Strange Performance Problem using atomicAdd
I have a strange performance problem using atomicAdd. My kernel sums up the rows and columns of a matrix. Therefore the matrix is copied to shared memory and summed up using the following code:
#define SMEM_INDEX(x, y)	((y) - ((y/THREADS_PER_BLOCK_Y) * THREADS_PER_BLOCK_Y)) * THREADS_PER_BLOCK_Y + \
							 (x) - ((x/THREADS_PER_BLOCK_X) * THREADS_PER_BLOCK_X)
	//Add up rows
	if ((threadIdx.y < THREADS_PER_BLOCK_Y) && (threadIdx.x == 0))
		unsigned int tmp = 0;
		#pragma unroll
		for (int i = 0; i < THREADS_PER_BLOCK_X; i++)
			//Add up bins
			tmp += imgdata[SMEM_INDEX(i, threadIdx.y)];
		atomicAdd(&d_vhisto[blockIdx.y * blockDim.y + threadIdx.y], tmp);
	//Add up columns
	if ((threadIdx.x < THREADS_PER_BLOCK_X) && (threadIdx.y == 0))
		#pragma unroll
		for (int i = 0; i < THREADS_PER_BLOCK_Y; i++)
			//Add up bins
			tmp += imgdata[SMEM_INDEX(threadIdx.x, i)];
		atomicAdd(&d_hhisto[blockIdx.x * blockDim.x + threadIdx.x], tmp);
The code works fine, but when I comment out the first aromicAdd (the one used to add up the rows), my kernel runs in about half a millisecond. When not commenting out this line, I get a performance drop to 6 milliseconds External Image. The second atomicAdd does not influence the performance significantly. Below are some profiling results. The problem is obvious, the kernel branches. But why is this caused by this single instruction?
Without first atomicAdd:
GPU time: 446.848
CPU tim: 541.433
grid X: 40
gridY: 30
blockX: 16
blockY: 16
shared mem: 1084
register: 6
occupancy: 1
branch: 9568
div. branch: 598
instructions: 142358
cta launched: 1200
gld32b: 0
gst32b: 0
gst64b: 321993
tex cache hit: 0
tex cache miss: 38400
With first atomicAdd:
GPU time: 5770.69
CPU tim: 5871.77
grid X: 40
gridY: 30
blockX: 16
blockY: 16
shared mem: 1084
register: 7
occupancy: 1
branch: 28800
div. branch: 5400
instructions: 286858
cta launched: 1200
gld32b: 0
gst32b: 0
gst64b: 105985
tex cache hit: 0
Thanks in advance,
Kwyjibo
If you comment out the atomicAdd(), the whole preceding loop can be optimized out by the compiler.
This is true for both loops. However, the first loop runs significantly slower than the second, as it only uses two threads of each warp, wasting 30/32 of its resources. In the second loop, only one warp (with 16 threads used) remains active, while the other warps where threadIdx.y>0 do not execute at all.
Thank you, I took both for loops into the second if block, now it runs like a charm in about 700 ms.
EDIT: I fine tuned my code and it now looks like this and I still get different runtimes for htype = VERTICAL and htype = HORIZONTAL. The difference is not dramatic (about 0.4 ms), I can live with it, but I still would like to know, what is causing this difference. (The reason is not the calculation of i_shifted.)
if ((threadIdx.x < BLOCK_SIDE_LENGTH) && (threadIdx.y == 0))
		unsigned int bin;
		if (htype == HORIZONTAL || htype == BOTH)
			//Add up columns
			#pragma unroll
			for (int i = 0; i < BLOCK_SIDE_LENGTH; i++)
				//Add up bins
			bin = blockIdx.x * blockDim.x + threadIdx.x;
			if (bin < (desc.d_width/desc.d_padding)) atomicAdd(&d_hhisto[bin], tmp);
		tmp = 0;
		if (htype == VERTICAL || htype == BOTH)
			//Add up rows
			#pragma unroll
				//Shift i to avoid bank conflicts
				int i_shifted = (i + threadIdx.x) % BLOCK_SIDE_LENGTH;
				//Add up bins
				tmp += imgdata[SMEM_INDEX(i_shifted, threadIdx.x)];
			bin = blockIdx.y * blockDim.y + threadIdx.x;
			if (bin < desc.d_height) atomicAdd(&d_vhisto[bin], tmp);
Any idea?
Thanks in advance,
Kwyjibo
		unsigned int bin;
			//Add up columns
			#pragma unroll
				//Add up bins
		tmp = 0;
			//Add up rows
			#pragma unroll
				//Add up bins
Any idea?
Thanks in advance,
Kwyjibo
