There is no log about the error. However whole output to terminal is as below.
ImporterContext.hpp:97: Registering tensor: 091_convolutional for ONNX tensor: 091_convolutional
ModelImporter.cpp:180: 091_convolutional [Conv] outputs: [091_convolutional -> (1, 512, 38, 38)],
ModelImporter.cpp:107: Parsing node: 091_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 091_convolutional
ModelImporter.cpp:123: Searching for input: 091_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 091_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 091_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 091_convolutional_bn_var
ModelImporter.cpp:129: 091_convolutional_bn [BatchNormalization] inputs: [091_convolutional -> (1, 512, 38, 38)], [091_convolutional_bn_scale -> (512)], [091_convolutional_bn_bias -> (512)], [091_convolutional_bn_mean -> (512)], [091_convolutional_bn_var -> (512)],
ImporterContext.hpp:122: Registering layer: 091_convolutional_bn for ONNX node: 091_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 091_convolutional_bn for ONNX tensor: 091_convolutional_bn
ModelImporter.cpp:180: 091_convolutional_bn [BatchNormalization] outputs: [091_convolutional_bn -> (1, 512, 38, 38)],
ModelImporter.cpp:107: Parsing node: 091_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 091_convolutional_lrelu [LeakyRelu] inputs: [091_convolutional_bn -> (1, 512, 38, 38)],
ImporterContext.hpp:122: Registering layer: 091_convolutional_lrelu for ONNX node: 091_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 091_convolutional_lrelu for ONNX tensor: 091_convolutional_lrelu
ModelImporter.cpp:180: 091_convolutional_lrelu [LeakyRelu] outputs: [091_convolutional_lrelu -> (1, 512, 38, 38)],
ModelImporter.cpp:107: Parsing node: 092_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 091_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 092_convolutional_conv_weights
ModelImporter.cpp:129: 092_convolutional [Conv] inputs: [091_convolutional_lrelu -> (1, 512, 38, 38)], [092_convolutional_conv_weights -> (256, 512, 1, 1)],
builtin_op_importers.cpp:442: Convolution input dimensions: (1, 512, 38, 38)
Bias weights are not set yet. Bias weights can be set using setInput(2, bias_tensor) API call.
builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 256
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 256, 38, 38)
ImporterContext.hpp:122: Registering layer: 092_convolutional for ONNX node: 092_convolutional
ImporterContext.hpp:97: Registering tensor: 092_convolutional for ONNX tensor: 092_convolutional
ModelImporter.cpp:180: 092_convolutional [Conv] outputs: [092_convolutional -> (1, 256, 38, 38)],
ModelImporter.cpp:107: Parsing node: 092_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 092_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 092_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 092_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 092_convolutional_bn_var
ModelImporter.cpp:129: 092_convolutional_bn [BatchNormalization] inputs: [092_convolutional -> (1, 256, 38, 38)], [092_convolutional_bn_scale -> (256)], [092_convolutional_bn_bias -> (256)], [092_convolutional_bn_mean -> (256)], [092_convolutional_bn_var -> (256)],
ImporterContext.hpp:122: Registering layer: 092_convolutional_bn for ONNX node: 092_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 092_convolutional_bn for ONNX tensor: 092_convolutional_bn
ModelImporter.cpp:180: 092_convolutional_bn [BatchNormalization] outputs: [092_convolutional_bn -> (1, 256, 38, 38)],
ModelImporter.cpp:107: Parsing node: 092_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 092_convolutional_lrelu [LeakyRelu] inputs: [092_convolutional_bn -> (1, 256, 38, 38)],
ImporterContext.hpp:122: Registering layer: 092_convolutional_lrelu for ONNX node: 092_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 092_convolutional_lrelu for ONNX tensor: 092_convolutional_lrelu
ModelImporter.cpp:180: 092_convolutional_lrelu [LeakyRelu] outputs: [092_convolutional_lrelu -> (1, 256, 38, 38)],
ModelImporter.cpp:107: Parsing node: 093_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 092_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 093_convolutional_conv_weights
ModelImporter.cpp:129: 093_convolutional [Conv] inputs: [092_convolutional_lrelu -> (1, 256, 38, 38)], [093_convolutional_conv_weights -> (512, 256, 3, 3)],
builtin_op_importers.cpp:442: Convolution input dimensions: (1, 256, 38, 38)
builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 512
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 512, 38, 38)
ImporterContext.hpp:122: Registering layer: 093_convolutional for ONNX node: 093_convolutional
ImporterContext.hpp:97: Registering tensor: 093_convolutional for ONNX tensor: 093_convolutional
ModelImporter.cpp:180: 093_convolutional [Conv] outputs: [093_convolutional -> (1, 512, 38, 38)],
ModelImporter.cpp:107: Parsing node: 093_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 093_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 093_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 093_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 093_convolutional_bn_var
ModelImporter.cpp:129: 093_convolutional_bn [BatchNormalization] inputs: [093_convolutional -> (1, 512, 38, 38)], [093_convolutional_bn_scale -> (512)], [093_convolutional_bn_bias -> (512)], [093_convolutional_bn_mean -> (512)], [093_convolutional_bn_var -> (512)],
ImporterContext.hpp:122: Registering layer: 093_convolutional_bn for ONNX node: 093_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 093_convolutional_bn for ONNX tensor: 093_convolutional_bn
ModelImporter.cpp:180: 093_convolutional_bn [BatchNormalization] outputs: [093_convolutional_bn -> (1, 512, 38, 38)],
ModelImporter.cpp:107: Parsing node: 093_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 093_convolutional_lrelu [LeakyRelu] inputs: [093_convolutional_bn -> (1, 512, 38, 38)],
ImporterContext.hpp:122: Registering layer: 093_convolutional_lrelu for ONNX node: 093_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 093_convolutional_lrelu for ONNX tensor: 093_convolutional_lrelu
ModelImporter.cpp:180: 093_convolutional_lrelu [LeakyRelu] outputs: [093_convolutional_lrelu -> (1, 512, 38, 38)],
ModelImporter.cpp:107: Parsing node: 094_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 093_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 094_convolutional_conv_weights
ModelImporter.cpp:123: Searching for input: 094_convolutional_conv_bias
ModelImporter.cpp:129: 094_convolutional [Conv] inputs: [093_convolutional_lrelu -> (1, 512, 38, 38)], [094_convolutional_conv_weights -> (255, 512, 1, 1)], [094_convolutional_conv_bias -> (255)],
builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 255
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 255, 38, 38)
ImporterContext.hpp:122: Registering layer: 094_convolutional for ONNX node: 094_convolutional
ImporterContext.hpp:97: Registering tensor: 094_convolutional_1 for ONNX tensor: 094_convolutional
ModelImporter.cpp:180: 094_convolutional [Conv] outputs: [094_convolutional -> (1, 255, 38, 38)],
ModelImporter.cpp:107: Parsing node: 097_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 097_convolutional_conv_weights
ModelImporter.cpp:129: 097_convolutional [Conv] inputs: [092_convolutional_lrelu -> (1, 256, 38, 38)], [097_convolutional_conv_weights -> (128, 256, 1, 1)],
builtin_op_importers.cpp:524: Using kernel: (1, 1), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 128
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 128, 38, 38)
ImporterContext.hpp:122: Registering layer: 097_convolutional for ONNX node: 097_convolutional
ImporterContext.hpp:97: Registering tensor: 097_convolutional for ONNX tensor: 097_convolutional
ModelImporter.cpp:180: 097_convolutional [Conv] outputs: [097_convolutional -> (1, 128, 38, 38)],
ModelImporter.cpp:107: Parsing node: 097_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 097_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 097_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 097_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 097_convolutional_bn_var
ModelImporter.cpp:129: 097_convolutional_bn [BatchNormalization] inputs: [097_convolutional -> (1, 128, 38, 38)], [097_convolutional_bn_scale -> (128)], [097_convolutional_bn_bias -> (128)], [097_convolutional_bn_mean -> (128)], [097_convolutional_bn_var -> (128)],
ImporterContext.hpp:122: Registering layer: 097_convolutional_bn for ONNX node: 097_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 097_convolutional_bn for ONNX tensor: 097_convolutional_bn
ModelImporter.cpp:180: 097_convolutional_bn [BatchNormalization] outputs: [097_convolutional_bn -> (1, 128, 38, 38)],
ModelImporter.cpp:107: Parsing node: 097_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 097_convolutional_lrelu [LeakyRelu] inputs: [097_convolutional_bn -> (1, 128, 38, 38)],
ImporterContext.hpp:122: Registering layer: 097_convolutional_lrelu for ONNX node: 097_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 097_convolutional_lrelu for ONNX tensor: 097_convolutional_lrelu
ModelImporter.cpp:180: 097_convolutional_lrelu [LeakyRelu] outputs: [097_convolutional_lrelu -> (1, 128, 38, 38)],
ModelImporter.cpp:107: Parsing node: 098_upsample [Resize]
ModelImporter.cpp:123: Searching for input: 097_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 098_upsample_roi
ModelImporter.cpp:123: Searching for input: 098_upsample_scale
ModelImporter.cpp:129: 098_upsample [Resize] inputs: [097_convolutional_lrelu -> (1, 128, 38, 38)], [098_upsample_roi -> (4)], [098_upsample_scale -> (4)],
ImporterContext.hpp:122: Registering layer: 098_upsample for ONNX node: 098_upsample
ImporterContext.hpp:97: Registering tensor: 098_upsample for ONNX tensor: 098_upsample
ModelImporter.cpp:180: 098_upsample [Resize] outputs: [098_upsample -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 099_route [Concat]
ModelImporter.cpp:123: Searching for input: 037_shortcut
ModelImporter.cpp:129: 099_route [Concat] inputs: [098_upsample -> (1, 128, 76, 76)], [037_shortcut -> (1, 256, 76, 76)],
ImporterContext.hpp:122: Registering layer: 099_route for ONNX node: 099_route
ImporterContext.hpp:97: Registering tensor: 099_route for ONNX tensor: 099_route
ModelImporter.cpp:180: 099_route [Concat] outputs: [099_route -> (1, 384, 76, 76)],
ModelImporter.cpp:107: Parsing node: 100_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 099_route
ModelImporter.cpp:123: Searching for input: 100_convolutional_conv_weights
ModelImporter.cpp:129: 100_convolutional [Conv] inputs: [099_route -> (1, 384, 76, 76)], [100_convolutional_conv_weights -> (128, 384, 1, 1)],
builtin_op_importers.cpp:442: Convolution input dimensions: (1, 384, 76, 76)
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 128, 76, 76)
ImporterContext.hpp:122: Registering layer: 100_convolutional for ONNX node: 100_convolutional
ImporterContext.hpp:97: Registering tensor: 100_convolutional for ONNX tensor: 100_convolutional
ModelImporter.cpp:180: 100_convolutional [Conv] outputs: [100_convolutional -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 100_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 100_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 100_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 100_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 100_convolutional_bn_var
ModelImporter.cpp:129: 100_convolutional_bn [BatchNormalization] inputs: [100_convolutional -> (1, 128, 76, 76)], [100_convolutional_bn_scale -> (128)], [100_convolutional_bn_bias -> (128)], [100_convolutional_bn_mean -> (128)], [100_convolutional_bn_var -> (128)],
ImporterContext.hpp:122: Registering layer: 100_convolutional_bn for ONNX node: 100_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 100_convolutional_bn for ONNX tensor: 100_convolutional_bn
ModelImporter.cpp:180: 100_convolutional_bn [BatchNormalization] outputs: [100_convolutional_bn -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 100_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 100_convolutional_lrelu [LeakyRelu] inputs: [100_convolutional_bn -> (1, 128, 76, 76)],
ImporterContext.hpp:122: Registering layer: 100_convolutional_lrelu for ONNX node: 100_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 100_convolutional_lrelu for ONNX tensor: 100_convolutional_lrelu
ModelImporter.cpp:180: 100_convolutional_lrelu [LeakyRelu] outputs: [100_convolutional_lrelu -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 101_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 100_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 101_convolutional_conv_weights
ModelImporter.cpp:129: 101_convolutional [Conv] inputs: [100_convolutional_lrelu -> (1, 128, 76, 76)], [101_convolutional_conv_weights -> (256, 128, 3, 3)],
builtin_op_importers.cpp:442: Convolution input dimensions: (1, 128, 76, 76)
builtin_op_importers.cpp:524: Using kernel: (3, 3), strides: (1, 1), padding: (0, 0), dilations: (1, 1), numOutputs: 256
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 256, 76, 76)
ImporterContext.hpp:122: Registering layer: 101_convolutional for ONNX node: 101_convolutional
ImporterContext.hpp:97: Registering tensor: 101_convolutional for ONNX tensor: 101_convolutional
ModelImporter.cpp:180: 101_convolutional [Conv] outputs: [101_convolutional -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 101_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 101_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 101_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 101_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 101_convolutional_bn_var
ModelImporter.cpp:129: 101_convolutional_bn [BatchNormalization] inputs: [101_convolutional -> (1, 256, 76, 76)], [101_convolutional_bn_scale -> (256)], [101_convolutional_bn_bias -> (256)], [101_convolutional_bn_mean -> (256)], [101_convolutional_bn_var -> (256)],
ImporterContext.hpp:122: Registering layer: 101_convolutional_bn for ONNX node: 101_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 101_convolutional_bn for ONNX tensor: 101_convolutional_bn
ModelImporter.cpp:180: 101_convolutional_bn [BatchNormalization] outputs: [101_convolutional_bn -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 101_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 101_convolutional_lrelu [LeakyRelu] inputs: [101_convolutional_bn -> (1, 256, 76, 76)],
ImporterContext.hpp:122: Registering layer: 101_convolutional_lrelu for ONNX node: 101_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 101_convolutional_lrelu for ONNX tensor: 101_convolutional_lrelu
ModelImporter.cpp:180: 101_convolutional_lrelu [LeakyRelu] outputs: [101_convolutional_lrelu -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 102_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 101_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 102_convolutional_conv_weights
ModelImporter.cpp:129: 102_convolutional [Conv] inputs: [101_convolutional_lrelu -> (1, 256, 76, 76)], [102_convolutional_conv_weights -> (128, 256, 1, 1)],
builtin_op_importers.cpp:442: Convolution input dimensions: (1, 256, 76, 76)
ImporterContext.hpp:122: Registering layer: 102_convolutional for ONNX node: 102_convolutional
ImporterContext.hpp:97: Registering tensor: 102_convolutional for ONNX tensor: 102_convolutional
ModelImporter.cpp:180: 102_convolutional [Conv] outputs: [102_convolutional -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 102_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 102_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 102_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 102_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 102_convolutional_bn_var
ModelImporter.cpp:129: 102_convolutional_bn [BatchNormalization] inputs: [102_convolutional -> (1, 128, 76, 76)], [102_convolutional_bn_scale -> (128)], [102_convolutional_bn_bias -> (128)], [102_convolutional_bn_mean -> (128)], [102_convolutional_bn_var -> (128)],
ImporterContext.hpp:122: Registering layer: 102_convolutional_bn for ONNX node: 102_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 102_convolutional_bn for ONNX tensor: 102_convolutional_bn
ModelImporter.cpp:180: 102_convolutional_bn [BatchNormalization] outputs: [102_convolutional_bn -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 102_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 102_convolutional_lrelu [LeakyRelu] inputs: [102_convolutional_bn -> (1, 128, 76, 76)],
ImporterContext.hpp:122: Registering layer: 102_convolutional_lrelu for ONNX node: 102_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 102_convolutional_lrelu for ONNX tensor: 102_convolutional_lrelu
ModelImporter.cpp:180: 102_convolutional_lrelu [LeakyRelu] outputs: [102_convolutional_lrelu -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 103_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 102_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 103_convolutional_conv_weights
ModelImporter.cpp:129: 103_convolutional [Conv] inputs: [102_convolutional_lrelu -> (1, 128, 76, 76)], [103_convolutional_conv_weights -> (256, 128, 3, 3)],
ImporterContext.hpp:122: Registering layer: 103_convolutional for ONNX node: 103_convolutional
ImporterContext.hpp:97: Registering tensor: 103_convolutional for ONNX tensor: 103_convolutional
ModelImporter.cpp:180: 103_convolutional [Conv] outputs: [103_convolutional -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 103_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 103_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 103_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 103_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 103_convolutional_bn_var
ModelImporter.cpp:129: 103_convolutional_bn [BatchNormalization] inputs: [103_convolutional -> (1, 256, 76, 76)], [103_convolutional_bn_scale -> (256)], [103_convolutional_bn_bias -> (256)], [103_convolutional_bn_mean -> (256)], [103_convolutional_bn_var -> (256)],
ImporterContext.hpp:122: Registering layer: 103_convolutional_bn for ONNX node: 103_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 103_convolutional_bn for ONNX tensor: 103_convolutional_bn
ModelImporter.cpp:180: 103_convolutional_bn [BatchNormalization] outputs: [103_convolutional_bn -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 103_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 103_convolutional_lrelu [LeakyRelu] inputs: [103_convolutional_bn -> (1, 256, 76, 76)],
ImporterContext.hpp:122: Registering layer: 103_convolutional_lrelu for ONNX node: 103_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 103_convolutional_lrelu for ONNX tensor: 103_convolutional_lrelu
ModelImporter.cpp:180: 103_convolutional_lrelu [LeakyRelu] outputs: [103_convolutional_lrelu -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 104_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 103_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 104_convolutional_conv_weights
ModelImporter.cpp:129: 104_convolutional [Conv] inputs: [103_convolutional_lrelu -> (1, 256, 76, 76)], [104_convolutional_conv_weights -> (128, 256, 1, 1)],
ImporterContext.hpp:122: Registering layer: 104_convolutional for ONNX node: 104_convolutional
ImporterContext.hpp:97: Registering tensor: 104_convolutional for ONNX tensor: 104_convolutional
ModelImporter.cpp:180: 104_convolutional [Conv] outputs: [104_convolutional -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 104_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 104_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 104_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 104_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 104_convolutional_bn_var
ModelImporter.cpp:129: 104_convolutional_bn [BatchNormalization] inputs: [104_convolutional -> (1, 128, 76, 76)], [104_convolutional_bn_scale -> (128)], [104_convolutional_bn_bias -> (128)], [104_convolutional_bn_mean -> (128)], [104_convolutional_bn_var -> (128)],
ImporterContext.hpp:122: Registering layer: 104_convolutional_bn for ONNX node: 104_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 104_convolutional_bn for ONNX tensor: 104_convolutional_bn
ModelImporter.cpp:180: 104_convolutional_bn [BatchNormalization] outputs: [104_convolutional_bn -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 104_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 104_convolutional_lrelu [LeakyRelu] inputs: [104_convolutional_bn -> (1, 128, 76, 76)],
ImporterContext.hpp:122: Registering layer: 104_convolutional_lrelu for ONNX node: 104_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 104_convolutional_lrelu for ONNX tensor: 104_convolutional_lrelu
ModelImporter.cpp:180: 104_convolutional_lrelu [LeakyRelu] outputs: [104_convolutional_lrelu -> (1, 128, 76, 76)],
ModelImporter.cpp:107: Parsing node: 105_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 104_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 105_convolutional_conv_weights
ModelImporter.cpp:129: 105_convolutional [Conv] inputs: [104_convolutional_lrelu -> (1, 128, 76, 76)], [105_convolutional_conv_weights -> (256, 128, 3, 3)],
ImporterContext.hpp:122: Registering layer: 105_convolutional for ONNX node: 105_convolutional
ImporterContext.hpp:97: Registering tensor: 105_convolutional for ONNX tensor: 105_convolutional
ModelImporter.cpp:180: 105_convolutional [Conv] outputs: [105_convolutional -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 105_convolutional_bn [BatchNormalization]
ModelImporter.cpp:123: Searching for input: 105_convolutional_bn_scale
ModelImporter.cpp:123: Searching for input: 105_convolutional_bn_bias
ModelImporter.cpp:123: Searching for input: 105_convolutional_bn_mean
ModelImporter.cpp:123: Searching for input: 105_convolutional_bn_var
ModelImporter.cpp:129: 105_convolutional_bn [BatchNormalization] inputs: [105_convolutional -> (1, 256, 76, 76)], [105_convolutional_bn_scale -> (256)], [105_convolutional_bn_bias -> (256)], [105_convolutional_bn_mean -> (256)], [105_convolutional_bn_var -> (256)],
ImporterContext.hpp:122: Registering layer: 105_convolutional_bn for ONNX node: 105_convolutional_bn
ImporterContext.hpp:97: Registering tensor: 105_convolutional_bn for ONNX tensor: 105_convolutional_bn
ModelImporter.cpp:180: 105_convolutional_bn [BatchNormalization] outputs: [105_convolutional_bn -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 105_convolutional_lrelu [LeakyRelu]
ModelImporter.cpp:129: 105_convolutional_lrelu [LeakyRelu] inputs: [105_convolutional_bn -> (1, 256, 76, 76)],
ImporterContext.hpp:122: Registering layer: 105_convolutional_lrelu for ONNX node: 105_convolutional_lrelu
ImporterContext.hpp:97: Registering tensor: 105_convolutional_lrelu for ONNX tensor: 105_convolutional_lrelu
ModelImporter.cpp:180: 105_convolutional_lrelu [LeakyRelu] outputs: [105_convolutional_lrelu -> (1, 256, 76, 76)],
ModelImporter.cpp:107: Parsing node: 106_convolutional [Conv]
ModelImporter.cpp:123: Searching for input: 105_convolutional_lrelu
ModelImporter.cpp:123: Searching for input: 106_convolutional_conv_weights
ModelImporter.cpp:123: Searching for input: 106_convolutional_conv_bias
ModelImporter.cpp:129: 106_convolutional [Conv] inputs: [105_convolutional_lrelu -> (1, 256, 76, 76)], [106_convolutional_conv_weights -> (255, 256, 1, 1)], [106_convolutional_conv_bias -> (255)],
builtin_op_importers.cpp:525: Convolution output dimensions: (1, 255, 76, 76)
ImporterContext.hpp:122: Registering layer: 106_convolutional for ONNX node: 106_convolutional
ImporterContext.hpp:97: Registering tensor: 106_convolutional_1 for ONNX tensor: 106_convolutional
ModelImporter.cpp:180: 106_convolutional [Conv] outputs: [106_convolutional -> (1, 255, 76, 76)],
ModelImporter.cpp:494: Marking 082_convolutional_1 as output: 082_convolutional
ModelImporter.cpp:494: Marking 094_convolutional_1 as output: 094_convolutional
ModelImporter.cpp:494: Marking 106_convolutional_1 as output: 106_convolutional
----- Parsing of ONNX model /home/orcun/Main.Drive/src/perception/object_recognition/detection/tensorrt_yolo/data/yolov3.onnx is Done ----
Applying optimizations and building TRT CUDA engine...
Assertion failed: dims.d[i] >= 1
../builder/cudnnBuilderGraph.cpp:780
Aborting...
../builder/cudnnBuilderGraph.cpp (780) - Assertion Error in checkDimsSanity: 0 (dims.d[i] >= 1)
builder->buildEngineWithConfig does not log anyting even though it is using the same logger as networkParser and etc.
