strange behaviour
Hello, guys!
I’d like to ask you to help me with a problem I don’t exactly know.
I am running a computer with an Nvidia Quadro FX 570 graphics card. And I’d like to start with CUDA-programming. But it doesn’t work. I’ve installed the following packages:
“cudatoolkit_2.3_linux_64_fedora10.run”
“cudasdk_2.3_linux.run”
and the driver for my card: “NVIDIA-Linux-x86_64-173.14.05-pkg2.run”.
I searched with google.com for a tutorial and found one (CUDA Tutorial | /// Parallel Panorama ///). But some of the code from this tutorial doesn’t run. The code from the first tutorial works fine. But from the secon does not. I modified to get some error-messages and informations about what doesn’t work:
// incrementArray.cu
#include <stdio.h>
#include <assert.h>
#include <cuda.h>
void incrementArrayOnHost(float* a, int N)
	int i;
	for(i = 0; i < N; i++)
		a[i] = a[i] + 1.f;
__global__ void incrementArrayOnDevice(float* a, int N)
	int idx = blockIdx.x * blockDim.x + threadIdx.x;
	if(idx < N)
		a[idx] = a[idx] + 1;
int main(int argc, char* argv[])
	float* a_h;
	float* b_h;	// pointers to host memory
	float* a_d;	// pointer to device memory
	int i;
	int N = 10;
	size_t size = N * sizeof(float);
	int blockSize = 1;
	// allocate arrays on host
	a_h = (float *)malloc(size);
	b_h = (float *)malloc(size);
	// allocate array on device
	cudaMalloc((void **) &a_d, size);
	// initialization of host data
		a_h[i] = (float)i;
		printf("a_h[%d]: %f\t", i, a_h[i]);
		printf("b_h[%d]: %f\n", i, b_h[i]);
	// copy data from host to device
	cudaMemcpy(a_d, a_h, sizeof(float) * N, cudaMemcpyHostToDevice);
	// do calculation on host
	incrementArrayOnHost(a_h, N);
	// do calculation on device:
	// Part 1 of 2. Compute execution configuration
	int nBlocks = N / blockSize + (N % blockSize == 0 ? 0 : 1);
	// Part 2 of 2. Call incrementArrayOnDevice kernel
	incrementArrayOnDevice <<< nBlocks, blockSize >>> (a_d, N);
	printf("incrementArrayOnDevice(%s);\n", cudaGetErrorString(cudaGetLastError()));
	// Retrieve result from device and store in b_h
	cudaMemcpy(b_h, a_d, sizeof(float) * N, cudaMemcpyDeviceToHost);
	// check results
		assert(a_h[i] == b_h[i]);
	// cleanup
	free(a_h);
	free(b_h);
	cudaFree(a_d);
And I got the following output:
user@Linux:~/Desktop/CUDA$ ./a.out
a_h[0]: 0.000000		b_h[0]: 0.000000
a_h[1]: 1.000000		b_h[1]: 0.000000
a_h[2]: 2.000000		b_h[2]: 0.000000
a_h[3]: 3.000000		b_h[3]: 0.000000
a_h[4]: 4.000000		b_h[4]: 0.000000
a_h[5]: 5.000000		b_h[5]: 0.000000
a_h[6]: 6.000000		b_h[6]: 0.000000
a_h[7]: 7.000000		b_h[7]: 0.000000
a_h[8]: 8.000000		b_h[8]: 0.000000
a_h[9]: 9.000000		b_h[9]: 0.000000
incrementArrayOnDevice(invalid device function );
a_h[0]: 1.000000		b_h[0]: 0.000000
a_h[1]: 2.000000		b_h[1]: 1.000000
a_h[2]: 3.000000		b_h[2]: 2.000000
a_h[3]: 4.000000		b_h[3]: 3.000000
a_h[4]: 5.000000		b_h[4]: 4.000000
a_h[5]: 6.000000		b_h[5]: 5.000000
a_h[6]: 7.000000		b_h[6]: 6.000000
a_h[7]: 8.000000		b_h[7]: 7.000000
a_h[8]: 9.000000		b_h[8]: 8.000000
a_h[9]: 10.000000	   b_h[9]: 9.000000
a.out: incrementArrays.cu:82: int main(int, char**): Assertion `a_h[i] == b_h[i]' failed.
Aborted
No compiling problems or anything. Then I tried to compile and run the examples from the SDK. And only some of them ran.
I show you some of the console outputs, so you might get an idea of what has gone wrong:
user@Linux:/opt/NVIDIA_CUDA_SDK/C/bin/linux/release$ ./3dfd
3DFD running on: Quadro FX 570
Total GPU Memory: 255.3125 MB
480x480x400
Unable to allocate 351.5625 Mbytes of GPU memory
  TEST PASSED!
user@Linux:/opt/NVIDIA_CUDA_SDK/C/bin/linux/release$ ./dct8x8
CUDA sample DCT/IDCT implementation
Loading test image: barbara.bmp... [512 x 512]... Success
Running Gold 1 (CPU) version... Success
Running Gold 2 (CPU) version... Success
cudaSafeCall() Runtime API error in file <dct8x8.cu>, line 195 : feature is not yet implemented.
Running CUDA 1 (GPU) version...
user@Linux:/opt/NVIDIA_CUDA_SDK/C/bin/linux/release$ ./Mandelbrot
[ CUDA Mandelbrot & Julia Set ]
Initializing GLUT...
Loading extensions: No error
OpenGL window created.
> Compute SM 1.1 Device Detected
> Device 0: <Quadro FX 570>
Data initialization done.
Starting GLUT main loop...
Press [s] to toggle between GPU and CPU implementations
Press [j] to toggle between Julia and Mandelbrot sets
Press [r] or [R] to decrease or increase red color channel
Press [g] or [G] to decrease or increase green color channel
Press [b] or [B] to decrease or increase blue color channel
Press [e] to reset
Press [a] or [A] to animate colors
Press [c] or [C] to change colors
Press [d] or [D] to increase or decrease the detail
Press [p] to record main parameters to file params.txt
Press [o] to read main parameters from file params.txt
Left mouse button + drag = move (Mandelbrot or Julia) or animate (Julia)
Press [m] to toggle between move and animate (Julia) for left mouse button
Middle mouse button + drag = Zoom
Right mouse button = Menu
Press [?] to print location and scale
Press [q] to exit
Creating GL texture...
Texture created.
Creating PBO...
cudaSafeCall() Runtime API error in file <Mandelbrot.cpp>, line 892 : feature is not yet implemented.
cudaSafeCall() Runtime API error in file <Mandelbrot.cpp>, line 468 : feature is not yet implemented.
And here the output from the deviceQuery:
user@Linux:/opt/NVIDIA_CUDA_SDK/C/bin/linux/release$ ./deviceQuery
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: "Quadro FX 570"
  CUDA Driver Version:						   0.0
  CUDA Runtime Version:						  2.30
  CUDA Capability Major revision number:		 1
  CUDA Capability Minor revision number:		 1
  Total amount of global memory:				 267714560 bytes
  Number of multiprocessors:					 16
  Number of cores:							   128
  Total amount of constant memory:			   65536 bytes
  Total amount of shared memory per block:	   16384 bytes
  Total number of registers available per block: 8192
  Warp size:									 32
  Maximum number of threads per block:		   512
  Maximum sizes of each dimension of a block:	512 x 512 x 64
  Maximum sizes of each dimension of a grid:	 65535 x 65535 x 1
  Maximum memory pitch:						  262144 bytes
  Texture alignment:							 256 bytes
  Clock rate:									0.92 GHz
  Concurrent copy and execution:				 Yes
  Run time limit on kernels:					 No
  Integrated:									Yes
  Support host page-locked memory mapping:	   Yes
  Compute mode:								  Default (multiple host threads can use this device simultaneously)
Test PASSED
Press ENTER to exit...
Do you have any idea, what I need to do to get this CUDA-thing working?
Could it be that my device-driver is too old and that I need to install a new one? If so, how do I uninstall the old one?
Could it be that the other hardware from my computer is causing the problem?
I’d be very happy to have a useful answer!
–Teewurst
BTW: My OS is:
Linux Linux 2.6.22.8 #1 SMP Tue Sep 25 20:41:25 BST 2007 x86_64 x86_64 x86_64 GNU/Linux
And the distribution is called Slamd64 12.0
That driver is far too old to work. For the CUDA 2.3 toolkit version you are using, you need a 190 series driver (190.53 is the current stable release driver). Until you update the driver, nothing is going to work.
Thanks for your very quick reply. But I have a (stupid) question. How am I going to do the update? Will the new driver recognize the old one an make a “clean” installation, so that I don’t have trouble with two drivers installed at the same time or do I have to uninstall the old driver first?
–Teewurst
The driver intaller will detect the presence of older driver installations and ask you whether you remove them or not. I have never had a problem updating drivers using the NVIDIA driver installation script.
Don’t know for sure does this has anything to do with the issues you’ve encountered, but if possible for you I’d strongly suggest upgrading your Linux installation too. Slamd64 12.0 is very, very old distribution, and now when an officially supported 64-bit Slackware branch is available, I see no reason to use anything else. Furthermore: various CUDA releases (always ones for latest RHEL version) worked for me perfectly with Slackware for years; at the moment, I’m using CUDA 3.0 beta (you could find the packages here) with Slackware64 13.0, and it works like charm.
Thanks you two for your answers! The installation of the new driver was no problem. It detected the old one and deleted it. That fixed the problem with CUDA and gave me about 20% extra bandwidth :)
@cgorac: I don’t yet see the point in upgrading a well running system. “Never touch a running system” ;)
–Teewurst
Makes sense, that kind of decision is of course matter of personal taste… I mentioned it just as an alternative to try, and only because Slackware has rock-solid upgrade mechanism (I’m tracking -current for years, without any kind of issue), and there exist some goodies to pick up along the way (security fixes first of all, but then also upgrades for the development tools, and also some additions to the tool-chain from time to time - for example CMake is upgraded recently in -current, and now CMake CUDA module is included, etc.).
