Start/stop streaming with Virtual channels issue
We are using 2 cameras connected to a single CSI port through GMSL and using virtual channels (Orin nano platform + JPack 6.1):
Camera 1 is an imx715 using vc-id=<0>, the second is a adsd3500 sensor using vc-id=<1>
Our DT : (it’s possible to have config with 2 x 2 cams)
tegra-capture-vi {
    num-channels = <4>;
	status="okay";
	ports {
		#address-cells = <1>;
		#size-cells = <0>;
		status="okay";
		port@0 {
			reg = <0>;
			Sensor_vi_in0: endpoint {
				status="okay";
				vc-id = <0> ;
				port-index = <0>;
				bus-width = <2>;
				remote-endpoint = <&imx715_csi_out0>;
		port@1 {
			reg = <1>;
			Sensor_vi_in1: endpoint {
				status="okay";
				vc-id = <1>;
				port-index = <0>;
				bus-width = <2>;
				remote-endpoint = <&adsd3500_csi_out1>;
		port@2 {
			reg = <2>;
			Sensor_vi_in2: endpoint {
				status="okay";
				vc-id = <0> ;
				port-index = <1>;
				bus-width = <2>;
				remote-endpoint = <&imx715_csi_out2>;
		port@3 {
			reg = <3>;
			Sensor_vi_in3: endpoint {
				status="okay";
				vc-id = <1> ;
				port-index = <1>;
				bus-width = <2>;
				remote-endpoint = <&adsd3500_csi_out3>;
We are using 2 applications running in parallel using these sensors separately: the application using the imx715 is based on ARGUS and the adsd3500 application uses v4l2.
So we can start and then stop the 2 cameras in any order…. worked perfectly with JetPack 5.1.2
With Jetpack6.1 if we stop the first camera (imx715) by stopping the application using it (VC=0), the application using the second camera does not receive data any more and we have a timeout in the kernel …
dmesg:
[ 2275.432709] imx715 9-001a: [T300] imx715_start_streaming entered.
[ 2275.472054] adsd3500 9-0040: [T300] adsd3500_start_streaming entered.
[ 2282.808832] imx715 9-001a: [T300] imx715_stop_streaming entered
[ 2285.989635] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 3000 ms
[ 2285.989664] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2285.991165] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 2289.061533] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 3000 ms
[ 2289.061560] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2289.062964] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 2292.069436] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 3000 ms
[ 2292.069465] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 2292.071143] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 2292.071197] adsd3500 9-0040: [T300] adsd3500_stop_streaming entered.
[ 2293.388227] tegra-camrtc-capture-vi tegra-capture-vi: subdev imx715 9-001a unbind
[ 2293.389269] adsd3500 9-0040: adsd3500_remove
[ 2293.391624] tegra-camrtc-capture-vi tegra-capture-vi: subdev adsd3500 9-0040 unbind
[ 2293.391777] adsd3500 9-0040: [T300] adsd3500_remove: ADSD3500 driver removed.
But the measurement with an oscilloscope shows that the mipi data on VC=1 still arrive without any problem until we stop the adsd3500 camera
This does not happen if we stop the camera using *adsd3500 first (*VC=1…)… Data are still received on VC=0 ???
Any idea what could produce this behavior?
For information, do you observe the issue when launching two cameras through v4l2? Or it is specific to launching one through v4ls and the other through Argus?
Hi DaneLLL
Thanks for the fast reply and suggestion…
With v4l2-ctl on both sensors, I have exactly the same behaviour …
hello Carbure,
please gather the logs for checking.
could you follow the steps to enable VI tracing logs.
for instance,
modprobe rtcpu_debug    #for JP-6.1 or later.
echo 1 > /sys/kernel/debug/tracing/tracing_on
echo 30720 > /sys/kernel/debug/tracing/buffer_size_kb
echo 1 > /sys/kernel/debug/tracing/events/tegra_rtcpu/enable
echo 1 > /sys/kernel/debug/tracing/events/freertos/enable
echo 2 > /sys/kernel/debug/camrtc/log-level
echo > /sys/kernel/debug/tracing/trace
cat /sys/kernel/debug/tracing/trace
Hi Jerry
I searched in the drivers of the sensor vendors to find differences when stopping streaming by activating kernel dynamic debugging.
Only the RGB sensor is calling camera_common_s_power (struct v4l2_subdev *sd, int on) with on=0
(file camera_common.c)
Commenting out the “else” part like this, solves the problem:
int camera_common_s_power(struct v4l2_subdev *sd, int on)
	int err = 0;
	struct camera_common_data *s_data = to_camera_common_data(sd->dev);
	if (!s_data)
		return -EINVAL;
	trace_camera_common_s_power("status", on);
	if (on) {
		err = call_s_op(s_data, power_on);
		………………….etc............
#if 0	 // Power off leads to timeout errors with Sick T-300 camera
        //if stopping RGB sensor , TOF cannot receive data anymore ....
	else {
        camera_common_dpd_enable(s_data);
		camera_common_mclk_disable(s_data);
		call_s_op(s_data, power_off);
#endif
	return err;
It works fine but this solution does not seem clean to me…what would be the right method?
hello Carbure,
it’s the kernel init stage to power-up for device registration.
is your camera stream also sending out while GMSL chip power-on?
Hi Jerry
GMSL chips (ser-des) are powered on … they are managed independently of the drivers because of conflicts between the 2 sensor drivers. ( theses drivers never act on GMSL components)
GMSL once powered on, the video pipes are disabled → Then one or both cameras are started … then the GMSL video pipes are activated … the video pipes are disabled after the 2 cameras has been stopped
hello Carbure,
please also collect VI tracing logs for more details.
traces.txt (575.9 KB)
It’s a big file … ;-)
hello Carbure,
did you gather the logs with the issue reproduced?
according to the tracing logs, it seems there’re validate frames on the CSI channel.
Yes :
and no data forTOF sensor
hello Carbure,
that should not root cause the issue as those code also present on JP-5.1.2
could you please check whether your TOF sensor driver have below operations.
for instance,
static struct v4l2_subdev_core_ops cam_subdev_core_ops = {
  	.s_power = camera_common_s_power,
Hi Jerry
In the TOF driver, I have
static const struct v4l2_subdev_core_ops adsd3500_core_ops = {
#ifdef CONFIG_VIDEO_ADV_DEBUG
	.g_register = adsd3500_g_register,
	.s_register = adsd3500_s_register,
#endif
but I have also :
static const struct v4l2_subdev_ops adsd3500_subdev_ops = {
	.core = &adsd3500_core_ops,
#endif
	.video = &adsd3500_video_ops,
	.pad = &adsd3500_subdev_pad_ops,
with CONFIG_VIDEO_ADV_DEBUG is not set
hello Carbure,
you may try making .core = &adsd3500_core_ops available.
since it’s adsd3500_core_ops to call s_power for sensor power-on.
for instance,
Hi Jerry
I had the same Idea …
But doing that, leads to a kernel Panic… I think , at this point , I’ve to contact the manufacturer of the driver …
hello Carbure,
you may see-also r36.4.3 release note of [4. Implementation Details] for some camera integration changes.
