Jetson Nano
• DeepStream Version
5.0
4.5
• TensorRT Version
7.1.3.0
Question
Hello, I’m currently trying to use a Logitech C922 webcam as input in deepstream-test3. I’m using ustreamer to start a stream on a localhost IP, then I’ll pass this IP as a URI to the deepstream-test3 app. This sample with the ustreamer URI, runs with no errors in my dGPU system, but I’m getting the following error on Jetson Nano:
ERROR from element source: Internal data stream error.
Error details: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:dstest3-pipeline/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin/GstSoupHTTPSrc:source:
streaming stopped, reason not-negotiated (-4)
What can I do to solve this error?
I also tested the stream from ustreamer on deepstream-app and it worked fine on the Jetson Nano, but not in the deepstream-test3.
Thanks in advance.
