Static 2D array problem
Hi all,
So simply, i am trying to do this.
  • declare a static 2D float array on host.
  • transfer it to the device
  • access the array on device just like i wud do at the host, (using )
  • process the array and return the array to host and print.
I obviously havent been able to do it, so am here. My question is , if it is at all possible to do with CUDA?.
If so, what is the problem with my code below:
float st_temp[4][4];
	float **dev_temp;
	for(int i=0;i<4;i++)
		for( int j=0;j<4;j++)
			 st_temp[i][j] = (float)rand()/RAND_MAX;
		for(int j=0;j<4;j++)
			printf("\n THE STATIC ARRAY ELEMENT : %.1f ",st_temp[i][j]);
	size_t dev_pitch,st_pitch;
	cudaMallocPitch((void**) &dev_temp, &dev_pitch, 4*sizeof(float), 4);
	cudaMemcpy2D((void *)dev_temp,dev_pitch,(const void *)st_temp,dev_pitch, 4*sizeof(float *),4, cudaMemcpyHostToDevice);
// gpu kernel
__global__ void kernel(float** a, float** b, float **c)
			printf("\n THE STATIC ARRAY ELEMENT : %.1f ",c[i][j]);
Thanks in advance!!
compiler does row-major map such that st_temp[i][j] = st_temp( i*4 + j ), but compiler must
know dimension of st_temp, that is why you declare
However in your kernel,
[codebox]global void kernel(float** a, float** b, float **c)
}[/codebox]
Compiler cannot map c[i][j] since no dimension of c is known at compiler time.
Question: why not using 1-D array and do index transformation manually?
Here is what i did to solve it in 3 simple steps
Declare 2D array in main :
float a[N][N],c[N-2][N-2];
Pass array to kernel:
kernel<<<dimGrid,dimBlock>>>((float() [N])a,(float() [N-2])c);
Kernel Signature:
global void kernel(float a[N][N], float b[N-2][N-2])
Access array in kernel as a regular 2D array syntax.
Note that i was more concerned about the syntax than the internal implementation and its meanings.
hope it helps to those who are concerned abt syntax like me. :)
thanx for ur interest.
-peace
I try simple case, data copy, it works
static __global__ void test_copy2D( doublereal odata[N][N], doublereal idata[N][N])
	// read the matrix tile into shared memory
	unsigned int xIndex = blockIdx.x * BLOCK_DIM + threadIdx.x;
	unsigned int yIndex = blockIdx.y * BLOCK_DIM + threadIdx.y;
	if((xIndex < N) && (yIndex < N))
		odata[yIndex][xIndex] = idata[yIndex][xIndex];
Could you post whole your code ?
besides, fix dimension in kernel function is not good.
2D arrays are not double pointers (pointers to pointers, arrays of arrays): they are used in the same way, with , but they are different things. Since you are speaking of static arrays, it is enough you replace their declaration:
__global__ void kernel(float a[N][], float b[N][], float c[N][])
Now the compiler will know how to access the elements, but notice that you will not be able to work with “pitched” arrays: if you have N oddly dimensioned, you are going to encounter performance troubles. View the CUDA programming guide about cudaMallocPitch() and the related example for reference.
I am glad I found one more monkey admirer in this forum!
