Hi,I run ssd_dectect.py with input from on-board camera but I can only get 3-4 fps. If I run ssd_pascal_webcam with usb camera, i can get 8-10 fps. Anyone have experience in this problem?
Suppose that you are using this SSD GitHub.
In ssd_dectect.py, SSD read image with python PIL library.
To improve performance, it’s recommended to use GStreamer(python) or Argus(C++) to read a CSI camera.
def open_cam_onboard(width, height):
# On versions of L4T previous to L4T 28.1, flip-method=2
# Use Jetson onboard camera
gst_str = ("nvcamerasrc ! "
"video/x-raw(memory:NVMM), width=(int)2592, height=(int)1458, format=(string)I420, framerate=(fraction)30/1 ! "
"nvvidconv ! video/x-raw, width=(int){}, height=(int){}, format=(string)BGRx ! "
"videoconvert ! appsink").format(width, height)
return cv2.VideoCapture(gst_str, cv2.CAP_GSTREAMER)
I used it. But performance only get 3 fps
Suppose that time should be similar among CSI and USB camera.
Could you also try our jetson_inference sample with both CSI/USB camera?
https://github.com/dusty-nv/jetson-inference#running-the-live-camera-recognition-demo
If the onboard camera case takes longer in inferencing, issue may come from camera driver.
If not, we can check SSD sample or OpenCV in detail.
I tried jetson-inference and got ~10fps with CSI camera.
Jetson_inference also use GStreamer for opening the camera.
It’s recommended to compare the difference between jeston_inference and SSD:
https://github.com/dusty-nv/jetson-inference/blob/master/util/camera/gstCamera.cpp#L338
I shared a python script which could do real-time SSD object detection with either JTX2/JTX1 on-board camera, USB webcam or IP CAM. It runs at 5~6 fps for JTX2 on-board camera with pre-trained COCO SSD300 model (would be a little bit faster if VOC0712 SSD300 model is used instead).
Please refer to the following blog post.
