add_96 for ONNX node: Add_96
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 218 for ONNX tensor: 218
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Add_96 [Add] outputs: [218 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_97 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 208
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.8.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.8.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_97 [Conv] inputs: [208 -> (1, 512, 20, 20)], [model.8.cv2.conv.weight -> (256, 512, 1, 1)], [model.8.cv2.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 512, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 256
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_97 for ONNX node: Conv_97
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 219 for ONNX tensor: 219
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_97 [Conv] outputs: [219 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_98 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 219
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_98 [Sigmoid] inputs: [219 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_98 for ONNX node: Sigmoid_98
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 220 for ONNX tensor: 220
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_98 [Sigmoid] outputs: [220 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_99 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 220
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_99 [Mul] inputs: [219 -> (1, 256, 20, 20)], [220 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_99 for ONNX node: Mul_99
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 221 for ONNX tensor: 221
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_99 [Mul] outputs: [221 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_100 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 218
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 221
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_100 [Concat] inputs: [218 -> (1, 256, 20, 20)], [221 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_100 for ONNX node: Concat_100
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 222 for ONNX tensor: 222
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_100 [Concat] outputs: [222 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_101 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 222
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.8.cv3.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.8.cv3.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_101 [Conv] inputs: [222 -> (1, 512, 20, 20)], [model.8.cv3.conv.weight -> (512, 512, 1, 1)], [model.8.cv3.conv.bias -> (512)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 512
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 512, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_101 for ONNX node: Conv_101
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 223 for ONNX tensor: 223
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_101 [Conv] outputs: [223 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_102 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 223
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_102 [Sigmoid] inputs: [223 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_102 for ONNX node: Sigmoid_102
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 224 for ONNX tensor: 224
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_102 [Sigmoid] outputs: [224 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_103 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 224
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_103 [Mul] inputs: [223 -> (1, 512, 20, 20)], [224 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_103 for ONNX node: Mul_103
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 225 for ONNX tensor: 225
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_103 [Mul] outputs: [225 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_104 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 225
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.9.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.9.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_104 [Conv] inputs: [225 -> (1, 512, 20, 20)], [model.9.cv1.conv.weight -> (256, 512, 1, 1)], [model.9.cv1.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_104 for ONNX node: Conv_104
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 226 for ONNX tensor: 226
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_104 [Conv] outputs: [226 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_105 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 226
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_105 [Sigmoid] inputs: [226 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_105 for ONNX node: Sigmoid_105
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 227 for ONNX tensor: 227
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_105 [Sigmoid] outputs: [227 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_106 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 227
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_106 [Mul] inputs: [226 -> (1, 256, 20, 20)], [227 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_106 for ONNX node: Mul_106
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 228 for ONNX tensor: 228
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_106 [Mul] outputs: [228 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: MaxPool_107 [MaxPool]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 228
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: MaxPool_107 [MaxPool] inputs: [228 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: MaxPool_107 for ONNX node: MaxPool_107
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 229 for ONNX tensor: 229
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: MaxPool_107 [MaxPool] outputs: [229 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: MaxPool_108 [MaxPool]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 229
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: MaxPool_108 [MaxPool] inputs: [229 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: MaxPool_108 for ONNX node: MaxPool_108
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 230 for ONNX tensor: 230
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: MaxPool_108 [MaxPool] outputs: [230 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: MaxPool_109 [MaxPool]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 230
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: MaxPool_109 [MaxPool] inputs: [230 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: MaxPool_109 for ONNX node: MaxPool_109
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 231 for ONNX tensor: 231
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: MaxPool_109 [MaxPool] outputs: [231 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_110 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 231
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_110 [Concat] inputs: [228 -> (1, 256, 20, 20)], [229 -> (1, 256, 20, 20)], [230 -> (1, 256, 20, 20)], [231 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_110 for ONNX node: Concat_110
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 232 for ONNX tensor: 232
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_110 [Concat] outputs: [232 -> (1, 1024, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_111 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 232
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.9.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.9.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_111 [Conv] inputs: [232 -> (1, 1024, 20, 20)], [model.9.cv2.conv.weight -> (512, 1024, 1, 1)], [model.9.cv2.conv.bias -> (512)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 1024, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_111 for ONNX node: Conv_111
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 233 for ONNX tensor: 233
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_111 [Conv] outputs: [233 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_112 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 233
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_112 [Sigmoid] inputs: [233 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_112 for ONNX node: Sigmoid_112
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 234 for ONNX tensor: 234
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_112 [Sigmoid] outputs: [234 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_113 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 234
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_113 [Mul] inputs: [233 -> (1, 512, 20, 20)], [234 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_113 for ONNX node: Mul_113
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 235 for ONNX tensor: 235
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_113 [Mul] outputs: [235 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_114 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 235
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.10.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.10.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_114 [Conv] inputs: [235 -> (1, 512, 20, 20)], [model.10.conv.weight -> (256, 512, 1, 1)], [model.10.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_114 for ONNX node: Conv_114
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 236 for ONNX tensor: 236
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_114 [Conv] outputs: [236 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_115 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 236
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_115 [Sigmoid] inputs: [236 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_115 for ONNX node: Sigmoid_115
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 237 for ONNX tensor: 237
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_115 [Sigmoid] outputs: [237 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_116 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 237
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_116 [Mul] inputs: [236 -> (1, 256, 20, 20)], [237 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_116 for ONNX node: Mul_116
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 238 for ONNX tensor: 238
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_116 [Mul] outputs: [238 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Resize_117 [Resize]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 238
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 525
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Resize_117 [Resize] inputs: [238 -> (1, 256, 20, 20)], [optional input, not set], [525 -> (4)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Resize_117 for ONNX node: Resize_117
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 243 for ONNX tensor: 243
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Resize_117 [Resize] outputs: [243 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_118 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 243
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 205
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_118 [Concat] inputs: [243 -> (1, 256, 40, 40)], [205 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_118 for ONNX node: Concat_118
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 244 for ONNX tensor: 244
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_118 [Concat] outputs: [244 -> (1, 512, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_119 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 244
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_119 [Conv] inputs: [244 -> (1, 512, 40, 40)], [model.13.cv1.conv.weight -> (128, 512, 1, 1)], [model.13.cv1.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 512, 40, 40)
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 128
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 128, 40, 40)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_119 for ONNX node: Conv_119
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 245 for ONNX tensor: 245
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_119 [Conv] outputs: [245 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_120 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 245
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_120 [Sigmoid] inputs: [245 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_120 for ONNX node: Sigmoid_120
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 246 for ONNX tensor: 246
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_120 [Sigmoid] outputs: [246 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_121 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 246
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_121 [Mul] inputs: [245 -> (1, 128, 40, 40)], [246 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_121 for ONNX node: Mul_121
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 247 for ONNX tensor: 247
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_121 [Mul] outputs: [247 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_122 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 247
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.m.0.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.m.0.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_122 [Conv] inputs: [247 -> (1, 128, 40, 40)], [model.13.m.0.cv1.conv.weight -> (128, 128, 1, 1)], [model.13.m.0.cv1.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 128, 40, 40)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_122 for ONNX node: Conv_122
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 248 for ONNX tensor: 248
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_122 [Conv] outputs: [248 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_123 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 248
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_123 [Sigmoid] inputs: [248 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_123 for ONNX node: Sigmoid_123
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 249 for ONNX tensor: 249
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_123 [Sigmoid] outputs: [249 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_124 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 249
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_124 [Mul] inputs: [248 -> (1, 128, 40, 40)], [249 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_124 for ONNX node: Mul_124
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 250 for ONNX tensor: 250
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_124 [Mul] outputs: [250 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_125 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 250
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.m.0.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.m.0.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_125 [Conv] inputs: [250 -> (1, 128, 40, 40)], [model.13.m.0.cv2.conv.weight -> (128, 128, 3, 3)], [model.13.m.0.cv2.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (1, 1), padding: (1, 1), dilations: (1, 1), numOutputs: 128
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_125 for ONNX node: Conv_125
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 251 for ONNX tensor: 251
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_125 [Conv] outputs: [251 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_126 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 251
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_126 [Sigmoid] inputs: [251 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_126 for ONNX node: Sigmoid_126
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 252 for ONNX tensor: 252
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_126 [Sigmoid] outputs: [252 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_127 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 252
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_127 [Mul] inputs: [251 -> (1, 128, 40, 40)], [252 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_127 for ONNX node: Mul_127
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 253 for ONNX tensor: 253
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_127 [Mul] outputs: [253 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_128 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_128 [Conv] inputs: [244 -> (1, 512, 40, 40)], [model.13.cv2.conv.weight -> (128, 512, 1, 1)], [model.13.cv2.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_128 for ONNX node: Conv_128
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 254 for ONNX tensor: 254
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_128 [Conv] outputs: [254 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_129 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 254
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_129 [Sigmoid] inputs: [254 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_129 for ONNX node: Sigmoid_129
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 255 for ONNX tensor: 255
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_129 [Sigmoid] outputs: [255 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_130 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 255
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_130 [Mul] inputs: [254 -> (1, 128, 40, 40)], [255 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_130 for ONNX node: Mul_130
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 256 for ONNX tensor: 256
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_130 [Mul] outputs: [256 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_131 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 253
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 256
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_131 [Concat] inputs: [253 -> (1, 128, 40, 40)], [256 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_131 for ONNX node: Concat_131
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 257 for ONNX tensor: 257
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_131 [Concat] outputs: [257 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_132 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 257
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.cv3.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.13.cv3.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_132 [Conv] inputs: [257 -> (1, 256, 40, 40)], [model.13.cv3.conv.weight -> (256, 256, 1, 1)], [model.13.cv3.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 256, 40, 40)
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 256, 40, 40)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_132 for ONNX node: Conv_132
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 258 for ONNX tensor: 258
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_132 [Conv] outputs: [258 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_133 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 258
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_133 [Sigmoid] inputs: [258 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_133 for ONNX node: Sigmoid_133
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 259 for ONNX tensor: 259
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_133 [Sigmoid] outputs: [259 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_134 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 259
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_134 [Mul] inputs: [258 -> (1, 256, 40, 40)], [259 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_134 for ONNX node: Mul_134
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 260 for ONNX tensor: 260
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_134 [Mul] outputs: [260 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_135 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 260
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.14.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.14.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_135 [Conv] inputs: [260 -> (1, 256, 40, 40)], [model.14.conv.weight -> (128, 256, 1, 1)], [model.14.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_135 for ONNX node: Conv_135
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 261 for ONNX tensor: 261
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_135 [Conv] outputs: [261 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_136 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 261
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_136 [Sigmoid] inputs: [261 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_136 for ONNX node: Sigmoid_136
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 262 for ONNX tensor: 262
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_136 [Sigmoid] outputs: [262 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_137 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 262
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_137 [Mul] inputs: [261 -> (1, 128, 40, 40)], [262 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_137 for ONNX node: Mul_137
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 263 for ONNX tensor: 263
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_137 [Mul] outputs: [263 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Resize_138 [Resize]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 263
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 526
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Resize_138 [Resize] inputs: [263 -> (1, 128, 40, 40)], [optional input, not set], [526 -> (4)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Resize_138 for ONNX node: Resize_138
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 268 for ONNX tensor: 268
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Resize_138 [Resize] outputs: [268 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_139 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 268
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 171
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_139 [Concat] inputs: [268 -> (1, 128, 80, 80)], [171 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_139 for ONNX node: Concat_139
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 269 for ONNX tensor: 269
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_139 [Concat] outputs: [269 -> (1, 256, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_140 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 269
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_140 [Conv] inputs: [269 -> (1, 256, 80, 80)], [model.17.cv1.conv.weight -> (64, 256, 1, 1)], [model.17.cv1.conv.bias -> (64)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 256, 80, 80)
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 64
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 64, 80, 80)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_140 for ONNX node: Conv_140
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 270 for ONNX tensor: 270
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_140 [Conv] outputs: [270 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_141 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 270
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_141 [Sigmoid] inputs: [270 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_141 for ONNX node: Sigmoid_141
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 271 for ONNX tensor: 271
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_141 [Sigmoid] outputs: [271 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_142 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 271
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_142 [Mul] inputs: [270 -> (1, 64, 80, 80)], [271 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_142 for ONNX node: Mul_142
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 272 for ONNX tensor: 272
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_142 [Mul] outputs: [272 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_143 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 272
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.m.0.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.m.0.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_143 [Conv] inputs: [272 -> (1, 64, 80, 80)], [model.17.m.0.cv1.conv.weight -> (64, 64, 1, 1)], [model.17.m.0.cv1.conv.bias -> (64)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 64, 80, 80)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_143 for ONNX node: Conv_143
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 273 for ONNX tensor: 273
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_143 [Conv] outputs: [273 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_144 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 273
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_144 [Sigmoid] inputs: [273 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_144 for ONNX node: Sigmoid_144
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 274 for ONNX tensor: 274
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_144 [Sigmoid] outputs: [274 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_145 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 274
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_145 [Mul] inputs: [273 -> (1, 64, 80, 80)], [274 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_145 for ONNX node: Mul_145
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 275 for ONNX tensor: 275
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_145 [Mul] outputs: [275 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_146 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 275
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.m.0.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.m.0.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_146 [Conv] inputs: [275 -> (1, 64, 80, 80)], [model.17.m.0.cv2.conv.weight -> (64, 64, 3, 3)], [model.17.m.0.cv2.conv.bias -> (64)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (1, 1), padding: (1, 1), dilations: (1, 1), numOutputs: 64
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_146 for ONNX node: Conv_146
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 276 for ONNX tensor: 276
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_146 [Conv] outputs: [276 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_147 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 276
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_147 [Sigmoid] inputs: [276 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_147 for ONNX node: Sigmoid_147
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 277 for ONNX tensor: 277
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_147 [Sigmoid] outputs: [277 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_148 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 277
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_148 [Mul] inputs: [276 -> (1, 64, 80, 80)], [277 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_148 for ONNX node: Mul_148
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 278 for ONNX tensor: 278
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_148 [Mul] outputs: [278 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_149 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_149 [Conv] inputs: [269 -> (1, 256, 80, 80)], [model.17.cv2.conv.weight -> (64, 256, 1, 1)], [model.17.cv2.conv.bias -> (64)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_149 for ONNX node: Conv_149
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 279 for ONNX tensor: 279
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_149 [Conv] outputs: [279 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_150 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 279
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_150 [Sigmoid] inputs: [279 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_150 for ONNX node: Sigmoid_150
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 280 for ONNX tensor: 280
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_150 [Sigmoid] outputs: [280 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_151 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 280
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_151 [Mul] inputs: [279 -> (1, 64, 80, 80)], [280 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_151 for ONNX node: Mul_151
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 281 for ONNX tensor: 281
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_151 [Mul] outputs: [281 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_152 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 278
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 281
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_152 [Concat] inputs: [278 -> (1, 64, 80, 80)], [281 -> (1, 64, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_152 for ONNX node: Concat_152
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 282 for ONNX tensor: 282
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_152 [Concat] outputs: [282 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_153 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 282
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.cv3.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.17.cv3.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_153 [Conv] inputs: [282 -> (1, 128, 80, 80)], [model.17.cv3.conv.weight -> (128, 128, 1, 1)], [model.17.cv3.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 128, 80, 80)
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 128, 80, 80)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_153 for ONNX node: Conv_153
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 283 for ONNX tensor: 283
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_153 [Conv] outputs: [283 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_154 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 283
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_154 [Sigmoid] inputs: [283 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_154 for ONNX node: Sigmoid_154
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 284 for ONNX tensor: 284
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_154 [Sigmoid] outputs: [284 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_155 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 284
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_155 [Mul] inputs: [283 -> (1, 128, 80, 80)], [284 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_155 for ONNX node: Mul_155
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 285 for ONNX tensor: 285
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_155 [Mul] outputs: [285 -> (1, 128, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_156 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 285
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.18.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.18.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_156 [Conv] inputs: [285 -> (1, 128, 80, 80)], [model.18.conv.weight -> (128, 128, 3, 3)], [model.18.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (2, 2), padding: (1, 1), dilations: (1, 1), numOutputs: 128
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_156 for ONNX node: Conv_156
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 286 for ONNX tensor: 286
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_156 [Conv] outputs: [286 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_157 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 286
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_157 [Sigmoid] inputs: [286 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_157 for ONNX node: Sigmoid_157
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 287 for ONNX tensor: 287
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_157 [Sigmoid] outputs: [287 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_158 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 287
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_158 [Mul] inputs: [286 -> (1, 128, 40, 40)], [287 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_158 for ONNX node: Mul_158
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 288 for ONNX tensor: 288
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_158 [Mul] outputs: [288 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_159 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 288
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_159 [Concat] inputs: [288 -> (1, 128, 40, 40)], [263 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_159 for ONNX node: Concat_159
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 289 for ONNX tensor: 289
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_159 [Concat] outputs: [289 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_160 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 289
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_160 [Conv] inputs: [289 -> (1, 256, 40, 40)], [model.20.cv1.conv.weight -> (128, 256, 1, 1)], [model.20.cv1.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_160 for ONNX node: Conv_160
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 290 for ONNX tensor: 290
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_160 [Conv] outputs: [290 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_161 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 290
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_161 [Sigmoid] inputs: [290 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_161 for ONNX node: Sigmoid_161
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 291 for ONNX tensor: 291
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_161 [Sigmoid] outputs: [291 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_162 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 291
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_162 [Mul] inputs: [290 -> (1, 128, 40, 40)], [291 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_162 for ONNX node: Mul_162
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 292 for ONNX tensor: 292
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_162 [Mul] outputs: [292 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_163 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 292
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.m.0.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.m.0.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_163 [Conv] inputs: [292 -> (1, 128, 40, 40)], [model.20.m.0.cv1.conv.weight -> (128, 128, 1, 1)], [model.20.m.0.cv1.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_163 for ONNX node: Conv_163
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 293 for ONNX tensor: 293
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_163 [Conv] outputs: [293 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_164 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 293
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_164 [Sigmoid] inputs: [293 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_164 for ONNX node: Sigmoid_164
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 294 for ONNX tensor: 294
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_164 [Sigmoid] outputs: [294 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_165 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 294
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_165 [Mul] inputs: [293 -> (1, 128, 40, 40)], [294 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_165 for ONNX node: Mul_165
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 295 for ONNX tensor: 295
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_165 [Mul] outputs: [295 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_166 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 295
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.m.0.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.m.0.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_166 [Conv] inputs: [295 -> (1, 128, 40, 40)], [model.20.m.0.cv2.conv.weight -> (128, 128, 3, 3)], [model.20.m.0.cv2.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_166 for ONNX node: Conv_166
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 296 for ONNX tensor: 296
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_166 [Conv] outputs: [296 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_167 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 296
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_167 [Sigmoid] inputs: [296 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_167 for ONNX node: Sigmoid_167
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 297 for ONNX tensor: 297
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_167 [Sigmoid] outputs: [297 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_168 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 297
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_168 [Mul] inputs: [296 -> (1, 128, 40, 40)], [297 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_168 for ONNX node: Mul_168
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 298 for ONNX tensor: 298
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_168 [Mul] outputs: [298 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_169 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_169 [Conv] inputs: [289 -> (1, 256, 40, 40)], [model.20.cv2.conv.weight -> (128, 256, 1, 1)], [model.20.cv2.conv.bias -> (128)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_169 for ONNX node: Conv_169
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 299 for ONNX tensor: 299
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_169 [Conv] outputs: [299 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_170 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 299
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_170 [Sigmoid] inputs: [299 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_170 for ONNX node: Sigmoid_170
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 300 for ONNX tensor: 300
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_170 [Sigmoid] outputs: [300 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_171 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 300
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_171 [Mul] inputs: [299 -> (1, 128, 40, 40)], [300 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_171 for ONNX node: Mul_171
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 301 for ONNX tensor: 301
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_171 [Mul] outputs: [301 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_172 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 298
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 301
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_172 [Concat] inputs: [298 -> (1, 128, 40, 40)], [301 -> (1, 128, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_172 for ONNX node: Concat_172
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 302 for ONNX tensor: 302
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_172 [Concat] outputs: [302 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_173 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 302
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.cv3.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.20.cv3.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_173 [Conv] inputs: [302 -> (1, 256, 40, 40)], [model.20.cv3.conv.weight -> (256, 256, 1, 1)], [model.20.cv3.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_173 for ONNX node: Conv_173
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 303 for ONNX tensor: 303
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_173 [Conv] outputs: [303 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_174 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 303
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_174 [Sigmoid] inputs: [303 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_174 for ONNX node: Sigmoid_174
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 304 for ONNX tensor: 304
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_174 [Sigmoid] outputs: [304 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_175 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 304
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_175 [Mul] inputs: [303 -> (1, 256, 40, 40)], [304 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_175 for ONNX node: Mul_175
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 305 for ONNX tensor: 305
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_175 [Mul] outputs: [305 -> (1, 256, 40, 40)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_176 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 305
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.21.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.21.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_176 [Conv] inputs: [305 -> (1, 256, 40, 40)], [model.21.conv.weight -> (256, 256, 3, 3)], [model.21.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (2, 2), padding: (1, 1), dilations: (1, 1), numOutputs: 256
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 256, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_176 for ONNX node: Conv_176
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 306 for ONNX tensor: 306
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_176 [Conv] outputs: [306 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_177 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 306
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_177 [Sigmoid] inputs: [306 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_177 for ONNX node: Sigmoid_177
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 307 for ONNX tensor: 307
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_177 [Sigmoid] outputs: [307 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_178 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 307
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_178 [Mul] inputs: [306 -> (1, 256, 20, 20)], [307 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_178 for ONNX node: Mul_178
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 308 for ONNX tensor: 308
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_178 [Mul] outputs: [308 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_179 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 308
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_179 [Concat] inputs: [308 -> (1, 256, 20, 20)], [238 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_179 for ONNX node: Concat_179
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 309 for ONNX tensor: 309
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_179 [Concat] outputs: [309 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_180 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 309
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_180 [Conv] inputs: [309 -> (1, 512, 20, 20)], [model.23.cv1.conv.weight -> (256, 512, 1, 1)], [model.23.cv1.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 512, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 256
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_180 for ONNX node: Conv_180
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 310 for ONNX tensor: 310
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_180 [Conv] outputs: [310 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_181 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 310
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_181 [Sigmoid] inputs: [310 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_181 for ONNX node: Sigmoid_181
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 311 for ONNX tensor: 311
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_181 [Sigmoid] outputs: [311 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_182 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 311
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_182 [Mul] inputs: [310 -> (1, 256, 20, 20)], [311 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_182 for ONNX node: Mul_182
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 312 for ONNX tensor: 312
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_182 [Mul] outputs: [312 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_183 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 312
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.m.0.cv1.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.m.0.cv1.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_183 [Conv] inputs: [312 -> (1, 256, 20, 20)], [model.23.m.0.cv1.conv.weight -> (256, 256, 1, 1)], [model.23.m.0.cv1.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:442: Convolution input dimensions: (1, 256, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_183 for ONNX node: Conv_183
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 313 for ONNX tensor: 313
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_183 [Conv] outputs: [313 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_184 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 313
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_184 [Sigmoid] inputs: [313 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_184 for ONNX node: Sigmoid_184
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 314 for ONNX tensor: 314
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_184 [Sigmoid] outputs: [314 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_185 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 314
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_185 [Mul] inputs: [313 -> (1, 256, 20, 20)], [314 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_185 for ONNX node: Mul_185
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 315 for ONNX tensor: 315
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_185 [Mul] outputs: [315 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_186 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 315
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.m.0.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.m.0.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_186 [Conv] inputs: [315 -> (1, 256, 20, 20)], [model.23.m.0.cv2.conv.weight -> (256, 256, 3, 3)], [model.23.m.0.cv2.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (1, 1), padding: (1, 1), dilations: (1, 1), numOutputs: 256
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_186 for ONNX node: Conv_186
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 316 for ONNX tensor: 316
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_186 [Conv] outputs: [316 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_187 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 316
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_187 [Sigmoid] inputs: [316 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_187 for ONNX node: Sigmoid_187
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 317 for ONNX tensor: 317
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_187 [Sigmoid] outputs: [317 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_188 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 317
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_188 [Mul] inputs: [316 -> (1, 256, 20, 20)], [317 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_188 for ONNX node: Mul_188
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 318 for ONNX tensor: 318
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_188 [Mul] outputs: [318 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_189 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.cv2.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.cv2.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_189 [Conv] inputs: [309 -> (1, 512, 20, 20)], [model.23.cv2.conv.weight -> (256, 512, 1, 1)], [model.23.cv2.conv.bias -> (256)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_189 for ONNX node: Conv_189
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 319 for ONNX tensor: 319
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_189 [Conv] outputs: [319 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_190 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 319
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_190 [Sigmoid] inputs: [319 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_190 for ONNX node: Sigmoid_190
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 320 for ONNX tensor: 320
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_190 [Sigmoid] outputs: [320 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_191 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 320
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_191 [Mul] inputs: [319 -> (1, 256, 20, 20)], [320 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_191 for ONNX node: Mul_191
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 321 for ONNX tensor: 321
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_191 [Mul] outputs: [321 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Concat_192 [Concat]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 318
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 321
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Concat_192 [Concat] inputs: [318 -> (1, 256, 20, 20)], [321 -> (1, 256, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Concat_192 for ONNX node: Concat_192
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 322 for ONNX tensor: 322
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Concat_192 [Concat] outputs: [322 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_193 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 322
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.cv3.conv.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.23.cv3.conv.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_193 [Conv] inputs: [322 -> (1, 512, 20, 20)], [model.23.cv3.conv.weight -> (512, 512, 1, 1)], [model.23.cv3.conv.bias -> (512)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 512
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 512, 20, 20)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_193 for ONNX node: Conv_193
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 323 for ONNX tensor: 323
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_193 [Conv] outputs: [323 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Sigmoid_194 [Sigmoid]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 323
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Sigmoid_194 [Sigmoid] inputs: [323 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Sigmoid_194 for ONNX node: Sigmoid_194
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 324 for ONNX tensor: 324
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Sigmoid_194 [Sigmoid] outputs: [324 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Mul_195 [Mul]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 324
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Mul_195 [Mul] inputs: [323 -> (1, 512, 20, 20)], [324 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Mul_195 for ONNX node: Mul_195
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 325 for ONNX tensor: 325
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Mul_195 [Mul] outputs: [325 -> (1, 512, 20, 20)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Conv_196 [Conv]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.24.m.0.weight
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: model.24.m.0.bias
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Conv_196 [Conv] inputs: [285 -> (1, 128, 80, 80)], [model.24.m.0.weight -> (255, 128, 1, 1)], [model.24.m.0.bias -> (255)],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 255
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:525: Convolution output dimensions: (1, 255, 80, 80)
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Conv_196 for ONNX node: Conv_196
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 326 for ONNX tensor: 326
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Conv_196 [Conv] outputs: [326 -> (1, 255, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Shape_197 [Shape]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 326
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Shape_197 [Shape] inputs: [326 -> (1, 255, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Shape_197 for ONNX node: Shape_197
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 327 for ONNX tensor: 327
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Shape_197 [Shape] outputs: [327 -> (4)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_198 [Constant]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Constant_198 [Constant] inputs:
[03/01/2022-11:12:06] [W] [TRT] onnx2trt_utils.cpp:198: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Constant_198 [Constant] outputs: [328 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Gather_199 [Gather]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 327
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 328
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Gather_199 [Gather] inputs: [327 -> (4)], [328 -> ()],
[03/01/2022-11:12:06] [V] [TRT] builtin_op_importers.cpp:942: Using Gather axis: 0
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Gather_199 for ONNX node: Gather_199
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 329 for ONNX tensor: 329
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Gather_199 [Gather] outputs: [329 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Shape_200 [Shape]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Shape_200 [Shape] inputs: [326 -> (1, 255, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Shape_200 for ONNX node: Shape_200
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 330 for ONNX tensor: 330
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Shape_200 [Shape] outputs: [330 -> (4)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_201 [Constant]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Constant_201 [Constant] inputs:
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Constant_201 [Constant] outputs: [331 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Gather_202 [Gather]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 330
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 331
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Gather_202 [Gather] inputs: [330 -> (4)], [331 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Gather_202 for ONNX node: Gather_202
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 332 for ONNX tensor: 332
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Gather_202 [Gather] outputs: [332 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Shape_203 [Shape]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Shape_203 [Shape] inputs: [326 -> (1, 255, 80, 80)],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Shape_203 for ONNX node: Shape_203
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 333 for ONNX tensor: 333
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Shape_203 [Shape] outputs: [333 -> (4)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_204 [Constant]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Constant_204 [Constant] inputs:
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Constant_204 [Constant] outputs: [334 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Gather_205 [Gather]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 333
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 334
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Gather_205 [Gather] inputs: [333 -> (4)], [334 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:122: Registering layer: Gather_205 for ONNX node: Gather_205
[03/01/2022-11:12:06] [V] [TRT] ImporterContext.hpp:97: Registering tensor: 335 for ONNX tensor: 335
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Gather_205 [Gather] outputs: [335 -> ()],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Constant_206 [Constant]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Constant_206 [Constant] inputs:
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:180: Constant_206 [Constant] outputs: [338 -> (1)],
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:107: Parsing node: Unsqueeze_207 [Unsqueeze]
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 329
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:123: Searching for input: 338
[03/01/2022-11:12:06] [V] [TRT] ModelImporter.cpp:129: Unsqueeze_207 [Unsqueeze] inputs: [329 -> ()], [338 -> (1)],
terminate called after throwing an instance of 'std::out_of_range'
what(): Attribute not found: axes
Aborted (core dumped)
and no error with the engine file
&&&& RUNNING TensorRT.trtexec # ./trtexec --loadEngine=yolov5s.engine --batch=1 --verbose
[03/01/2022-11:28:42] [I] === Model Options ===
[03/01/2022-11:28:42] [I] Format: *
[03/01/2022-11:28:42] [I] Model:
[03/01/2022-11:28:42] [I] Output:
[03/01/2022-11:28:42] [I] === Build Options ===
[03/01/2022-11:28:42] [I] Max batch: 1
[03/01/2022-11:28:42] [I] Workspace: 16 MB
[03/01/2022-11:28:42] [I] minTiming: 1
[03/01/2022-11:28:42] [I] avgTiming: 8
[03/01/2022-11:28:42] [I] Precision: FP32
[03/01/2022-11:28:42] [I] Calibration:
[03/01/2022-11:28:42] [I] Safe mode: Disabled
[03/01/2022-11:28:42] [I] Save engine:
[03/01/2022-11:28:42] [I] Load engine: yolov5s.engine
[03/01/2022-11:28:42] [I] Inputs format: fp32:CHW
[03/01/2022-11:28:42] [I] Outputs format: fp32:CHW
[03/01/2022-11:28:42] [I] Input build shapes: model
[03/01/2022-11:28:42] [I] === System Options ===
[03/01/2022-11:28:42] [I] Device: 0
[03/01/2022-11:28:42] [I] DLACore:
[03/01/2022-11:28:42] [I] Plugins:
[03/01/2022-11:28:42] [I] === Inference Options ===
[03/01/2022-11:28:42] [I] Batch: 1
[03/01/2022-11:28:42] [I] Iterations: 10
[03/01/2022-11:28:42] [I] Duration: 3s (+ 200ms warm up)
[03/01/2022-11:28:42] [I] Sleep time: 0ms
[03/01/2022-11:28:42] [I] Streams: 1
[03/01/2022-11:28:42] [I] ExposeDMA: Disabled
[03/01/2022-11:28:42] [I] Spin-wait: Disabled
[03/01/2022-11:28:42] [I] Multithreading: Disabled
[03/01/2022-11:28:42] [I] CUDA Graph: Disabled
[03/01/2022-11:28:42] [I] Skip inference: Disabled
[03/01/2022-11:28:42] [I] Input inference shapes: model
[03/01/2022-11:28:42] [I] Inputs:
[03/01/2022-11:28:42] [I] === Reporting Options ===
[03/01/2022-11:28:42] [I] Verbose: Enabled
[03/01/2022-11:28:42] [I] Averages: 10 inferences
[03/01/2022-11:28:42] [I] Percentile: 99
[03/01/2022-11:28:42] [I] Dump output: Disabled
[03/01/2022-11:28:42] [I] Profile: Disabled
[03/01/2022-11:28:42] [I] Export timing to JSON file:
[03/01/2022-11:28:42] [I] Export output to JSON file:
[03/01/2022-11:28:42] [I] Export profile to JSON file:
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::GridAnchor_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::NMS_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::Reorg_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::Region_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::Clip_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::LReLU_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::PriorBox_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::Normalize_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::RPROI_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::BatchedNMS_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::FlattenConcat_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::CropAndResize
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::DetectionLayer_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::Proposal
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::ProposalLayer_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::PyramidROIAlign_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::ResizeNearest_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::Split
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::SpecialSlice_TRT
[03/01/2022-11:28:42] [V] [TRT] Plugin creator registration succeeded - ::InstanceNormalization_TRT
[03/01/2022-11:28:43] [V] [TRT] Deserialize required 885216 microseconds.
[03/01/2022-11:28:43] [W] [TRT] Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
[03/01/2022-11:28:43] [W] [TRT] Explicit batch network detected and batch size specified, use enqueue without batch size instead.
[03/01/2022-11:28:47] [I] Warmup completed 34 queries over 200 ms
[03/01/2022-11:28:47] [I] Timing trace has 594 queries over 3.01403 s
[03/01/2022-11:28:47] [I] Trace averages of 10 runs:
[03/01/2022-11:28:47] [I] Average on 10 runs - GPU latency: 5.15921 ms - Host latency: 6.88754 ms (end to end 9.96947 ms)
[03/01/2022-11:28:47] [I] Host latency
[03/01/2022-11:28:47] [I] min: 6.26825 ms (end to end 8.1282 ms)
[03/01/2022-11:28:47] [I] max: 8.10938 ms (end to end 11.0569 ms)
[03/01/2022-11:28:47] [I] mean: 6.7875 ms (end to end 9.81555 ms)
[03/01/2022-11:28:47] [I] median: 6.82288 ms (end to end 9.77625 ms)
[03/01/2022-11:28:47] [I] percentile: 7.53218 ms at 99% (end to end 10.8849 ms at 99%)
[03/01/2022-11:28:47] [I] throughput: 197.079 qps
[03/01/2022-11:28:47] [I] walltime: 3.01403 s
[03/01/2022-11:28:47] [I] GPU Compute
[03/01/2022-11:28:47] [I] min: 4.54861 ms
[03/01/2022-11:28:47] [I] max: 6.4043 ms
[03/01/2022-11:28:47] [I] mean: 5.05268 ms
[03/01/2022-11:28:47] [I] median: 5.08521 ms
[03/01/2022-11:28:47] [I] percentile: 5.7804 ms at 99%
[03/01/2022-11:28:47] [I] total compute time: 3.00129 s
&&&& PASSED TensorRT.trtexec # ./trtexec --loadEngine=yolov5s.engine --batch=1 --verbose
BTW, I’ve already tested it on python, and everything worked fine.
Thanks for your reply. :)
