Gst-stream-error-quark: Internal data stream error
Jetson TX2
• DeepStream Version
6.0
4.6
• TensorRT Version
8.0
Error: gst-stream-error-quark: Internal data stream error. (1): gstbaseparse.c(3611): gst_base_parse_loop (): /GstPipeline:pipeline0/GstH264Parse:h264-parser:
streaming stopped, reason not-negotiated (-4)
Run the python3 deepstream-test1 sample out of the box as per the readme instructions. Altering no code or config files.
I found a user having a similar issue here: Python in DeepStream: error {Internal data stream error} while running deepstream-test1 - #9 by rohit167
The answers provided by support there failed to resolve the issue. One difference between that user and me is I am working directly on the TX2 with a monitor plugged into it, not using SSH. A similar issue also occurs when I try to run the C sample app deepstream-test1.:
Error details: gstbaseparse.c(3611): gst_base_parse_loop (): /GstPipeline:dstest1-pipeline/GstH264Parse:h264-parser:
Using python code provided from the forum post linked above yields the following error:
  File "deepstream_test_1.py", line 315, in <module>
    sys.exit(main(sys.argv))
  File "deepstream_test_1.py", line 213, in main
    encoder.set_property("bitrate", 2000000)
AttributeError: 'NoneType' object has no attribute 'set_property'
I am able to run other sample projects like the objectDetector_Yolo configuration with no issue. I am unsure why these sample apps in C and Python are different in my environment.
Thanks in advance.
Can you show us your command line of run python3 deepstream-test1 sample?
@Fiona.Chen Hello, the following is how I am attempting to run the deepstream sample app. The mentioned mp4 file is in the same directory as the python file.
python3 deepstream_test_1.py sample_1080p_h264.mp4
The readme file of deepstream_test_1.py has told you the input should be h264 element stream.
deepstream_python_apps/README at master · NVIDIA-AI-IOT/deepstream_python_apps (github.com)
Hi, thank you for your reply.
The command I used is now python3 deepstream_test_1.py sample_720p.h264 and I am receiving a new error:
File "deepstream_test_1.py", line 55, in osd_sink_pad_buffer_probe
    batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
AttributeError: module pyds has no attribute gst_buffer_get_nvds_batch_meta
From this file.
Please check whether your pyds is installed correctly. DeepStream SDK FAQ - #22 by mchi
