Inference error at engine.cpp::enqueue::293
Ubuntu 16.04 LTS
GPU type:1050Ti
nvidia driver version:390.87
CUDA version:9.0
CUDNN version:7.13
Python version:3.5
TensorRT version: 5.0
I am new to TensorRT. When learning the offical sample onnx_resnet50.py,I change some lines and use my own onnx model like this:
from PIL import Image
import numpy as np
import pycuda.driver as cuda
import pycuda.autoinit
import tensorrt as trt
import sys, os
sys.path.insert(1, os.path.join(sys.path[0], ".."))
import common
class ModelData(object):
    MODEL_PATH = "paf.proto"
    INPUT_SHAPE = (3, 368, 368)
    DTYPE = trt.float32
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
def allocate_buffers(engine):
    h_input = cuda.pagelocked_empty(trt.volume(engine.get_binding_shape(0)), dtype=trt.nptype(ModelData.DTYPE))
    h_output = cuda.pagelocked_empty(trt.volume(engine.get_binding_shape(1)), dtype=trt.nptype(ModelData.DTYPE))
    d_input = cuda.mem_alloc(h_input.nbytes)
    d_output = cuda.mem_alloc(h_output.nbytes)
    stream = cuda.Stream()
    return h_input, d_input, h_output, d_output, stream
def do_inference(context, h_input, d_input, h_output, d_output, stream):
    cuda.memcpy_htod_async(d_input, h_input, stream)
    context.execute_async(bindings=[int(d_input), int(d_output)], stream_handle=stream.handle)
    cuda.memcpy_dtoh_async(h_output, d_output, stream)
    stream.synchronize()
def build_engine_onnx(model_file):
    with trt.Builder(TRT_LOGGER) as builder, builder.create_network() as network, trt.OnnxParser(network,
        TRT_LOGGER) as parser:
        builder.max_workspace_size = common.GiB(1)
        with open(model_file, 'rb') as model:
            parser.parse(model.read())
        return builder.build_cuda_engine(network)
def load_normalized_test_case(test_image, pagelocked_buffer):
    def normalize_image(image):
        c, h, w = ModelData.INPUT_SHAPE
        image_arr = np.asarray(image.resize((w, h), Image.ANTIALIAS)).transpose([2, 0, 1]).astype(
            trt.nptype(ModelData.DTYPE)).ravel()
        return (image_arr / 255.0 - 0.45) / 0.225
    np.copyto(pagelocked_buffer, normalize_image(Image.open(test_image)))
    return test_image
def main():
    onnx_model_file = 'paf.proto'
    with build_engine_onnx(onnx_model_file) as engine:
        h_input, d_input, h_output, d_output, stream = allocate_buffers(engine)
        with engine.create_execution_context() as context:
            test_image='/home/test1050/Desktop/0.506.jpg'
            test_case = load_normalized_test_case(test_image, h_input)
if __name__ == '__main__':
    main()
The error is :[TensorRT] ERROR: Parameter check failed at: engine.cpp::enqueue::293, condition: bindings != nullptr
Same error!!! Has anyone solved it yet?
can you share your onnx model “paf.proto”?
Same Error, PyTorch model → onnx → trt, failed to inference. Sorry unable to share it’s company’s property. Both TensorRT4 & TensortRT5 have this problem.
Error:
[TensorRT] ERROR: Parameter check failed at: engine.cpp::enqueue::295, condition: bindings[x] != nullptr
Ubuntu 16.04 LTS
GPU type:TITAN V
CUDA version:9.0
CUDNN version:7.42
Python version:2.7
I have the same problem too! And I used the caffeparser to translate the model.
Except the problem above, sometimes it may print error messages like this :
Assertion failed: size_t(params.srcPtr) % 4 == 0 && s
cuda/tiledPoolingLauncher.cuh:1164
Here is my deploy.prototxt:
layer {
	top: "res4b2_branch2a"
	bottom: "res4b2_branch2a"
	type: "ReLU"
layer {
	top: "res4b2_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b2_branch2b"
	type: "BatchNorm"
	batch_norm_param {
		use_global_stats: true
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b2_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b2_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b1"
	top: "res4b2"
	type: "Eltwise"
layer {
	bottom: "res4b2"
	top: "res4b2"
	type: "ReLU"
layer {
	bottom: "res4b2"
	top: "res4b3_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b3_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b3_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b3_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b3_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b3_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b2"
	top: "res4b3"
	type: "Eltwise"
layer {
	bottom: "res4b3"
	top: "res4b3"
	type: "ReLU"
layer {
	bottom: "res4b3"
	top: "res4b4_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b4_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b4_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b4_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b4_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b4_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b3"
	top: "res4b4"
	type: "Eltwise"
layer {
	bottom: "res4b4"
	top: "res4b4"
	type: "ReLU"
layer {
	bottom: "res4b4"
	top: "res4b5_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b5_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b5_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b5_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b5_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b5_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b4"
	top: "res4b5"
	type: "Eltwise"
layer {
	bottom: "res4b5"
	top: "res4b5"
	type: "ReLU"
layer {
	bottom: "res4b5"
	top: "res4b6_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b6_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b6_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b6_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b6_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b6_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b5"
	top: "res4b6"
	type: "Eltwise"
layer {
	bottom: "res4b6"
	top: "res4b6"
	type: "ReLU"
layer {
	bottom: "res4b6"
	top: "res4b7_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b7_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b7_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b7_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b7_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b7_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b6"
	top: "res4b7"
	type: "Eltwise"
layer {
	bottom: "res4b7"
	top: "res4b7"
	type: "ReLU"
layer {
	bottom: "res4b7"
	top: "res4b8_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b8_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b8_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b8_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b8_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b8_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b7"
	top: "res4b8"
	type: "Eltwise"
layer {
	bottom: "res4b8"
	top: "res4b8"
	type: "ReLU"
layer {
	bottom: "res4b8"
	top: "res4b9_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b9_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b9_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b9_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b9_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b9_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b8"
	top: "res4b9"
	type: "Eltwise"
layer {
	bottom: "res4b9"
	top: "res4b9"
	type: "ReLU"
layer {
	bottom: "res4b9"
	top: "res4b10_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b10_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b10_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b10_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b10_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b10_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b9"
	top: "res4b10"
	type: "Eltwise"
layer {
	bottom: "res4b10"
	top: "res4b10"
	type: "ReLU"
layer {
	bottom: "res4b10"
	top: "res4b11_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b11_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b11_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b11_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b11_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b11_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b10"
	top: "res4b11"
	type: "Eltwise"
layer {
	bottom: "res4b11"
	top: "res4b11"
	type: "ReLU"
layer {
	bottom: "res4b11"
	top: "res4b12_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b12_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b12_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b12_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b12_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b12_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b11"
	top: "res4b12"
	type: "Eltwise"
layer {
	bottom: "res4b12"
	top: "res4b12"
	type: "ReLU"
layer {
	bottom: "res4b12"
	top: "res4b13_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b13_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b13_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b13_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b13_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b13_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b12"
	top: "res4b13"
	type: "Eltwise"
layer {
	bottom: "res4b13"
	top: "res4b13"
	type: "ReLU"
layer {
	bottom: "res4b13"
	top: "res4b14_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b14_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b14_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b14_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b14_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b14_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b13"
	top: "res4b14"
	type: "Eltwise"
layer {
	bottom: "res4b14"
	top: "res4b14"
	type: "ReLU"
layer {
	bottom: "res4b14"
	top: "res4b15_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b15_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b15_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b15_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b15_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b15_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b14"
	top: "res4b15"
	type: "Eltwise"
layer {
	bottom: "res4b15"
	top: "res4b15"
	type: "ReLU"
layer {
	bottom: "res4b15"
	top: "res4b16_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b16_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b16_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b16_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b16_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b16_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b15"
	top: "res4b16"
	type: "Eltwise"
layer {
	bottom: "res4b16"
	top: "res4b16"
	type: "ReLU"
layer {
	bottom: "res4b16"
	top: "res4b17_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b17_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b17_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b17_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b17_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b17_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b16"
	top: "res4b17"
	type: "Eltwise"
layer {
	bottom: "res4b17"
	top: "res4b17"
	type: "ReLU"
layer {
	bottom: "res4b17"
	top: "res4b18_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b18_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b18_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b18_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b18_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b18_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b17"
	top: "res4b18"
	type: "Eltwise"
layer {
	bottom: "res4b18"
	top: "res4b18"
	type: "ReLU"
layer {
	bottom: "res4b18"
	top: "res4b19_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b19_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b19_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b19_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b19_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b19_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b18"
	top: "res4b19"
	type: "Eltwise"
layer {
	bottom: "res4b19"
	top: "res4b19"
	type: "ReLU"
layer {
	bottom: "res4b19"
	top: "res4b20_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b20_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b20_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b20_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b20_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b20_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b19"
	top: "res4b20"
	type: "Eltwise"
layer {
	bottom: "res4b20"
	top: "res4b20"
	type: "ReLU"
layer {
	bottom: "res4b20"
	top: "res4b21_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b21_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b21_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b21_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b21_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b21_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b20"
	top: "res4b21"
	type: "Eltwise"
layer {
	bottom: "res4b21"
	top: "res4b21"
	type: "ReLU"
layer {
	bottom: "res4b21"
	top: "res4b22_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b22_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b22_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 256
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res4b22_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res4b22_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 1024
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res4b22_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b21"
	top: "res4b22"
	type: "Eltwise"
layer {
	bottom: "res4b22"
	top: "res4b22"
	type: "ReLU"
layer {
	bottom: "res4b22"
	top: "res5a_branch1"
	type: "Convolution"
	convolution_param {
		num_output: 2048
		kernel_size: 1
		pad: 0
		stride: 2
		bias_term: false
layer {
	bottom: "res5a_branch1"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res4b22"
	top: "res5a_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 512
		kernel_size: 1
		pad: 0
		stride: 2
		bias_term: false
layer {
	bottom: "res5a_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res5a_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 512
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res5a_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res5a_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 2048
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res5a_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	top: "res5a"
	type: "Eltwise"
layer {
	bottom: "res5a"
	top: "res5a"
	type: "ReLU"
layer {
	bottom: "res5a"
	top: "res5b_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 512
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res5b_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res5b_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 512
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res5b_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res5b_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 2048
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res5b_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res5a"
	top: "res5b"
	type: "Eltwise"
layer {
	bottom: "res5b"
	top: "res5b"
	type: "ReLU"
layer {
	bottom: "res5b"
	top: "res5c_branch2a"
	type: "Convolution"
	convolution_param {
		num_output: 512
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res5c_branch2a"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res5c_branch2b"
	type: "Convolution"
	convolution_param {
		num_output: 512
		kernel_size: 3
		pad: 1
		stride: 1
		bias_term: false
layer {
	bottom: "res5c_branch2b"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	type: "ReLU"
layer {
	top: "res5c_branch2c"
	type: "Convolution"
	convolution_param {
		num_output: 2048
		kernel_size: 1
		pad: 0
		stride: 1
		bias_term: false
layer {
	bottom: "res5c_branch2c"
	type: "BatchNorm"
	batch_norm_param {
layer {
	type: "Scale"
	scale_param {
		bias_term: true
layer {
	bottom: "res5b"
	top: "res5c"
	type: "Eltwise"
layer {
	bottom: "res5c"
	top: "res5c"
	type: "ReLU"
layer {
	bottom: "res5c"
	top: "pool5"
	type: "Pooling"
	pooling_param {
		kernel_size: 7
		stride: 1
		pool: AVE
layer {
	bottom: "pool5"
	top: "fc1000"
	type: "InnerProduct"
	inner_product_param {
		num_output: 1000
layer {
	bottom: "fc1000"
	top: "prob"
	type: "Softmax"
