This project enable MacBook Pro with 48GB RAM to run Qwen3.5-397B-A17B at 4.4+ tokens/second
M3 Max can do 17.5 GB/s. Is internal SSD throughput on DGX Spark fast enough to implement this approach?
I believe DGX Spark External USB is 20GB/s but through put needs to be tested.
Update 1: PCIe 5.0 x4 allows for a theoretical bandwidth of up to 16 GB/s, with practical drive performance pushing over 14 GB/s so I think this approach might be worth a try.
The external USB ports on the DGX Spark are 20Gbit/sec, not 20GByte/sec. Best-case scenario, you’ll get around ~2GB/sec for large sequential reads from an external device.
It’s been tested multiple times, and there’s a few posts here in the forum about external USB drive speeds.
It’s certainly worth a try, but chances are you won’t see anywhere near 14GB/sec from the internal NVMe drive.
Here are results of a quick test on my FE DGX Spark with the Samsung 4TB drive:
Just keep an eye of RAM utlilization while loading the experts, so you don’t get into a situation where you’re using Linux Swap, the heavy writing could accelerate wear of your NVMe drive
